Hello!
I have nextcloud running well in Openmediavault - Portainer container.
All is working fine, excepted that big files are not synchronized to the server with error 413: toolarge…
Please where is the configuration point to adjust in environment like mine to increase the allowed filesize ?
Best regards Rico
Unsure of how OMV is setup, but try following our support template.
Hi @Rico_la_terreur,
You are missing the required support template. Please fill this form out and edit into your post.
Please copy paste the exact error message. Thanks.
This will give us the technical info and logs needed to help you! Thanks.
Hello! So sorry, the issue is solved: because i had more than one swag instances, i wrote in false config file. Have a very nice evening and thanks for your help
