NC-Report Teil 2:
{“Exception”:“Doctrine\DBAL\Exception\ConnectionLost”,“Message”:“An exception occurred while executing a query: SQLSTATE[HY000]: General error: 2006 MySQL server has gone away”,“Code”:2006,“Trace”:[{“file”:“/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php”,“line”:1780,“function”:“convert”,“class”:“Doctrine\DBAL\Driver\API\MySQL\ExceptionConverter”,“type”:“->”,“args”:[{“class”:“Doctrine\DBAL\Driver\PDO\Exception”},{“class”:“Doctrine\DBAL\Query”}]},{“file”:“/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php”,“line”:1719,“function”:“handleDriverException”,“class”:“Doctrine\DBAL\Connection”,“type”:“->”,“args”:[{“class”:“Doctrine\DBAL\Driver\PDO\Exception”},{“class”:“Doctrine\DBAL\Query”}]},{“file”:“/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php”,“line”:1067,“function”:“convertExceptionDuringQuery”,“class”:“Doctrine\DBAL\Connection”,“type”:“->”,“args”:[{“class”:“Doctrine\DBAL\Driver\PDO\Exception”},“SELECT gu.gid, g.displayname FROM oc_group_user gu LEFT JOIN oc_groups g ON gu.gid = g.gid WHERE uid = ?”,[“”],[2]]},{“file”:“/var/www/nextcloud/lib/private/DB/Connection.php”,“line”:237,“function”:“executeQuery”,“class”:“Doctrine\DBAL\Connection”,“type”:“->”,“args”:[“SELECT gu.gid, g.displayname FROM oc_group_user gu LEFT JOIN oc_groups g ON gu.gid = g.gid WHERE uid = ?”,[“”],[2],null]},{“file”:“/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php”,“line”:345,“function”:“executeQuery”,“class”:“OC\DB\Connection”,“type”:“->”,“args”:[“SELECT gu.gid, g.displayname FROM oc_group_user gu LEFT JOIN oc_groups g ON gu.gid = g.gid WHERE uid = :dcValue1”,[“”],[2]]},{“file”:“/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php”,“line”:287,“function”:“execute”,“class”:“Doctrine\DBAL\Query\QueryBuilder”,“type”:“->”,“args”:},{“file”:“/var/www/nextcloud/lib/private/Group/Database.php”,“line”:242,“function”:“execute”,“class”:“OC\DB\QueryBuilder\QueryBuilder”,“type”:“->”,“args”:},{“file”:“/var/www/nextcloud/lib/private/Group/Manager.php”,“line”:337,“function”:“getUserGroups”,“class”:“OC\Group\Database”,“type”:“->”,“args”:[“”]},{“file”:“/var/www/nextcloud/lib/private/Group/Manager.php”,“line”:316,“function”:“getUserIdGroupIds”,“class”:“OC\Group\Manager”,“type”:“->”,“args”:[“”]},{“file”:“/var/www/nextcloud/lib/private/Group/Manager.php”,“line”:305,“function”:“isInGroup”,“class”:“OC\Group\Manager”,“type”:“->”,“args”:[“”,“admin”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:247,“function”:“isAdmin”,“class”:“OC\Group\Manager”,“type”:“->”,“args”:[“”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:160,“function”:“OC\AppFramework\DependencyInjection\{closure}”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[“*** sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php",“line”:118,“function”:“OC\AppFramework\Utility\{closure}”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php",“line”:127,“function”:“offsetGet”,“class”:“Pimple\Container”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:457,“function”:“query”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:435,“function”:“queryNoFallback”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:56,“function”:“query”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:182,“function”:“get”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:160,“function”:“OC\AppFramework\DependencyInjection\{closure}”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php",“line”:118,“function”:“OC\AppFramework\Utility\{closure}”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php",“line”:208,“function”:“offsetGet”,“class”:“Pimple\Container”,“type”:“->”,“args”:[“Dispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/App.php”,“line”:149,“function”:“offsetGet”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“Dispatcher”]},{“file”:“/var/www/nextcloud/lib/private/Route/Router.php”,“line”:302,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:“::”,“args”:[“OCA\Provisioning_API\Controller\UsersController”,“getCurrentUser”," sensitive parameters replaced “,[“ocs.provisioning_api.Users.getCurrentUser”]]},{“file”:”/var/www/nextcloud/ocs/v1.php",“line”:62,“function”:“match”,“class”:“OC\Route\Router”,“type”:“->”,“args”:[“/ocsapp/cloud/user”]}],“File”:“/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php”,“Line”:101,“Previous”:{“Exception”:“Doctrine\DBAL\Driver\PDO\Exception”,“Message”:“SQLSTATE[HY000]: General error: 2006 MySQL server has gone away”,“Code”:2006,“Trace”:[{“file”:“/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php”,“line”:94,“function”:“new”,“class”:“Doctrine\DBAL\Driver\PDO\Exception”,“type”:“::”,“args”:[{“class”:“PDOException”,“errorInfo”:[“HY000”,2006,“MySQL server has gone away”]}]},{“file”:“/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php”,“line”:1057,“function”:“execute”,“class”:“Doctrine\DBAL\Driver\PDO\Statement”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/DB/Connection.php”,“line”:237,“function”:“executeQuery”,“class”:“Doctrine\DBAL\Connection”,“type”:“->”,“args”:[“SELECT gu.gid, g.displayname FROM oc_group_user gu LEFT JOIN oc_groups g ON gu.gid = g.gid WHERE uid = ?”,[“”],[2],null]},{“file”:“/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php”,“line”:345,“function”:“executeQuery”,“class”:“OC\DB\Connection”,“type”:“->”,“args”:[“SELECT gu.gid, g.displayname FROM oc_group_user gu LEFT JOIN oc_groups g ON gu.gid = g.gid WHERE uid = :dcValue1”,[“”],[2]]},{“file”:“/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php”,“line”:287,“function”:“execute”,“class”:“Doctrine\DBAL\Query\QueryBuilder”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/Group/Database.php”,“line”:242,“function”:“execute”,“class”:“OC\DB\QueryBuilder\QueryBuilder”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/Group/Manager.php”,“line”:337,“function”:“getUserGroups”,“class”:“OC\Group\Database”,“type”:“->”,“args”:[“”]},{“file”:“/var/www/nextcloud/lib/private/Group/Manager.php”,“line”:316,“function”:“getUserIdGroupIds”,“class”:“OC\Group\Manager”,“type”:“->”,“args”:[“”]},{“file”:“/var/www/nextcloud/lib/private/Group/Manager.php”,“line”:305,“function”:“isInGroup”,“class”:“OC\Group\Manager”,“type”:“->”,“args”:[“”,“admin”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:247,“function”:“isAdmin”,“class”:“OC\Group\Manager”,“type”:“->”,“args”:[“”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:160,“function”:“OC\AppFramework\DependencyInjection\{closure}”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php",“line”:118,“function”:“OC\AppFramework\Utility\{closure}”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php",“line”:127,“function”:“offsetGet”,“class”:“Pimple\Container”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:457,“function”:“query”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:435,“function”:“queryNoFallback”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:56,“function”:“query”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:182,“function”:“get”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:160,“function”:“OC\AppFramework\DependencyInjection\{closure}”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php",“line”:118,“function”:“OC\AppFramework\Utility\{closure}”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php",“line”:208,“function”:“offsetGet”,“class”:“Pimple\Container”,“type”:“->”,“args”:[“Dispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/App.php”,“line”:149,“function”:“offsetGet”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“Dispatcher”]},{“file”:“/var/www/nextcloud/lib/private/Route/Router.php”,“line”:302,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:“::”,“args”:[“OCA\Provisioning_API\Controller\UsersController”,“getCurrentUser”," sensitive parameters replaced “,[“ocs.provisioning_api.Users.getCurrentUser”]]},{“file”:”/var/www/nextcloud/ocs/v1.php",“line”:62,“function”:“match”,“class”:“OC\Route\Router”,“type”:“->”,“args”:[“/ocsapp/cloud/user”]}],“File”:“/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php”,“Line”:26,“Previous”:{“Exception”:“PDOException”,“Message”:“SQLSTATE[HY000]: General error: 2006 MySQL server has gone