nemo87
August 9, 2025, 2:59pm
1
Raspberry Pi 5 with 8 GB RAM;
RaspberryPi OS (bookworm);
PHP 8.4.11;
Apache 2 installed;
NextCloud is version 31.0.5.
I get this error message:
Your web server is not properly set up to resolve .well-known URLs, failed on: /.well-known/webfinger
Following the guide, I tried to insert the indicated lines into the .htaccess file but I still get the same error, could you help me?
Did you restart Apache to re-read the new settings in .htaccess?
nemo87
August 9, 2025, 5:09pm
3
I rebooted my machine, how do I restart the service?
If you did reboot, the service itself was restarted.
Restart the Apache service may be depend on the OS f.ex.
service apache2 restart
but I do not know, whether it also will work in your OS. Maybe then man pages might help.
nemo87
August 9, 2025, 6:56pm
5
whether restarting the entire system or just restarting the service, I still get the error
I’m using RaspberryPi OS (bookworm)
What exactly did you type in. Please post the content on .htaccess.
nemo87
August 9, 2025, 8:54pm
7
The file is located in: /var/www/nextcloud/
<IfModule mod_headers.c>
<IfModule mod_setenvif.c>
<IfModule mod_fcgid.c>
SetEnvIfNoCase ^Authorization$ "(.+)" XAUTHORIZATION=$1
RequestHeader set XAuthorization %{XAUTHORIZATION}e env=XAUTHORIZATION
</IfModule>
<IfModule mod_proxy_fcgi.c>
SetEnvIfNoCase Authorization "(.+)" HTTP_AUTHORIZATION=$1
</IfModule>
<IfModule mod_lsapi.c>
</IfModule>
</IfModule>
<IfModule mod_env.c>
# Add security and privacy related headers
# Avoid doubled headers by unsetting headers in "onsuccess" table,
# then add headers to "always" table: https://github.com/nextcloud/server/pull/19002
<If "%{REQUEST_URI} =~ m#/login$#">
# Only on the login page we need any Origin or Referer header set.
Header onsuccess unset Referrer-Policy
Header always set Referrer-Policy "same-origin"
</If>
<Else>
Header always set Referrer-Policy "no-referrer"
</Else>
Header onsuccess unset X-Content-Type-Options
Header always set X-Content-Type-Options "nosniff"
Header onsuccess unset X-Frame-Options
Header always set X-Frame-Options "SAMEORIGIN"
Header onsuccess unset X-Permitted-Cross-Domain-Policies
Header always set X-Permitted-Cross-Domain-Policies "none"
Header onsuccess unset X-Robots-Tag
Header always set X-Robots-Tag "noindex, nofollow"
Header onsuccess unset X-XSS-Protection
Header always set X-XSS-Protection "1; mode=block"
SetEnv modHeadersAvailable true
</IfModule>
# Add cache control for static resources
<FilesMatch "\.(css|js|mjs|svg|gif|png|jpg|webp|ico|wasm|tflite)$">
<If "%{QUERY_STRING} =~ /(^|&)v=/">
Header set Cache-Control "max-age=15778463, immutable"
</If>
<Else>
Header set Cache-Control "max-age=15778463"
</Else>
</FilesMatch>
# Let browsers cache OTF and WOFF files for a week
<FilesMatch "\.(otf|woff2?)$">
Header set Cache-Control "max-age=604800"
</FilesMatch>
</IfModule>
<IfModule mod_php.c>
php_value mbstring.func_overload 0
php_value default_charset 'UTF-8'
php_value output_buffering 0
SetEnv htaccessWorking true
</IfModule>
</IfModule>
<IfModule mod_mime.c>
AddType image/svg+xml svg svgz
AddType application/wasm wasm
AddEncoding gzip svgz
# Serve ESM javascript files (.mjs) with correct mime type
AddType text/javascript js mjs
</IfModule>
<IfModule mod_dir.c>
DirectoryIndex index.php index.html
</IfModule>
<IfModule pagespeed_module>
ModPagespeed Off
</IfModule>
<IfModule mod_rewrite.c>
RewriteEngine on
RewriteCond %{HTTP_USER_AGENT} DavClnt
RewriteRule ^$ /remote.php/webdav/ [L,R=302]
RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^\.well-known/carddav /remote.php/dav/ [R=301,L]
RewriteRule ^\.well-known/caldav /remote.php/dav/ [R=301,L]
RewriteRule ^remote/(.*) remote.php [QSA,L]
RewriteRule ^(?:build|tests|config|lib|3rdparty|templates)/.* - [R=404,L]
RewriteRule ^\.well-known/(?!acme-challenge|pki-validation) /index.php [QSA,L]
RewriteRule ^ocm-provider/?$ index.php [QSA,L]
RewriteRule ^(?:\.(?!well-known)|autotest|occ|issue|indie|db_|console).* - [R=404,L]
