- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
Nextcloud Server version (e.g., 29.x.x):
33.0.6.2 -
Operating system and version (e.g., Ubuntu 24.04):
Armbian 26.5.1 trixie. 6.6.63-current-bcm2712 (aarch64) -
Web server and version (e.g, Apache 2.4.25):
- Apache/2.4.67 (Debian)
Reverse proxy and version _(e.g. nginx 1.27.2)
replace me
PHP version (e.g, 8.3):
- 8.3.32
Is this the first time you’ve seen this error? (Yes / No):
Yes
When did this problem seem to first start?
Today: after running ncp-dist-upgrade
Installation method (e.g. AlO, NCP, Bare Metal/Archive, etc.)
NCP
Are you using CloudfIare, mod_security, or similar? (Yes / No)
replace me
Mac desktop client suggested to run ncp-dist-upgrade. The cli also suggested this. So I did this at the cli:
sudo ncp-dist-upgrade
there were dpkg errors in the upgrade. I didn’t write them down when the upgrade was running. I can ssh into the system. The system panel is accessible from my Mac. System Info says all the usual services are up. From the system panel, if I try to “Launch Nextcloud”, the browser reports that the local IP address “is currently unable to handle this request”. The Nextcloud web app doesn’t run (same error). The clients do not connect to the server.
sudo apt --fix-broken install
also gives dpkg errors:
Preparing to unpack …/raspi-firmware_1%3a1.20250915-1~bookworm_all.deb …
Unpacking raspi-firmware (1:1.20250915-1~bookworm) …
dpkg: error processing archive /var/cache/apt/archives/raspi-firmware_1%3a1.20250915-1~bookworm_all.deb (–unpack):
trying to overwrite ‘/etc/kernel/postinst.d/z50-raspi-firmware’, which is also in package armbian-bsp-cli-rpi5b-current (24.11.1)
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
PASTE HERE
PASTE
PASTE HERE
PASTE HERE
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