away”,“Code”:“HY000”,“Trace”:[{“file”:“/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php”,“line”:92,“function”:“execute”,“class”:“PDOStatement”,“type”:“->”,“args”:[null]},{“file”:“/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php”,“line”:1057,“function”:“execute”,“class”:“Doctrine\DBAL\Driver\PDO\Statement”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/DB/Connection.php”,“line”:237,“function”:“executeQuery”,“class”:“Doctrine\DBAL\Connection”,“type”:“->”,“args”:[“SELECT gu.gid, g.displayname FROM oc_group_user gu LEFT JOIN oc_groups g ON gu.gid = g.gid WHERE uid = ?”,[“”],[2],null]},{“file”:“/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php”,“line”:345,“function”:“executeQuery”,“class”:“OC\DB\Connection”,“type”:“->”,“args”:[“SELECT gu.gid, g.displayname FROM oc_group_user gu LEFT JOIN oc_groups g ON gu.gid = g.gid WHERE uid = :dcValue1”,[“”],[2]]},{“file”:“/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php”,“line”:287,“function”:“execute”,“class”:“Doctrine\DBAL\Query\QueryBuilder”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/Group/Database.php”,“line”:242,“function”:“execute”,“class”:“OC\DB\QueryBuilder\QueryBuilder”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/Group/Manager.php”,“line”:337,“function”:“getUserGroups”,“class”:“OC\Group\Database”,“type”:“->”,“args”:[“”]},{“file”:“/var/www/nextcloud/lib/private/Group/Manager.php”,“line”:316,“function”:“getUserIdGroupIds”,“class”:“OC\Group\Manager”,“type”:“->”,“args”:[“”]},{“file”:“/var/www/nextcloud/lib/private/Group/Manager.php”,“line”:305,“function”:“isInGroup”,“class”:“OC\Group\Manager”,“type”:“->”,“args”:[“”,“admin”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:247,“function”:“isAdmin”,“class”:“OC\Group\Manager”,“type”:“->”,“args”:[“”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:160,“function”:“OC\AppFramework\DependencyInjection\{closure}”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php",“line”:118,“function”:“OC\AppFramework\Utility\{closure}”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php",“line”:127,“function”:“offsetGet”,“class”:“Pimple\Container”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:457,“function”:“query”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:435,“function”:“queryNoFallback”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:56,“function”:“query”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:182,“function”:“get”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OC\AppFramework\Middleware\MiddlewareDispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:160,“function”:“OC\AppFramework\DependencyInjection\{closure}”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php",“line”:118,“function”:“OC\AppFramework\Utility\{closure}”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php",“line”:208,“function”:“offsetGet”,“class”:“Pimple\Container”,“type”:“->”,“args”:[“Dispatcher”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/App.php”,“line”:149,“function”:“offsetGet”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“Dispatcher”]},{“file”:“/var/www/nextcloud/lib/private/Route/Router.php”,“line”:302,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:“::”,“args”:[“OCA\Provisioning_API\Controller\UsersController”,“getCurrentUser”," sensitive parameters replaced “,[“ocs.provisioning_api.Users.getCurrentUser”]]},{“file”:”/var/www/nextcloud/ocs/v1.php",“line”:62,“function”:“match”,“class”:“OC\Route\Router”,“type”:“->”,“args”:[“/ocsapp/cloud/user”]}],“File”:“/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php”,“Line”:92}},“CustomMessage”:“–”}}
{“reqId”:“Yy7uq7fnf6K8z2xLY5uh3wAAAwI”,“level”:3,“time”:“2022-09-24T11:48:59+00:00”,“remoteAddr”:“192.168.178.159”,“user”:“–”,“app”:“index”,“method”:“GET”,“url”:“/index.php/apps/files/”,“message”:“read error on connection”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36 Edg/105.0.1343.50”,“version”:“23.0.6.1”,“exception”:{“Exception”:“RedisException”,“Message”:“read error on