Problems installing recognize dependencies
    • 31.0.7snap1
    • Ubuntu 24.04.3 LTS
    • Included in the snap
    • Yes
    • A week or to since
    • Snap
I have been running Nextcloud on a Raspberry Pi, using Ubuntu 24.04. Nextcloud was installed using the snap, and have been updated multiple times. However it stopped wokring a couple of weeks ago. When trying to log into Ubuntu and running:
sudo nextcloud.occ maintenance:repair
things appear to be OK (i.e. text in green) except the following warnings that are printed in yellow:
Install recognize dependencies
  • WARNING: Failed to install node binary
  • WARNING: Failed to automatically install dependencies for recognize. Check the recognize admin panel for potential problems.
Steps to replicate it (hint: details matter!)
  1. Originally, the snap version was 31.0.8snap1. I reverted to a previous version using “sudo snap revert nextcloud”the problem stil remains.
Last two lines from log:Error
recognize
Exception
Failed to install Tensorflow.js: sh: 1: /var/snap/nextcloud/42232/nextcloud/extra-apps/recognize/bin/node: not found
11. sep. 2025, 16:44:59
Error
recognize
PASTE
PASTE HERE
sudo nextcloud.occ config:list
        "apps_paths": [
                "path": "\/snap\/nextcloud\/current\/htdocs\/apps",
                "url": "\/apps",
                "writable": false
                "path": "\/var\/snap\/nextcloud\/current\/nextcloud\/extra-apps",
                "url": "\/extra-apps",
                "writable": true
        "supportedDatabases": [
            "mysql"
        "redis": {
            "port": 0
        "log_type": "file",
        "logfile": "\/var\/snap\/nextcloud\/current\/logs\/nextcloud.log",
        "logfilemode": 416,
            "storhaug.dyndns.org"
        "dbtype": "mysql",
        "version": "31.0.7.1",
        "overwrite.cli.url": "https:\/\/storhaug.dyndns.org",
        "dbport": "",
        "mysql.utf8mb4": true,
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "loglevel": 2,
        "theme": "",
        "mail_smtpport": "587",
        "mail_smtpauth": 1,
        "default_phone_region": "NO"
    "apps": {
        "activity": {
            "enabled": "yes",
            "installed_version": "4.0.0",
            "types": "filesystem"
        "admin_audit": {
            "enabled": "yes",
            "installed_version": "1.21.0",
            "types": "logging"
        "app_api": {
            "enabled": "yes",
            "installed_version": "5.0.2",
            "types": ""
        "backgroundjob": {
            "lastjob": "27"
        "bruteforcesettings": {
            "enabled": "yes",
            "types": ""
        "calendar": {
            "enabled": "yes",
            "installed_version": "5.5.3",
            "types": ""
        "circles": {
            "enabled": "yes",
            "installed_version": "31.0.0",
            "loopback_tmp_scheme": "https",
            "maintenance_run": "0",
            "maintenance_update": "{\"3\":1757601106,\"2\":1757602784,\"1\":1757602784}",
            "migration_22": "1",
            "migration_run": "0",
            "types": "filesystem,dav"
        "cloud_federation_api": {
            "enabled": "yes",
            "installed_version": "1.14.0",
        "comments": {
            "enabled": "yes",
            "types": "logging"
        "contacts": {
            "enabled": "yes",
            "installed_version": "7.3.0",
            "types": "dav"
        "contactsinteraction": {
            "enabled": "yes",
            "installed_version": "1.12.0",
            "types": "dav"
        "core": {
            "backgroundjobs_mode": "cron",
            "emailTestSuccessful": "0",
            "files_metadata_installed": "1",
            "installedat": "1678793548.5301",
            "lastcron": 1757602785,
            "lastupdatedat": "0",
            "metadataGenerationDone": true,
            "moveavatarsdone": "yes",
            "previewsCleanedUp": "1",
            "public_files": "files_sharing\/public.php",
            "public_webdav": "dav\/appinfo\/v1\/publicwebdav.php",
            "vendor": "nextcloud",
            "files_metadata": {
                "photos-original_date_time": {
                    "value": null,
                    "type": "int",
                    "etag": "",
                    "indexed": true,
                    "editPermission": 0
                "photos-size": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-exif": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-ifd0": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-gps": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-place": {
