System Specifics:
Nextcouud Version 33.0.0 Version 2.3.4
Operating system and version running on Trunas Scale
PostgreSQL DB
Dear all,
Im facting a problem installing Nextcloud on Trunas. At the initial startup, I do run into a problem (potentially with authorisations on the PostgreSQL DB)
Installation scrip was running with no problems - but it seams on the first startup on the UI dialog the initialisation on the PostgeSQL DB is failing
Has anyone run into this problem and found a solution for this problem?
