Good morning,
we tested nextcloud files for its file management section and especially version management. Our business uses tools like Creative Cloud a lot, and I’m encountering a problem. in fact, the indesign suite does not modify the files but replaces the files each time they save. As it is a new file, there is no history. How to get around this problem? Thanks for your help
hi @Didier_Bataillard welcome to the forum ![]()
I would expect such behavior to create new file version… but it depends on how the do it exactly… e.g. if the application first deletes the original file and creates a new one the could be no version… but simple replace/overwrite should create one…
as you didn’t follow required support template we can’t help you now. Please fill this form out and edit into your post.