                    "value": null,
                    "type": "string",
                    "etag": "",
                    "indexed": true,
                    "editPermission": 0
                "blurhash": {
                    "value": null,
                    "type": "string",
                    "etag": "00297c963cac559f71ef858cf23dfb85",
                    "indexed": false,
                    "editPermission": 0
            "oc.integritycheck.checker": []
        "dashboard": {
            "enabled": "yes",
            "installed_version": "7.11.0",
            "types": ""
        "dav": {
            "buildCalendarReminderIndex": "yes",
            "buildCalendarSearchIndex": "yes",
            "builtSocialSearchIndex": "yes",
            "chunks_migrated": "1",
            "enabled": "yes",
            "installed_version": "1.33.0",
            "regeneratedBirthdayCalendarsForYearFix": "yes",
        "drawio": {
            "enabled": "yes",
            "installed_version": "3.1.0",
        "federatedfilesharing": {
            "enabled": "yes",
            "types": ""
        "federation": {
            "enabled": "yes",
            "types": "authentication"
        "files": {
            "enabled": "yes",
            "installed_version": "2.3.1",
            "mimetype_version": "31.0.7.1",
        "files_downloadlimit": {
            "enabled": "yes",
            "types": ""
        "files_pdfviewer": {
            "enabled": "yes",
            "types": ""
        "files_reminders": {
            "enabled": "yes",
            "installed_version": "1.4.0",
            "types": ""
        "files_rightclick": {
            "enabled": "no",
            "installed_version": "1.6.0",
            "types": ""
        "files_sharing": {
            "enabled": "yes",
            "installed_version": "1.23.1",
        "files_trashbin": {
            "enabled": "yes",
        "files_versions": {
            "enabled": "yes",
            "installed_version": "1.24.0",
        "firstrunwizard": {
            "enabled": "yes",
            "types": ""
        "logreader": {
            "enabled": "yes",
            "types": "logging"
        "lookup_server_connector": {
            "enabled": "yes",
            "installed_version": "1.19.0",
        "mail": {
            "enabled": "yes",
            "installed_version": "5.4.0",
            "types": ""
        "nextcloud_announcements": {
            "enabled": "yes",
            "installed_version": "3.0.0",
            "pub_date": "Thu, 24 Oct 2019 00:00:00 +0200",
            "types": "logging"
        "notes": {
            "enabled": "yes",
            "installed_version": "4.12.3",
            "types": ""
        "notifications": {
            "enabled": "yes",
            "types": "logging"
        "oauth2": {
            "enabled": "yes",
            "installed_version": "1.19.1",
        "password_policy": {
            "enabled": "yes",
        "photos": {
            "enabled": "yes",
            "lastPlaceMappedUser": "gas",
            "lastPlaceMappingDone": "true",
            "types": "dav,authentication"
        "privacy": {
            "enabled": "yes",
            "types": ""
        "profile": {
            "enabled": "yes",
            "installed_version": "1.0.0",
            "types": ""
        "provisioning_api": {
            "enabled": "yes",
            "types": "prevent_group_restriction"
        "recognize": {
            "enabled": "yes",
            "installed_version": "9.0.7",
            "nice_binary": "\/usr\/bin\/nice",
            "node_binary": "\/var\/snap\/nextcloud\/42232\/nextcloud\/extra-apps\/recognize\/bin\/node",
            "tensorflow.purejs": "true",
        "recommendations": {
            "enabled": "yes",
            "types": ""
        "related_resources": {
            "enabled": "yes",
            "installed_version": "2.0.0",
            "types": ""
        "richdocuments": {
            "enabled": "yes",
            "installed_version": "8.7.4",
            "types": "filesystem,prevent_group_restriction"
        "serverinfo": {
            "cached_count_appdata_files": 594647,
            "cached_count_filecache": 937619,
            "cached_count_storages": "2",
            "enabled": "yes",
            "size_appdata_storage": 151925657,
            "types": ""
        "settings": {
            "enabled": "yes",
            "types": ""
