Is the Nextcloud User Manual available in other languages, particularly in German?
Thank you!
Nextcloud version (eg, 10.0.2): 11.0.3
Operating system and version (eg, Ubuntu 16.04): Ubuntu 16.04
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.18
PHP version (eg, 5.6): 7.0.15
Is this the first time you’ve seen this error?: N/A
Can you reliably replicate it? (If so, please outline steps): N/A
The issue you are facing: Need a German language version of the Nextcloud User Manual
The output of your Nextcloud log in Admin > Logging: N/A
The output of your config.php file in /path/to/nextcloud (make sure you remove any identifiable information!): N/A
The output of your Apache/nginx/system log in /var/log/____: N/A
Remember, this information may be requested if it isn’t supplied; for fastest response please provide as much as you can
Feel free to use a pastebin service, otherwise log files can be indented with 4 spaces on each line to present them in a friendlier way on the forum.