connection”,“Code”:0,“Trace”:[{“file”:“/var/www/nextcloud/lib/private/RedisFactory.php”,“line”:138,“function”:“auth”,“class”:“Redis”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/RedisFactory.php",“line”:172,“function”:“create”,“class”:“OC\RedisFactory”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/Memcache/Redis.php”,“line”:46,“function”:“getInstance”,“class”:“OC\RedisFactory”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/Memcache/Factory.php”,“line”:120,“function”:“__construct”,“class”:“OC\Memcache\Redis”,“type”:“->”,“args”:[“fecfed0b35d57bfb055f310cd78e05f5/lock”,“”]},{“file”:“/var/www/nextcloud/lib/private/Server.php”,“line”:1080,“function”:“createLocking”,“class”:“OC\Memcache\Factory”,“type”:“->”,“args”:[“lock”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:160,“function”:“OC\{closure}”,“class”:“OC\Server”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php",“line”:118,“function”:“OC\AppFramework\Utility\{closure}”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php",“line”:127,“function”:“offsetGet”,“class”:“Pimple\Container”,“type”:“->”,“args”:[“OCP\Lock\ILockingProvider”]},{“file”:“/var/www/nextcloud/lib/private/ServerContainer.php”,“line”:136,“function”:“query”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OCP\Lock\ILockingProvider”,false]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:56,“function”:“query”,“class”:“OC\ServerContainer”,“type”:“->”,“args”:[“OCP\Lock\ILockingProvider”]},{“file”:“/var/www/nextcloud/lib/private/Server.php”,“line”:2040,“function”:“get”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OCP\Lock\ILockingProvider”]},{“file”:“/var/www/nextcloud/lib/private/Files/View.php”,“line”:118,“function”:“getLockingProvider”,“class”:“OC\Server”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/Server.php”,“line”:439,“function”:“__construct”,“class”:“OC\Files\View”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:160,“function”:“OC\{closure}”,“class”:“OC\Server”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php",“line”:118,“function”:“OC\AppFramework\Utility\{closure}”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php",“line”:127,“function”:“offsetGet”,“class”:“Pimple\Container”,“type”:“->”,“args”:[“OC\Files\Node\HookConnector”]},{“file”:“/var/www/nextcloud/lib/private/ServerContainer.php”,“line”:136,“function”:“query”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OC\Files\Node\HookConnector”,false]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:56,“function”:“query”,“class”:“OC\ServerContainer”,“type”:“->”,“args”:[“OC\Files\Node\HookConnector”]},{“file”:“/var/www/nextcloud/lib/private/Server.php”,“line”:1403,“function”:“get”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OC\Files\Node\HookConnector”]},{“file”:“/var/www/nextcloud/lib/base.php”,“line”:594,“function”:“boot”,“class”:“OC\Server”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/base.php”,“line”:1089,“function”:“init”,“class”:“OC”,“type”:“::”,“args”:[]},{“file”:“/var/www/nextcloud/index.php”,“line”:34,“args”:[“/var/www/nextcloud/lib/base.php”],“function”:“require_once”}],“File”:“/var/www/nextcloud/lib/private/RedisFactory.php”,“Line”:138,“CustomMessage”:“–”}}
{“reqId”:“Yy7uq7fnf6K8z2xLY5uh3wAAAwI”,“level”:3,“time”:“2022-09-24T11:48:59+00:00”,“remoteAddr”:“192.168.178.159”,“user”:“–”,“app”:“no app in context”,“method”:“GET”,“url”:“/index.php/apps/files/”,“message”:“Could not boot files_trashbin: Could not resolve trashManager! Class trashManager does not exist”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36 Edg/105.0.1343.50”,“version”:“23.0.6.1”,“exception”:{“Exception”:“OCP\AppFramework\QueryException”,“Message”:“Could not resolve trashManager! Class trashManager does not exist”,“Code”:0,“Trace”:[{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:131,“function”:“resolve”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“trashManager”]},{“file”:“/var/www/nextcloud/lib/private/ServerContainer.php”,“line”:161,“function”:“query”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“trashManager”,true]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:438,“function”:“query”,“class”:“OC\ServerContainer”,“type”:“->”,“args”:[“trashManager”,true]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:56,“function”:“query”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[“trashManager”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php”,“line”:57,“function”:“get”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“trashManager”]},{“function”:“OC\AppFramework\Bootstrap\{closure}”,“class”:“OC\AppFramework\Bootstrap\FunctionInjector”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php",“line”:67,“function”:“array_map”,“args”:[{“class”:“Closure”},[{“class”:“ReflectionParameter”,“name”:“serverContainer”},{“class”:“ReflectionParameter”,“name”:“logger”},{“class”:“ReflectionParameter”,“name”:“appManager”}," sensitive