        "sharebymail": {
            "enabled": "yes",
        "spreed": {
            "enabled": "yes",
            "has_reference_id": "yes",
            "installed_version": "21.1.4",
            "project_access_invalidated": "1",
            "signaling_ticket_secret": "***REMOVED SENSITIVE VALUE***",
            "signaling_token_privkey_es256": "***REMOVED SENSITIVE VALUE***",
            "signaling_token_pubkey_es256": "***REMOVED SENSITIVE VALUE***",
            "types": "dav,prevent_group_restriction"
        "support": {
            "SwitchUpdaterServerHasRun": "yes",
            "enabled": "yes",
            "types": "session"
        "survey_client": {
            "enabled": "yes",
            "last_report": "{\"id\":\"ochpakwd3ipc\",\"items\":[[\"server\",\"version\",\"31.0.7.1\"],[\"server\",\"code\",\"other\"],[\"server\",\"enable_avatars\",\"yes\"],[\"server\",\"enable_previews\",\"yes\"],[\"server\",\"memcache.local\",\"\\\\OC\\\\Memcache\\\\Redis\"],[\"server\",\"memcache.distributed\",\"none\"],[\"server\",\"asset-pipeline.enabled\",\"no\"],[\"server\",\"filelocking.enabled\",\"yes\"],[\"server\",\"memcache.locking\",\"\\\\OC\\\\Memcache\\\\Redis\"],[\"server\",\"debug\",\"no\"],[\"server\",\"cron\",\"cron\"],[\"php\",\"version\",\"8.3.23\"],[\"php\",\"memory_limit\",536870912],[\"php\",\"max_execution_time\",0],[\"php\",\"upload_max_filesize\",2097152],[\"database\",\"type\",\"mysql\"],[\"database\",\"version\",\"8.0.42\"],[\"database\",\"size\",993705984],[\"apps\",\"activity\",\"4.0.0\"],[\"apps\",\"admin_audit\",\"1.21.0\"],[\"apps\",\"app_api\",\"5.0.2\"],[\"apps\",\"bruteforcesettings\",\"4.0.0\"],[\"apps\",\"calendar\",\"5.5.3\"],[\"apps\",\"circles\",\"31.0.0\"],[\"apps\",\"cloud_federation_api\",\"1.14.0\"],[\"apps\",\"comments\",\"1.21.0\"],[\"apps\",\"contacts\",\"7.2.5\"],[\"apps\",\"contactsinteraction\",\"1.12.0\"],[\"apps\",\"dashboard\",\"7.11.0\"],[\"apps\",\"dav\",\"1.33.0\"],[\"apps\",\"drawio\",\"3.1.0\"],[\"apps\",\"federatedfilesharing\",\"1.21.0\"],[\"apps\",\"federation\",\"1.21.0\"],[\"apps\",\"files\",\"2.3.1\"],[\"apps\",\"files_downloadlimit\",\"4.0.0\"],[\"apps\",\"files_pdfviewer\",\"4.0.0\"],[\"apps\",\"files_reminders\",\"1.4.0\"],[\"apps\",\"files_rightclick\",\"disabled\"],[\"apps\",\"files_sharing\",\"1.23.1\"],[\"apps\",\"files_trashbin\",\"1.21.0\"],[\"apps\",\"files_versions\",\"1.24.0\"],[\"apps\",\"firstrunwizard\",\"4.0.0\"],[\"apps\",\"logreader\",\"4.0.0\"],[\"apps\",\"lookup_server_connector\",\"1.19.0\"],[\"apps\",\"mail\",\"5.4.0\"],[\"apps\",\"nextcloud_announcements\",\"3.0.0\"],[\"apps\",\"notes\",\"4.12.3\"],[\"apps\",\"notifications\",\"4.0.0\"],[\"apps\",\"oauth2\",\"1.19.1\"],[\"apps\",\"password_policy\",\"3.0.0\"],[\"apps\",\"photos\",\"4.0.0\"],[\"apps\",\"privacy\",\"3.0.0\"],[\"apps\",\"profile\",\"1.0.0\"],[\"apps\",\"provisioning_api\",\"1.21.0\"],[\"apps\",\"recognize\",\"9.0.3\"],[\"apps\",\"recommendations\",\"4.0.0\"],[\"apps\",\"related_resources\",\"2.0.0\"],[\"apps\",\"richdocuments\",\"8.7.4\"],[\"apps\",\"serverinfo\",\"3.0.0\"],[\"apps\",\"settings\",\"1.14.0\"],[\"apps\",\"sharebymail\",\"1.21.0\"],[\"apps\",\"spreed\",\"21.1.4\"],[\"apps\",\"support\",\"3.0.0\"],[\"apps\",\"survey_client\",\"3.0.0\"],[\"apps\",\"suspicious_login\",\"9.0.1\"],[\"apps\",\"systemtags\",\"1.21.1\"],[\"apps\",\"text\",\"5.0.0\"],[\"apps\",\"theming\",\"2.6.1\"],[\"apps\",\"twofactor_backupcodes\",\"1.20.0\"],[\"apps\",\"user_status\",\"1.11.0\"],[\"apps\",\"viewer\",\"4.0.0\"],[\"apps\",\"weather_status\",\"1.11.0\"],[\"apps\",\"webhook_listeners\",\"1.2.0\"],[\"apps\",\"workflowengine\",\"2.13.0\"],[\"stats\",\"num_files\",937627],[\"stats\",\"num_users\",1],[\"stats\",\"num_storages\",2],[\"stats\",\"num_storages_local\",1],[\"stats\",\"num_storages_home\",1],[\"stats\",\"num_storages_other\",0],[\"stats\",\"num_comments\",80],[\"stats\",\"num_comment_markers\",0],[\"stats\",\"num_systemtags\",0],[\"stats\",\"num_systemtags_mappings\",0],[\"files_sharing\",\"num_shares\",83],[\"files_sharing\",\"num_shares_user\",0],[\"files_sharing\",\"num_shares_groups\",0],[\"files_sharing\",\"num_shares_link\",83],[\"files_sharing\",\"num_shares_link_no_password\",83],[\"files_sharing\",\"num_fed_shares_sent\",0],[\"files_sharing\",\"num_fed_shares_received\",0],[\"files_sharing\",\"permissions_3_17\",83],[\"encryption\",\"enabled\",\"no\"],[\"encryption\",\"default_module\",\"no\"]]}",
            "last_sent": "1757601257",
            "types": ""
        "suspicious_login": {
            "enabled": "yes",
