Updated without problems
I dont see a way to install the talk 3.2 from App store directly. How do i install it from my Nextcloud instance?
Solved!. I had to set āappstoreenabledā => true in the config to see the App store.
When I send a text message, the recipient first has the option of video chat. Only when you finish the video chat you come to the text chat.
This is related to push notifications I guess. This will be fixed in beta4.
Hi Mario,
I do have a small Problem my huawei P8max Android 6
The word comletion will not work and no examble is shown.
On my mediapad 3 with androit 7 there is not Problem.
Iāll check it out on Android 6.
Thank you.
I tried line and WhatsApp and had no Problem there. Android 6 and 7
Thank you again for the good app
Ah! Do you mean word completion or users completion?!
I meant word comletion which is helpfull for fast writing.
It works also in Android 8.
I use 6 7 and 8
Only 6 has that Problem.
In my lenovo with android 6 the word completion works like in others apps
Two questions:
Where can I get the apk?
Is there no way to donate?
Kind regards.
Frank
No way to donate. If you really want the APK, and donāt want to be part of the beta program, then over at Github
@mario
I donāt think it is a huawei problem, because with all other services word completion is okay with P8 android 6.0
The other huaweis I own with Android 7 and 8 do not have any problem
Well itās absolutely possible itās Huawei + Android 6 problem. Unfortunately these kind of problems are really hard to debug since I donāt have the phone.
You say it works with other apps?
Yes. I use Line, WhatsApp and Skype with the P8 and wordcompletion works.
Hi, from my side the app works fine, as it should be, the only thing is I donāt receive a notification for every chat I receive, should I configure something or is a feature that is not yet implemented?. Thanks for the efforts!
Cheers,
Bruno.
You should only be notified on mentions. Are you not?
Does it work when youāre, say, entering server url? Or doing something else inside the app where typing is needed?
