OnlyOffice NAT Problem
I configured a new virtual machine with OnlyOffice only (nginx), configured the SSL certificate and activated HTTPS.
When I try to connect NextCloud to OnlyOffice with https://onlyoffice.xxxxx.com it works correctly.
After, I created a NAT rule on our firewall to forward traffic from pubblic IP:29443 to internal IP:443 and reconfigured NextCloud to access https://onlyoffice.com.xxxxx.com:29443
But I get the error:
[onlyoffice] Error: HealthcheckRequest on check error: cURL error 28: Connection timed out after 60001 milliseconds (see libcurl - Error Codes)
PUT /nextcloud/index.php/apps/onlyoffice/ajax/settings/address
from xx.xx.xx.xx by admin at 2020-02-03T08: 22: 11 + 00: 00
NAT seems to work: if I browse the page https://onlyoffice.com.xxxxx.com:29443 I am redirected to https://onlyoffice.xxxxx.com:29443/welcome/
Do you have any advice?
NextCloud version: 18.0.0
OnlyOffice version: 4.1.4
check this maybe help if it’s nextcloud issue
thanks zerone,
but the problem has not changed
hope this help:
Best Regards
