Your network address has been identified as “192.168.1.254” and it is bridled by the anti-intrusion mechanism which slows the performance of certain requests. If this network address is not yours, this may mean that there is a proxy configuration error. For more information, see [Documentation
] (https://docs.nextcloud.com/server/30/go.php?to=admin-reverse-proxy).
Hi @Dev314r, welcome to Nextcloud community ![]()
Unfortunately a lot of information to help you is missing as you ignored the required support template. Please edit into your post and add as many information as possible. This will give us the technical info and logs needed to help you!
The problem sounds like often discussed misconfiguration related to reverseproxy and bruteforce protection. Make sure your reverse proxy settings are valid and the reverse proxy sends right headers. review 101: reverse proxy
It’s good I found it, I just had to add to my router the local address of my NextCloud as DNS, even if I notice that I have always slowed down and that DNSMASQ even “activate” does not seem “Activate” and that my router does not have a nat loop.
+ (6 domain name server, 192.168.1. 159)
Thank you anyway for your responsiveness👍
