On the last update it comes to me an error message and app on Win64 does not function yet.
I install the previous version, and it runs with no problems.
But appears everyday the reminder to update.
And if I update, it happens the same problem.
The proposed solution is “to simply uninstall Nextcloud and then reinstall it via the [latest] installer. Works without problems. Please download the installer from the website.”
I suppose the updater is doing something wrong. I cannot test this, since i don’t have Windows nor do i use the desktop client anyway.
