[solved] issues with nextcloudpi on pi3b+
hello, i’m french
i have follow a tutorial to convert my raspberry pi3b+
because images systems on the git hub ares for pi4 and pi5
Welcome 01power.
you may start with an older image, usually rpi4 images should work for rpi3.
You may take a look at a conversation I had some days ago and check the links given there.
hello, thank’s for your reply ,
i have accidentaly sent the massage befor ending it and i’ve do a doble.
I thought that the pi 4 image will dont work on pi 3b+
ok i will try it,
So you may check to start with rpi images older than the switch to armbian based images for rpi, resulting in many updates especially dist-upgrade to bookworm.
Citation from the doble message but this one are complete : hello, i’m frend and i need your help
i haven’t find the image disk fot the 3b+. so, i have follow a tutorial to install nextcloud on my pi 3b+ after installing the “os” and rebooting, when i try to access with crome or edge, with the ip, the first time i have the notification for the unsecur page, so i when i say i will enter nothing appen and when i refresh the page it’ turn but the page don’t open
i haven’t found answer on the forum
have you an idea to solve it i’ve try 2 internet explorer (chrome and edge), and i’ve try to turn off my anti malware
i have test it vith the V1.53.2 but, i have the sames problems than the start
when i try to access mon my navigator after clicking on the continue to HTTPS://(IP) nothing happen
and with the 1.55.3 i have the error : ERR_CONNECTION_REFUSED
To write the images did you use rpi-imager without any presets?
no i’ve use balenaetcher
and i’ve try the 1.54.3 and same problem than 1.55.3
i have follow a tutorial he say tu use balena etcher
did you have somes advices ?
Do us a favour - try rpi-imager without any presets,
same problem, access denied
You got this on your browser, sorry, that is the certificate warning, you have to go further.
when i’ve try with the 1.53.2 i have the cetificate werning when i try to go further nothing happen, and if i close (or try to refresh) the page and retry the loading indicator turn but the page never appers
and when i try vith the 1.54.3 or 1.55.3 i have : ERR_CONNECTION_REFUSED and can’t do somthing else click on refresh
javascript enabled, no other blocker?
i have 2 ad blocker on chrome bu nothing en edge, generaly i don’t use edge.
i have check java script is enable on edge
Let’s take the chrome browser, try disable the blocker, I’m mostly running firefox.
hello for now i have arrived to the login page with fire fox,
Solved > in the tutorial he say to use the first password to acess to the configuration and add the usb SSD ou HDD
but when i use the first password the server reject me and when i use the second, i was accepted, but i don’t find how to configure it
i have forced by writing " :4443 " after the ip and i have open the wizard to add my ssd
i try to arrived to finish to set it
First set up ssh, so you have another login opportunity to your rpi3 device, I prefer this, ncp-config gives you the same commands as webgui:4443 but more error/log messagess and so on.
Good luck and have fun,
it is not too bad :wink:
i have a new problem perhaps it’s the last one
i have creat à no-ip dyn dns
i have set it in my internet box, i have open the ports 80 et 443,
i have set the dyn dns in the nextcloud pi,
and when i use my external IP to open the access on my android phone (in the nextcloud app)
it dont work, i stop for today, and with somes chance wil could finish to make it work tomorrow or monday
no, never
but in the next topics there I have no personal expertise because my ncp runs local only.
How to access from outside your network
Read the docs and the forum, open a new, more specific thread here.
Good luck and much fun.
hello, i have finish to set and make work my pi cloud but 2 new problems
Maybe you could report back what your solution looks like, so others wouldn’t waste their time reading this thread.
