NextcloudPi: Documentation site is not working?
https://docs.nextcloudpi.com/
The above site is not showing any info at all? Do you know that? I was going to try to install it and use the guides you had earlier.
This is how it looks like both in Chrome and Edge:
NCP docs have been moved into this forum About the NextcloudPi Documentation category
I’m not sure the old site is expected work.
All NextcloudPi Documentation contributed on this forum are automatically available at:
looks there is some issue.
I added ncp tag - likely somebody from NextcloudPi team will take look on this.
