example
longer
example
here
Nextcloud version (eg, 12.0.2): 16.0.4
PHP version (eg, 7.1): 7.3
I followed the steps for manual upgrade because web updater is running in timeouts while doing the backup.
How to upgrade
Manual Upgrade with Shared Hosting/Webhosting
So I
- download and extract the nextcloud files for 16.0.9
- set maintenance to true
- copied config.php, data and 3rd party apps to directory of new version
- renamed old version to “nc_old” and new version to “nc”
- set maintenance to false
- opened my instance via browser and clicked “upgrade”
I’m running in a timeout here again. Web Updater says I "to prevent timeouts use ./occ upgrade", but I’m not able to do this on sharedHosting (I have SSH access but can not run sudo commands, so I get a "permission denied when running ./occ upgrade).
So: How can I finish the upgrade process after manual file update on a system without sudo permissions?
Thank you for your responses!
config.php
'instanceid' => 'oc6cbvwhknq6',
'passwordsalt' => 'IZZ3cW55Q8sAseDOnuKjcX7ux2AV+7',
'secret' => 'ztM77bf0X8IOfkwmvMA6unDtO21SeHVCYZnUPEOyw64v4OdT',
0 => '********',
'datadirectory' => '/var/www/vhosts/*********/httpdocs/nc/data',
'overwrite.cli.url' => '*******',
'version' => '16.0.4.1',
'dbname' => '******',
'dbhost' => '**********',
'dbuser' => '*****',
'dbpassword' => ******',
'updater.release.channel' => 'production',
'maintenance' => true,
'mail_from_address' => '*****',
'mail_smtpmode' => 'smtp',
'mail_domain' => '******',
'theme' => '',
'loglevel' => 0,
'mail_smtphost' => '******',
'mail_smtpsecure' => 'tls',
'mail_smtpauth' => 1,
'mail_smtpname' => '*******',
'mail_smtppassword' => '*******',
'mail_smtpport' => '***',
'skeletondirectory' => '',
'app_install_overwrite' =>
0 => 'mail',
1 => 'occweb',
'trashbin_retention_obligation' => 'auto, 180',
'updater.secret' => '$2y$10$UHvKGZ/rdVycW.uaPZ1areN2ud7qQ9S9EWBR69T4fV4gH7AqTWmsm',
