Here is the latest RC before the final release! ![]()
Thank you all for the dedicated support and reviewing of those last beta/RC! ![]()
Download
History
- First RC of Nextcloud 30 - Hub 9
- Second RC of Nextcloud 30 - Hub 9
- Third RC of Nextcloud 30 - Hub 9
- Fourth RC of Nextcloud 30 - Hub 9
What changed
- Fix(dav): Always respond custom error page on exceptions (server#47787)
- Fix: Fix inaccessible content on public pages due to overlapping footer (server#47810)
- Fix: Run migration sql as statement so that the primary db node is used (server#47839)
- Fix: Replace conflicting tags in
xml_exceptiontemplate (server#47842) - Fix(files_sharing): password checkbox and labels in link share (server#47851)
- Add an endpoint to remove all webhook registrations from an app (server#47855)
- Fix: Only write once to template instead of create/copy (server#47863)
- Fix: make swift connect exception message more informative (server#47874)
- Fix(files): Sort tree views correctly by natural order (server#47882)
- Fix(theming): Add migration to restore primary color after separating primary and background (server#47897)
- Chore: Update trashbin retention documentation with exceeded quota details (server#47912)
- Fix: Add whiteboard to education and public sector bundle (server#47915)
- Fix display name of new users (circles#1688)
- Fix: Add app hint for whiteboard (firstrunwizard#1355)
- Update nextcloud/ocp dependency (nextcloud_announcements#378)
- Chore(deps): Bump @nextcloud/vue from 8.17.0 to 8.17.1 (notifications#2024)
- Update nextcloud/ocp dependency (notifications#2026)
- Chore(deps): bump nextcloud/vue from 8.17.1 to 8.18.0 (notifications#2031)
- Update nextcloud/ocp dependency (serverinfo#678)
- Chore(deps): update dependency vite to ^5.4.3 (text#6328)
- Chore(deps): update dependency eslint-plugin-cypress to ^3.5.0 (text#6330)
- Update nextcloud/ocp dependency (text#6334)
- Fix(TaskList): Add class name to rendered HTML (text#6340)
- Fix: Reset session if file rename changes mimetype from/to markdown (text#6348)
- Update nextcloud/ocp dependency (twofactor_nextcloud_notification#873)
- Fix npm audit (twofactor_nextcloud_notification#875)
- Update cypress snapshots (viewer#2465)
