I have Nextcloud installed using docker-compose. Due to issues uploading a huge folder (560Gb). I had to restart the docker compose set up, I saw that the Nextcloud container was recreated/updated.
After this Nextcloud refuses to start, web says “Internal server error”. Webtools says it cant load favicon. Well the container starts without issues. The ssl-certificate is loaded like it should.
nextcloud:
image: lscr.io/linuxserver/nextcloud:latest
container_name: nextcloud
environment:
- PUID=1000
- PGID=1000
- TZ=${TZ}
- MYSQL_DATABASE=${MYSQL_DB}
- MYSQL_USER=${MYSQL_USER}
- MYSQL_PASSWORD=${MYSQL_PW}
- MYSQL_HOST=${MYSQL_HOST}
- MYSQL_PORT=${MYSQL_PORT}
- NEXTCLOUD_ADMIN_USER=${NEXTCLOUD_ADMIN}
- NEXTCLOUD_ADMIN_PASSWORD=${NEXTCLOUD_ADMIN_PW}
- REDIS_HOST=${REDIS_HOST}
- REDIS_PORT=${REDIS_PORT}
- REDIS_HOST_PASSWORD=${REDIS_PW}
depends_on:
- mariadb
- redis
volumes:
- ./appdata/nextcloud:/config
- /amsvartnir/nextcloudstorage/:/data
#ports:
# - 11100:80
# - 12100:443
labels:
- "traefik.enable=true"
- "traefik.http.routers.nextcloud.entrypoints=websecure"
- "traefik.http.routers.nextcloud.rule=Host(`cloud.${DOMAIN}`)"
- "traefik.http.routers.nextcloud.tls=true"
- "traefik.http.routers.nextcloud.tls.certresolver=letencrypt"
#- "traefik.http.routers.nextcloud.middlewares=nextcloud-dav,secHeaders@file"
- "traefik.http.middlewares.nextcloud-dav.replacepathregex.regex=^/.well-known/ca(l|rd)dav"
- "traefik.http.middlewares.nextcloud-dav.replacepathregex.replacement=/remote.php/dav/"
networks:
- frontend
restart: unless-stopped
This is a first time for me with this error, what shall I do?
jtr
July 7, 2025, 7:04pm
2
This is a generic error. Check your nextcloud.log
as described in the support template .
I see you’re using the latest
tag. You may want to use a more specific tag to avoid surprising major version bumps. See LSIO’s image docs.
Failing favicon retrieval won’t prevent anything from functioning (to this degree). This is likely a red herring.
You are correct, this is a red herring.
This is what show now:
nextcloud | Doctrine\DBAL\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] php_network_getaddresses: getaddrinfo for mariadb failed: Name does not resolve in /app/www/public/lib/private/DB/Connection.php:237
nextcloud | Stack trace:
nextcloud | #0 /app/www/public/3rdparty/doctrine/dbal/src/Connection.php(458): OC\DB\Connection->connect()
nextcloud | #1 /app/www/public/3rdparty/doctrine/dbal/src/Connection.php(416): Doctrine\DBAL\Connection->getDatabasePlatformVersion()
nextcloud | #2 /app/www/public/3rdparty/doctrine/dbal/src/Connection.php(323): Doctrine\DBAL\Connection->detectDatabasePlatform()
nextcloud | #3 /app/www/public/lib/private/DB/Connection.php(903): Doctrine\DBAL\Connection->getDatabasePlatform()
nextcloud | #4 /app/www/public/lib/private/DB/ConnectionAdapter.php(235): OC\DB\Connection->getDatabaseProvider()
nextcloud | #5 /app/www/public/lib/private/DB/QueryBuilder/QueryBuilder.php(96): OC\DB\ConnectionAdapter->getDatabaseProvider()
nextcloud | #6 /app/www/public/lib/private/AppConfig.php(1226): OC\DB\QueryBuilder\QueryBuilder->expr()
nextcloud | #7 /app/www/public/lib/private/AppConfig.php(243): OC\AppConfig->loadConfig()
nextcloud | #8 /app/www/public/lib/private/AppConfig.php(1366): OC\AppConfig->searchValues()
nextcloud | #9 /app/www/public/lib/private/App/AppManager.php(136): OC\AppConfig->getValues()
nextcloud | #10 /app/www/public/lib/private/App/AppManager.php(157): OC\App\AppManager->getInstalledAppsValues()
nextcloud | #11 /app/www/public/lib/private/legacy/OC_App.php(188): OC\App\AppManager->getInstalledApps()
nextcloud | #12 /app/www/public/lib/private/AppFramework/Bootstrap/Coordinator.php(48): OC_App::getEnabledApps()
nextcloud | #13 /app/www/public/lib/base.php(675): OC\AppFramework\Bootstrap\Coordinator->runInitialRegistration()
nextcloud | #14 /app/www/public/lib/base.php(1171): OC::init()
nextcloud | #15 /app/www/public/cron.php(24): require_once('...')
nextcloud | #16 {main}
I know that the database is up and running. I have a healthcheck on it and I see it is up and running, the login works. And other services is using it.
jtr
July 7, 2025, 7:32pm
4
Can you test DNS resolution for mariadb
from within the Nextcloud container?
Is the mariadb
container on your frontend
Docker network?
jtr:
networks:
- frontend
Without checking it that has to be it!
system
Closed
July 15, 2025, 7:44pm
6