            "installed_version": "9.0.1",
        "systemtags": {
            "enabled": "yes",
            "installed_version": "1.21.1",
            "types": "logging"
        "text": {
            "enabled": "yes",
            "installed_version": "5.0.0",
            "types": "dav"
        "theming": {
            "enabled": "yes",
            "installed_version": "2.6.1",
            "types": "logging"
        "twofactor_backupcodes": {
            "enabled": "yes",
            "installed_version": "1.20.0",
            "types": ""
        "user_status": {
            "enabled": "yes",
            "installed_version": "1.11.0",
            "types": ""
        "viewer": {
            "enabled": "yes",
            "types": ""
        "weather_status": {
            "enabled": "yes",
            "types": ""
        "webhook_listeners": {
            "enabled": "yes",
            "installed_version": "1.2.0",
        "workflowengine": {
            "enabled": "yes",
            "installed_version": "2.13.0",
Hey @GeirS, welcome to the Nextcloud community and thanks for supporting Nextcloud snap :handshake:
Sorry to hear you’re having issues with your Nextcloud snap automatic update. The following steps will get you up and running again… but you’ll need to discover some log reference to resolve the cause of the failed automatic update.
1. Check your logs to discover the cause of the update failure
2. Revert to last known good revision
Snaps were designed to have a robust upgrade story. In the case of the Nextcloud snap, every time it refreshes (updates), it takes a snapshot of the database and other version-specific things (not the raw data though, e.g. pictures and documents) and holds them alongside the old revision of the snap.
With that command, you should be back up and running right at the moment before the automatic update happened.
see How to revert Nextcloud snap after failed update
Backup your running snap now!
This would be the perfect occasion to create a complete Nextcloud snap backup including configuration, apps, certificates, database and data.
  • stop Nextcloud snap sudo snap stop nextcloud
  • save Nextcloud snap sudo snap save nextcloud
  • start Nextcloud snap sudo snap start nextcloud
  • copy/move snapshot (*.zip) in /var/lib/snapd/snapshots to wherever
see How to backup, restore and migrate Nextcloud snap
3. Resolve automatic update issues
A prevalent cause of automatic update issues is attributed to incompatible third party apps due to snap confinement. Any apps requiring access to executable binaries will fail since these are not included in the snap. Disabling the misbehaving apps frequently resolves the automatic update issue. Sometimes apps can be re-installed or re-enabled after successful manual refresh (update)… but may recur during the next automatic update.
If your Nextcloud interface is not available or your Nextcloud is in “Maintenance mode”, you can disable apps using the OCC management console or command line:
  1. List apps: sudo nextcloud.occ app:list
  2. Disable app: sudo nextcloud.occ app:disable <appname>
    • Remove app: sudo nextcloud.occ app:remove <appname>
  3. Enable app: sudo nextcloud.occ app:enable <appname>
see How to manage automatic updates in Nextcloud snap
4. Manually update = refresh Nextcloud snap
sudo snap refresh nextcloud
see How to manage Nextcloud snap with snap
In your specific case you’ll need to remove recognize see FAQ's · nextcloud-snap/nextcloud-snap Wiki · GitHub
Nextcloud snap - remove incompatible Recognize app
NOTE
Recognize app path to node.js is reset by the app after an Nextcloud snap update. The admin would need to configure the path to be /var/snap/nextcloud/current/nextcloud/extra-apps/recognize/bin/node.
TIP
uninstall Recognize app before an update and reinstall after update – if the Snap will not start after update, revert and remove Recognize, then update manually and reinstall Recognize
IMPORTANT
Latest Recognize versions, when in WASM mode, require Node.js 20, which in turn requires a version of glibc >= 2.28 (more context here). The nextcloud snap is still using glibc 2.27 (from core18) due to Snap confinement, so Recognize’s WASM mode won’t work with the snap till this issue is solved.
sudo nextcloud.occ app:disable recognize
Fantastic quick and to the point response - thank you very, very much!
Looks like disabling recognize get me up and running again. Will review the information you provided in more detail when I have more time during the weekend.
Again, thank you!
