RC3 of Nextcloud 30 - Hub 9
We’re closing in the final release! :tada:
Thank you all for the dedicated support and reviewing of those last beta/RC! :bowing_woman:
You can download the RC3 already from our download servers:
History
First RC: First RC of Nextcloud 30 - Hub 9
Second RC: RC2 of Nextcloud 30 - Hub 9
What changed
Will the new version be released on Docker?
Which docker image do you refer to? But generally the final should be available just as previous versions.
Will it have the fix where it detects typing and updates accordingly? Right now mine stopped updating changes once saved once…
for one, does the changelog contain an entry that would match? For the other, do you have a link to the bug report?
HOLY FRUIT BAT!!!
It’s the red stuff not the yellow stuff, that’s been there since day 1 of installing NC
The first one is about your server configuration, we cannot fix that for you.
Cannot say anything about the second one, depends on the details.
Third one may depend on the previous item or not, but have not seen this before. Check the bug tracker after the items above are solved and it is still present, or open a new issue if there is none that matches yet.
Hello, i can’t run onlyoffice app in 30 RC, is there any way to use it ?
Hi @Cem_S,
This thread is about the announcement of a new RC (Release Candidate)
Your question is about a third party app that does not (yet) support this not yet released Nextcloud version.
This is absolutely the wrong place for that.
As you may have seen already, there is an issue in the related tracker:
Please follow up there.
Much and good luck,
ernolf
