Nextcloud version (eg, 18.0.2): 20.0.4.0
Operating system and version (eg, Ubuntu 20.04): debian stable
Apache or nginx version (eg, Apache 2.4.25): nginx/1.14.2
PHP version (eg, 7.1): 7.4.10 php-fpm
The webinterface is really slow (20 000ms+ loading time) while the dav etc are fine
(https://check-host.net/check-http?host=https://cloud.torbenarne.de/index.php/login)
Is this the first time you’ve seen this error? (Y/N): No
- Install nextcloud with redis, apcu and OPCache
- use it for a while
There is no error per se, so nothing to paste here
'instanceid' => 'REMOVED',
'passwordsalt' => 'REMOVED',
'secret' => 'REMOVED',
0 => 'REMOVED',
1 => 'cloud.torbenarne.de',
'datadirectory' => '/srv/www/nextcloud-data',
'version' => '20.0.4.0',
'overwrite.cli.url' => 'https://cloud.torbenarne.de',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextclouduser',
'dbpassword' => 'REMOVED',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => 'REMOVED',
'mail_domain' => 'REMOVED',
'mail_smtphost' => 'REMOVED',
'mail_smtpauth' => 1,
'mail_smtpname' => 'REMOVED',
'mail_smtppassword' => 'REMOVED',
'mail_smtpport' => '465',
'theme' => '',
'loglevel' => 2,
'log_query' => false,
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'dbindex' => 0,
'ldapIgnoreNamingRules' => false,
'updater.secret' => 'REMOVED',
'encryption.legacy_format_support' => true,
'encryption.key_storage_migrated' => false,
Nothing in the nginx errorlog or the php-fpm log
Question: Is there a tool through which I could get deeper insights why my nextcloud is slow?
