Edit2: For sure you need these informations. Iam really sorry! So here it is:
Nextcloud version (eg, 20.0.5): 25.0.6snap1
Operating system and version (eg, Ubuntu 20.04): Ubuntu 22.04.2 LTS (GNU/Linux 5.4.241-417 armv7l)
Apache or nginx version (eg, Apache 2.4.25): cant find apache or nginx (tried with apache2 -v and nginx -v, but its said command not fund) is it maybe not on the system anymore?
PHP version (eg, 7.4): PHP 8.1.2-1ubuntu2.11
Steps to replicate it: its allways there
its empty
'apps_paths' =>
0 =>
'path' => '/snap/nextcloud/current/htdocs/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/var/snap/nextcloud/current/nextcloud/extra-apps',
'url' => '/extra-apps',
'writable' => true,
'supportedDatabases' =>
0 => 'mysql',
'redis' =>
'host' => '/tmp/sockets/redis.sock',
'port' => 0,
'log_type' => 'file',
'logfile' => '/var/snap/nextcloud/current/logs/nextcloud.log',
'logfilemode' => 416,
'instanceid' => 'ocdsjpu3e4rr',
'passwordsalt' => 'bvqJU2X+L7lrpkqdGW+rzKQVxfCV5H',
'secret' => 'OQYUC7A2YBcPvNA1xF4dA8VngVHVf2N/REr4G+jq0X1Hc0kV',
0 => 'xxxxx',
1 => 'xxx',
'datadirectory' => '/media/nextcloud/data',
'version' => '25.0.5.1',
'overwrite.cli.url' => 'http://192.168.0.5',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:/tmp/sockets/mysql.sock',
'dbuser' => 'nextcloud',
'dbpassword' => '8oIqBU6ry13NvP093mLQSpnH4tKXelwQXEmia7CGxCgLlexAAYEBNgkhnR7ae6C5',
'loglevel' => 2,
2023-04-27T17:49:40Z nextcloud.apache[11812]: error: cannot communicate with server: Post http://localhost/v2/snapctl: EOF
2023-04-27T17:49:40Z nextcloud.apache[11818]: error: cannot communicate with server: Post http://localhost/v2/snapctl: EOF
2023-04-27T17:49:40Z nextcloud.apache[11824]: AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1. Set the 'ServerName' directive globally to suppress this message
2023-04-27T17:49:40Z nextcloud.apache[11824]: httpd (no pid file) not running
2023-04-27T17:49:40Z systemd[1]: snap.nextcloud.apache.service: Deactivated successfully.
2023-04-27T17:49:40Z systemd[1]: Stopped Service for snap application nextcloud.apache.
2023-04-27T17:49:40Z systemd[1]: snap.nextcloud.apache.service: Consumed 2.504s CPU time.
2023-04-27T17:50:08Z systemd[1]: Started Service for snap application nextcloud.apache.
2023-04-27T17:50:13Z nextcloud.apache[529]: Making sure nextcloud is setup...
2023-04-27T17:50:14Z nextcloud.apache[991]: Waiting for PHP...
PASTE HERE
PASTE HERE
