SIP Trip Phone Issues
I installed the SIP Trip Phone app that went successful (duh)
But the problem lays with the opening, it sends me to https://example.com/custom_apps/sip_trip_phone/phone/index.php
But that page doesn’t exist.
Im running it on docker with apache.
  • Nextcloud Hub 10 (31.0.5)
  • Ubuntu 24.04
  • Apache 2.4.25
  • PHP 8.3
  • Is this the first time you’ve seen this error? Yes
  • When did this problem seem to first start? Ater install
  • Installation method: AIO, Docker
  • Using Cloudflare
Hello @Syntax,
welcome to the community of Nextcloud :handshake:
You started a topic in support category. Unfortunately you ignored the template and a lot of information to help you is missing. Please edit your original post and add all required details like Nextcloud version, webserver type and version, os version, related log file content. Use the support template.
Without additional information the community members cannot help you.
Regards,
wwe
My bad, hope this looks better.
I’m running standard community docker and can’t confirm your finding. the app goes to the right domain. I would recommend reviewing your reverse proxy config 101: reverse proxy and if you still experience issues adding logs and configs as required per support template.
Do you not have Pretty URLs enabled? That app requires it.
