Nextcloud version (eg, 20.0.5): 29.0.1.1
Operating system and version (eg, Ubuntu 20.04): Debian 11
Apache or nginx version (eg, Apache 2.4.25): Apache2.4
PHP version (eg, 7.4): php 8.3
When I access xxxx.com, the following message appears
Downgrading is not supported and is likely to cause unpredictable issues (from 29.0.1.1 to 29.0.0.19)
In the config file, , I have the following parameter
‘version’ => ‘29.0.1.1’,
And now I have errors with DAV events (that make sense) :
Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
There are no commands defined in the "dav" namespace.
Do you have any idea how to fix it, please ?
Thanxx
Iupdated Nextcloud with the following commands :
- php8.3 -f /var/www/xxxx.com/web/updater/updater.phar -e
- php8.3 -f /var/www/xxxx.com/web/occ upgrade
I resolved the issue by setting the value ‘version’ => ‘29.0.0.19’ in config file.
- access to
xxxx.com
"reqId": "tghSAQbbb8lMzgF6N8e9",
"level": 3,
"time": "2024-05-24T08:47:12+02:00",
"remoteAddr": "2001:41d0:2:dd7c::",
"user": "--",
"app": "core",
"method": "GET",
"url": "/",
"message": "Rendering themed error page failed. Falling back to unthemed error page.",
"userAgent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36",
"version": "29.0.1.1",
"exception": {
"Exception": "OCP\\HintException",
"Message": "Downgrading is not supported and is likely to cause unpredictable issues (from 29.0.1.1 to 29.0.0.19)",
"Code": 0,
"Trace": [
"file": "/var/www/clients/client1/web8/web/lib/public/Util.php",
"line": 599,
"function": "needUpgrade",
"class": "OC_Util",
"type": "::"
"file": "/var/www/clients/client1/web8/web/lib/private/TemplateLayout.php",
"line": 286,
"class": "OCP\\Util",
"type": "::"
"file": "/var/www/clients/client1/web8/web/lib/private/legacy/OC_Template.php",
"line": 145,
"function": "__construct",
"class": "OC\\TemplateLayout",
"type": "->"
"file": "/var/www/clients/client1/web8/web/lib/public/AppFramework/Http/TemplateResponse.php",
"line": 211,
"function": "fetchPage",
"class": "OC_Template",
"type": "->"
"line": 269,
"function": "render",
"class": "OCP\\AppFramework\\Http\\TemplateResponse",
"type": "->"
"file": "/var/www/clients/client1/web8/web/index.php",
"line": 60,
"function": "printErrorPage",
"type": "::"
"File": "/var/www/clients/client1/web8/web/lib/private/legacy/OC_Util.php",
"Line": 1155,
"Hint": "Downgrading is not supported and is likely to cause unpredictable issues (from 29.0.1.1 to 29.0.0.19)",
"CustomMessage": "Rendering themed error page failed. Falling back to unthemed error page."
"id": "665039a0eba36"
