Hi everyone,
Frank announced resource management for the calendar app at the Nextcloud conf this year, but I can’t find any announcement, commit message or new function in NC14. Did I get something wrong?
Cheers,
Klaus
Hi everyone,
Cheers,
Klaus
Resource management was integrated in the server:
If I understood correctly, this functionality is not yet exposed by the calendar app…
Have a look to
By the way, I am not sure that asking the exact same question in two different threads helps anyone…
FYI there is now a publicly available back-end for the resource booking system Georg started: GitHub - nextcloud/calendar_resource_management: Resources back-end for the Nextcloud CalDAV server
beware this is still a prototype
@ChristophWurst, what must be done that this experimental backend can be loaded as active App in a Nextcloud environment?
According to the README you have to place the files (more precise: the directory with the files) in the nextclouds/apps
directory.
(see GitHub - nextcloud/calendar_resource_management: Resources back-end for the Nextcloud CalDAV server) . Did you try that already?
@fwolfst,I did not try, I found readme empty, this afternoon. I guess I manage to try tomorrow and will come back with news.
@ChristophWurst, App Version 0.1.0 Alpha2 is installed, means I copied the unzipped files and directories into …/apps/calendar_resource_management and activated it in the Apps section of the Admin-User of my Nextcloud.
But now I find no place where I could configure the App or create Resources as an Sample room.
What is the Workaroud? Is there at least a rudimentary documentation?
Please make sure that you download the calendar_resource_management.tar.gz
since everything else is just the repo.
You have to use occ
and the calendar-resource:*
commands.
Documentation · Issue #4 · nextcloud/calendar_resource_management · GitHub docs are still missing.
Thank for the answer, but this workaround seems too difficult for me.
