after update i get error internal server error
what happen?
Internal Server Error
The server was unable to complete your request.
If this happens again, please send the technical details below to the server administrator.
Technical details
Remote Address: 162.158.167.39
Request ID: W8sy55o5SY-EXJ8AFRwkUwAAAAU
Type: OCP\Files\NotPermittedException
Code: 0
Message: No create permission for path
File: /home/cloud/public_html/lib/private/Files/Node/Folder.php
Line: 187
Trace
#0 /home/cloud/public_html/lib/private/Files/SimpleFS/SimpleFolder.php(83): OC\Files\Node\Folder->newFile(‘b492-3196-jquer…’)
#1 /home/cloud/public_html/lib/private/Template/SCSSCacher.php(273): OC\Files\SimpleFS\SimpleFolder->newFile(‘b492-3196-jquer…’)
#2 /home/cloud/public_html/lib/private/Template/SCSSCacher.php(153): OC\Template\SCSSCacher->cache(‘/home/cloud/pub…’, ‘b492-3196-jquer…’, ‘jquery-ui-fixes…’, Object(OC\Files\SimpleFS\SimpleFolder), ‘/core/css’)
#3 /home/cloud/public_html/lib/private/Template/CSSResourceLocator.php(109): OC\Template\SCSSCacher->process(‘/home/cloud/pub…’, ‘core/css/jquery…’, ‘core’)
#4 /home/cloud/public_html/lib/private/Template/CSSResourceLocator.php(61): OC\Template\CSSResourceLocator->cacheAndAppendScssIfExist(‘/home/cloud/pub…’, ‘core/css/jquery…’)
#5 /home/cloud/public_html/lib/private/Template/ResourceLocator.php(78): OC\Template\CSSResourceLocator->doFind(‘css/jquery-ui-f…’)
#6 /home/cloud/public_html/lib/private/TemplateLayout.php(285): OC\Template\ResourceLocator->find(Array)
#7 /home/cloud/public_html/lib/private/TemplateLayout.php(201): OC\TemplateLayout::findStylesheetFiles(Array)
#8 /home/cloud/public_html/lib/private/legacy/template.php(211): OC\TemplateLayout->__construct(‘user’, ‘files’)
#9 /home/cloud/public_html/lib/public/AppFramework/Http/TemplateResponse.php(157): OC_Template->fetchPage(Array)
#10 /home/cloud/public_html/lib/private/AppFramework/Http/Dispatcher.php(119): OCP\AppFramework\Http\TemplateResponse->render()
#11 /home/cloud/public_html/lib/private/AppFramework/App.php(118): OC\AppFramework\Http\Dispatcher->dispatch(Object(OCA\Files\Controller\ViewController), ‘index’)
#12 /home/cloud/public_html/lib/private/AppFramework/Routing/RouteActionHandler.php(47): OC\AppFramework\App::main(‘ViewController’, ‘index’, Object(OC\AppFramework\DependencyInjection\DIContainer), Array)
#13 [internal function]: OC\AppFramework\Routing\RouteActionHandler->__invoke(Array)
#14 /home/cloud/public_html/lib/private/Route/Router.php(297): call_user_func(Object(OC\AppFramework\Routing\RouteActionHandler), Array)
#15 /home/cloud/public_html/lib/base.php(987): OC\Route\Router->match(‘/apps/files/’)
#16 /home/cloud/public_html/index.php(42): OC::handleRequest()
#17 {main}