</IfModule>
# Clients like xDavv5 on Android, or Cyberduck, use chunked requests.
# When FastCGI or FPM is used with apache, requests arrive to Nextcloud without any content.
# This leads to the creation of empty files.
# The following directive will force the problematic requests to be buffered before being forwarded to Nextcloud.
# This way, the "Transfer-Encoding" header is removed, the "Content-Length" header is set, and the request content is proxied to Nextcloud.
# Here are more information about the issue:
# - https://docs.cyberduck.io/mountainduck/issues/fastcgi/
# - https://docs.nextcloud.com/server/latest/admin_manual/issues/general_troubleshooting.html#troubleshooting-webdav
SetEnvIfNoCase Transfer-Encoding "chunked" proxy-sendcl=1
</IfModule>
# Apache disabled the sending of the server-side content-length header
# in their 2.4.59 patch updated which breaks some use-cases in Nextcloud.
# Setting ap_trust_cgilike_cl allows to bring back the usual behaviour.
# See https://bz.apache.org/bugzilla/show_bug.cgi?id=68973
SetEnv ap_trust_cgilike_cl
</IfModule>
Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains"
</IfModule>
RewriteEngine on
</IfModule>
AddDefaultCharset utf-8
Options -Indexes
RewriteEngine on
RewriteRule ^\.well-known/carddav /nextcloud/remote.php/dav [R=301,L]
RewriteRule ^\.well-known/caldav /nextcloud/remote.php/dav [R=301,L]
RewriteRule ^\.well-known/webfinger /nextcloud/index.php/.well-known/webfinger [R=301,L]
RewriteRule ^\.well-known/nodeinfo /nextcloud/index.php/.well-known/nodeinfo [R=301,L]
</IfModule>
#### DO NOT CHANGE ANYTHING ABOVE THIS LINE ####
ErrorDocument 403 /nextcloud/index.php/error/403
ErrorDocument 404 /nextcloud/index.php/error/404
Ich weiß jetzt nicht, ob eine “Lösung” tatsächlich gefunden wurde, finde keinen Hinweis darauf.
Was mir an der .htaccess aufgefallen war, ist, dass die well-known - Einträge mal mit und mal ohne “/” nach “/nextcloud/remote.php/dav” enden.
und
Abgesehen davon steht einmal
/remote.php/dav/
und einmal
“/nextcloud” als Unterschied
Einer davon dürfte auch hier falsch sein.
nemo87
August 10, 2025, 11:53am
9
nemo87:
RewriteEngine on
</IfModule>
If you are referring to these entries, I copied them from the guide
Then please check the difference between the entries in the guide and the settings on your PI
nemo87
August 10, 2025, 12:21pm
11
Maybe I’m not clear on what you mean…
The file I posted was automatically generated. I then inserted the lines (as suggested in the guide). What should I compare it to?
I found this topic:
I know this has been asked many times. I’ve read through many different threads, and still haven’t figured this out.
The warning I get in the NC admin panel:
Your web server is not properly set up to resolve “/.well-known/caldav”. Further information can be found in the documentation .
Your web server is not properly set up to resolve “/.well-known/carddav”. Further information can be found in the documentation .
This is a new install:
nextcloud 27.0…
proposes to solve the problem by creating another file
There are different entries of “well-known ..caldav” and “well-known…carddav” in your posted .htaccess, see my posting above, where I mentioned the differences.
The main difference is, that some redirects contain “/nextcloud” and some other not.
nemo87
August 10, 2025, 4:14pm
13
Okay, so my file probably has these errors…
What do I compare it to?
And how do I fix them?
