[detail =“Support intro”]
example
[/details]
This has been solved! Thanks to NeptuneUK and stratege1401! Short thing short, when changing character collation type, make sure to follow the questions closely. There is some assistance here if needed. (Edit 2: Still not working. See latest post) Nextcloud team, maybe make the docs a little clearer. Besides that, great job on this.
Nextcloud version (eg, 12.0.2): 16.01
Operating system and version (eg, Ubuntu 17.04): Ubuntu 18.04
Apache or nginx version (eg, Apache 2.4.25): 2.4.29
PHP version (eg, 7.1): Php 7.2
When going to the share menu for any file or directory and start typing in an email/contact, Invalid query, please check the syntax. API specifications are here: http://www.freedesktop.org/wiki/Specifications/open-collaboration-services pops up.
Is this the first time you’ve seen this error? (Y/N):Yes
See above.
PASTE HERE
Is this in the data or web root directory. Couldn't seem to find in either.
Not sure where to find
Someone had a similar issue that I replied with a summary to at https://github.com/nextcloud/server/issues/15740. Was just scrolling through GitHub’s issue creation and tried running
sudo -u www-data php occ config:list system in both my data and web directories and got segmentation defaults. Is this the issue? Sorry if I’m posting in the wrong place. I’m new to Nextcloud and just installed this and Collabora.
