Please confirm which version of the desktop app your Windows machine is running. Should be a numerical value (3.4.0) under About.
General size is fine. You might have disabled certain sizes, or disabled folders in specific locations, from syncing. The person using the machine can also do this at anytime fyi.
You can check from the client machine Desktop app settings.
Confirm what is being synced on the Desktop Client
Nextcloud Desktop app should be visible in the toolbar on client machine.
Select settings from the toolbar > … menu > Choose What to Sync
or, click the drop down arrow left of each “Folder Sync Connection” to see what is being synced (checkmarked).
Example:
Work Photos
Consultations <— this means it is not being synced.
Asking for confirmation before synchronizing folders large than xxx MB
Nextcloud Desktop Settings
General
Ask for confirmation before synchronizing folders larger than [xxx] MB
Ask for confirmation before synchronizing external storages
General
If you still need help please fill out the support template you discarded when making this post. Thanks!
Thank you for your return, really, I confirm that we have deactivated the options for the synchronization of files greater than 500 MB and the option for external storage.
We have tested with the option that allows not to download files immediately and we no longer have any problem, the directories are correct, the download is only done when the file is opened.
Please fill out the linked support template above. Then go into as explicit detail as possible on what the unsolved problem is using logs and screenshots to explain. Thanks.
