Problem solved for me. I was using a quotes before and after number “1” , ‘maintenance_window_start’ => “1” . Apparently it was my mistake!
Thnaky you jtr!
Thnaky you jtr!
That’s SO much better! Thanks for that, the page will now actually help someone that follows the link in the error ![]()
As I said before, we’d be lost without this forum and you! ![]()
I didn’t do anything, but maybe someone who read this thread…?! ![]()
Does anyone have any more precise explanations of the values to be set, the values are basically clear to me… (and I don’t have the information warning anymore)
e.g.
Value 1 the tasks runs between 1 a.m. and 5 a.m
e.g.
Value 3 the tasks runs between 3 a.m. and 7 a.m
So always everything between 4 hours… so far ok,
Can enter the value 100 disable it or the task can always be executed, also got it…
But what do values like 25 do?
The tasks is between 1 and 5 every 2 days?
25 to 99 works at all?
.25 , .5 or .75 values also possible like 2.75 ?
the documentation on this is a bit poor.
Maybe someone has an explanation about this, it would be very helpful.
Thanks
Nothing notable. It’s not a valid hour. Technically, it’ll be treated the same as 100 at present, but it’s not guaranteed to work.
Well those values aren’t documented because they aren’t supported. ![]()
The bulk of the code is here[1] if you’re curious about the implementation.
[1] server/cron.php at 77f4c84c18340ed049056bada3327b941887d1b8 · nextcloud/server · GitHub
Any valua greater 23 wil disable the time window (like 100 does).
You can read it fom within the code:
ernolf
I have a problem with it mapping the app_data folder for the backup.
It doesn’t give me the option to update it.
