Scan.nextcloud.com does not resolve my Nextcloud instance
I have no support/technical question and have seen the support category. (Be aware that direct support questions will be deleted.)
on
Which general topic do you have
The security scanner site seems to have DNS issues as it can not resolve my host.
nextcloud.westkamp.net.
This is informational.
Regards and thanks,
Klaus
@Unwissender no need for dupes, but thanks for mentioning;
As mentioned in the other issue, the problem is now fixed.
Happy scanning!
