Is this the first time you’ve seen this error? Yes
- Install NextCloud + Collabora over docker-compose
- Install Collabora App
- Try setting up Collabora with either of the options proposed (self-hosted, built-in or demo)
- NextCloud looks happy and confirms the Collabora server is accessible (green mark and all)
- Documents download instead of opening in Collabora
Nothing relevant
?php
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'oca7yxi0axh4',
'passwordsalt' => 'AfOj2HbGCnlf5xhphKUF0WMDB7KzY6',
'secret' => '4PcUa5ICqo/EkYu5G+SB9FLRPDJaQOyWRHrlWw86onfHQhVA',
0 => 'cloud.irrig.io',
'version' => '25.0.1.1',
'overwrite.cli.url' => 'http://cloud.irrig.io',
'dbname' => 'nextcloud',
'dbhost' => 'db',
'dbuser' => 'nextcloud',
'dbpassword' => 'mysqlpasswd',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_from_address' => 'noreply',
'mail_domain' => 'irrig.io',
'mail_smtphost' => 'smtp.online.net',
'mail_smtpport' => '587',
'mail_smtpauth' => 1,
'mail_smtpname' => 'camille@irrig.io',
'mail_smtppassword' => 'Kactus223',
'mail_smtpauthtype' => 'PLAIN',
'loglevel' => 0,
'trusted_proxies' =>
1 => '127.0.0.1',
'overwritehost' => 'cloud.irrig.io',
Docker-compose:
version: '2'
volumes:
nextcloud:
db:
services:
db:
image: mariadb
restart: always
volumes:
- db:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=mysqrootpasswd
- MYSQL_PASSWORD=mysqlpasswd
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
app:
image: nextcloud:25
ports:
- 127.0.0.1:8001:80
links:
- db
volumes:
- nextcloud:/var/www/html
restart: always
labels:
ofelia.enabled: "true"
ofelia.job-exec.php-cron-nextcloud.schedule: "5 * * * *"
ofelia.job-exec.php-cron-nextcloud.command: "php -f /var/www/html/cron.php"
ofelia.job-exec.php-cron-nextcloud.user: "www-data"
ofelia:
image: mcuadros/ofelia:latest
depends_on:
- app
command: daemon --docker
volumes:
colabora:
image: collabora/code
environment:
- dictionaries=de en es fr
- domain=cloud\.irrig\.io
- extra_params=--o:server_name=office\.irrig\.io --o:net.post_allow.host=::ffff:172\.18\.0\.[0-9]+ --o:net.post_allow.host=172\.18\.0\.[0-9]+ --o:net.proto=IPv4
ports:
- 127.0.0.1:9980:9980
restart: always
cap_add:
- MKNOD
Apache configuration:
<VirtualHost *:80>
ServerName cloud.irrig.io
Redirect permanent / https://cloud.irrig.io/
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule ^ https://%{HTTP_HOST}%{REQUEST_URI} [R=301,L]
</VirtualHost>
<VirtualHost *:443>
ProxyRequests off
ProxyPreserveHost on
ProxyPass /error/ !
ProxyPass "/" "http://localhost:8001/"
ProxyPassReverse "/" "http://localhost:8001/"
SSLCertificateFile /etc/letsencrypt/live/cloud.irrig.io/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/cloud.irrig.io/privkey.pem
</VirtualHost>
<VirtualHost *:443>
ServerName office.irrig.io
# SSL configuration, you may want to take the easy route instead and use Lets Encrypt!
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/office.irrig.io/fullchain.pem
#SSLCertificateChainFile /path/to/intermediate_certificate
SSLCertificateKeyFile /etc/letsencrypt/live/office.irrig.io/privkey.pem
SSLProtocol all -SSLv2 -SSLv3
SSLCipherSuite ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
SSLHonorCipherOrder on
# Encoded slashes need to be allowed
AllowEncodedSlashes NoDecode
# Container uses a unique non-signed certificate
SSLProxyEngine On
SSLProxyVerify None
SSLProxyCheckPeerCN Off
SSLProxyCheckPeerName Off
# keep the host
ProxyPreserveHost On
# static html, js, images, etc. served from loolwsd
# loleaflet is the client part of LibreOffice Online
ProxyPass /loleaflet https://127.0.0.1:9980/loleaflet retry=0
ProxyPassReverse /loleaflet https://127.0.0.1:9980/loleaflet
# WOPI discovery URL
ProxyPass /hosting/discovery https://127.0.0.1:9980/hosting/discovery retry=0
ProxyPassReverse /hosting/discovery https://127.0.0.1:9980/hosting/discovery
# Main websocket
ProxyPassMatch "/lool/(.*)/ws$" wss://127.0.0.1:9980/lool/$1/ws nocanon
# Admin Console websocket
ProxyPass /lool/adminws wss://127.0.0.1:9980/lool/adminws
# Download as, Fullscreen presentation and Image upload operations
ProxyPass /lool https://127.0.0.1:9980/lool
ProxyPassReverse /lool https://127.0.0.1:9980/lool
# Endpoint with information about availability of various features
ProxyPass /hosting/capabilities https://127.0.0.1:9980/hosting/capabilities retry=0
ProxyPassReverse /hosting/capabilities https://127.0.0.1:9980/hosting/capabilities
</VirtualHost>
The exact same configuration, but with nextcoud:24 works fine.
