in a fairly recent installation I have a problem with recovering deleted files.
All users correctly access the section, only one user cannot access the deleted files the message is: “The directory is unavailable, please check the logs or contact the administrator”.
What may have happened?
Thank you very much in advance
We also have a template (should show up when you open a new topic) that helps you to add all important information. We don’t know the logs, we don’t know the NC version you are using, nothing about your configuration…
Nextcloud version: 17.0.1
Operating system and version: DietPi (raspian lite) on Raspberry pi4 4GB last version
Apache version: 2.4.41
PHP version: 7.3.11
In my installation I have a problem with recovering deleted files.
