Hi
I just wander if somebody could help me or at least confirm if the notify for SMB is or is not compatible with SMB2.
Steps to reproduce
- Add external shared folder sitting on the Windows Server 2012 with SMB1 enabled for AD users in Nextcloud - added successfully and users have access to the folder. Run “sudo -u www-data php /var/www/nextcloud/occ files_external:notify -u domin/user -p password” and the notify is working fine.
- Disable SMB2 on the windows server, add “client min protocol = SMB2” and “client max protocol = SMB3” to smb.conf and Nextcloud users have access to the shared folder
- run sudo -u www-data php /var/www/nextcloud/occ files_external:notify -u domin/user -p password
Expected behaviour
sudo -u www-data php /var/www/nextcloud/occ files_external:notify -u domin/user -p password will work
Actual behaviour
Error message:
[Icewind\SMB\Exception\RevisionMismatchException]
Notify is not supported with the used smb version
Server configuration
Operating system :
Ubunu 16.04
Web server:
Apache 2
Database:
MySQL
PHP version:
7.0.30
Nextcloud version: (see Nextcloud admin page)
13.0.4
Updated from an older Nextcloud/ownCloud or fresh install:
updated from 13.0.0 Beta
Where did you install Nextcloud from:
https://download.nextcloud.com
