Can I also do as follows? Run the docker in https://hub.docker.com/r/spreed/webrtc/
And change the IP in the vhost file sample to the servers IP running the docker container?
Or am I missing something important then?
Does it have hardware config requirements (such as x86-64/amd64 for the Collabora docker)?
On my nextcloud server renamed both spreed app config/config.php.in and extra/static/config/OwnCloudConfig.js.to config.php and OwnCloudConfig.js (removed the in and set the shared secret.
In the server.conf I changed the ip to 0.0.0.0. Root is commented. Now the paths in âextraâ and âpluginâ have values that cannot match as they refer to the primary. Changing them to URLS doesânt work either. I get error messages starting the docker. When I comment them out, I do get Spreed visible in my nextcloud setup.
But the message says I need to sign in to create a room.
Do I need to set a serverRealm than local? What do I do with âextraâ and âpluginâ?
allowed me in and even I could make calls to registered users (when they are logged in into nextcloud)
the âextraâ line I had to leave commented.
This leaves me with a
"Configured extra â/home/share/public_html/apps/spreedme/extraâ is not a directory.
message.
⊠Also I cannot see the âkeyâ icon though to invite (external/temp) users though.Does that come with TURN server installed? Where would I install that? On the machine running the spreed me docker or the machine running nextcloud?
âŠ
It seems a bit different, admin user has the key icon, normal user does not. I need to create a group where all users in that group are group admins (see manual on https://github.com/strukturag/nextcloud-spreedme)
The modal popping up seems too small for all content (form fields and create button are not visible in chrome, FF shows scrollbar), you can scroll, but the create button does not work (yet).
For the spreedme / webrtc docker
The server.conf in /srv/extra/ needs to be:
; Minimal Spreed WebRTC configuration for Nextcloud, split server, external user invite
[http]
listen = 0.0.0.0:8080
basePath = /webrtc/
[app]
sessionSecret = xxxxxxxxxxxxx
encryptionSecret = xxxxxxxxxxxxx
authorizeRoomJoin = true
serverToken = xxxxxxxxxxxxxxx
serverRealm = nextcloud.com
extra = /srv/extra
plugin = /apps/spreedme/extra/static/owncloud.js
turnURIs = turn:nextcloud.com:8443?transport=udp turn:nextcloud.com:8443?transport=tcp
turnSecret = the key you set in /apps/spreedme/config/config.php when you set it to true
[users]
enabled = true
mode = sharedsecret
sharedsecret_secret = xxxxxxxxxxxxxxx
Copy the contents of /home/share/public_html/apps/spreedme/extra/ on your webserver to folder /srv/extra/ on the server running docker.
Start the docker.
Now I installed âcoturnâ on my webserver. With this in /etc/turnserver.conf
listening-port=8443
alt-listening-port=3478
fingerprint
lt-cred-mech
use-auth-secret
static-auth-secret=the key you set in /apps/spreedme/config/config.php when you set it to true
realm=nextcloud.com
total-quota=100
bps-capacity=0
stale-nonce
cipher-list="ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:ECDH+3DES:DH+3DES:RSA+AES:RSA+3DES:!ADH:!AECDH:!MD5"
log-file=/var/log/turn.log
no-loopback-peers
no-multicast-peers
cert=/path_to_nextcloud.com/ssl.cert
pkey=/path_to_nextcloud.com/ssl.key
And (re)started the coturn server.
On my router needed the following ports forwarded to my webservers IP:
8443
3478
Now that made it work in and outside my network: sound, video and screen sharingâŠ
As I migrated to another server for my nextcloud instance I discovered my spreed.me failed me.
It appeared FirewallD, new in my debian switch on an up-board with webmin/virtualmin, was blocking it.
Adding the ports 8443 and 3478 to allowed made it work againâŠ