parameters replaced “]]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php",“line”:51,“function”:“injectFn”,“class”:“OC\AppFramework\Bootstrap\FunctionInjector”,“type”:“->”,“args”:[[{“class”:“OCA\Files_Trashbin\AppInfo\Application”},“registerTrashBackends”]]},{“file”:“/var/www/nextcloud/apps/files_trashbin/lib/AppInfo/Application.php”,“line”:56,“function”:“injectFn”,“class”:“OC\AppFramework\Bootstrap\BootContext”,“type”:“->”,“args”:[[{“class”:“OCA\Files_Trashbin\AppInfo\Application”},“registerTrashBackends”]]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php”,“line”:181,“function”:“boot”,“class”:“OCA\Files_Trashbin\AppInfo\Application”,“type”:“->”,“args”:[{“class”:“OC\AppFramework\Bootstrap\BootContext”}]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_App.php”,“line”:206,“function”:“bootApp”,“class”:“OC\AppFramework\Bootstrap\Coordinator”,“type”:“->”,“args”:[“files_trashbin”]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_App.php”,“line”:140,“function”:“loadApp”,“class”:“OC_App”,“type”:“::”,“args”:[“files_trashbin”]},{“file”:“/var/www/nextcloud/apps/dav/lib/AppInfo/Application.php”,“line”:172,“function”:“loadApps”,“class”:“OC_App”,“type”:“::”,“args”:[[“dav”]]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php”,“line”:181,“function”:“boot”,“class”:“OCA\DAV\AppInfo\Application”,“type”:“->”,“args”:[{“class”:“OC\AppFramework\Bootstrap\BootContext”}]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_App.php”,“line”:206,“function”:“bootApp”,“class”:“OC\AppFramework\Bootstrap\Coordinator”,“type”:“->”,“args”:[“dav”]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_App.php”,“line”:140,“function”:“loadApp”,“class”:“OC_App”,“type”:“::”,“args”:[“dav”]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Util.php”,“line”:199,“function”:“loadApps”,“class”:“OC_App”,“type”:“::”,“args”:[[“filesystem”]]},{“file”:“/var/www/nextcloud/lib/private/Files/Mount/Manager.php”,“line”:87,“function”:“setupRootFS”,“class”:“OC_Util”,“type”:“::”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/Files/Mount/Manager.php”,“line”:103,“function”:“setupForFind”,“class”:“OC\Files\Mount\Manager”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Files/View.php”,“line”:1385,“function”:“find”,“class”:“OC\Files\Mount\Manager”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/Root.php”,“line”:200,“function”:“getFileInfo”,“class”:“OC\Files\View”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“function”:“get”,“class”:“OC\Files\Node\Root”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php”,“line”:65,“function”:“call_user_func_array”,“args”:[[{“class”:“OC\Files\Node\Root”},“get”],[“appdata_ocle6jowghkx/js/core”]]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php”,“line”:142,“function”:“__call”,“class”:“OC\Files\Node\LazyFolder”,“type”:“->”,“args”:[“get”,[“appdata_ocle6jowghkx/js/core”]]},{“file”:“/var/www/nextcloud/lib/private/Files/AppData/AppData.php”,“line”:141,“function”:“get”,“class”:“OC\Files\Node\LazyFolder”,“type”:“->”,“args”:[“appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSCombiner.php”,“line”:96,“function”:“getFolder”,“class”:“OC\Files\AppData\AppData”,“type”:“->”,“args”:[“core”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSResourceLocator.php”,“line”:115,“function”:“process”,“class”:“OC\Template\JSCombiner”,“type”:“->”,“args”:[“/var/www/nextcloud”,“core/js/merged-template-prepend.json”,“core”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSResourceLocator.php”,“line”:71,“function”:“cacheAndAppendCombineJsonIfExist”,“class”:“OC\Template\JSResourceLocator”,“type”:“->”,“args”:[“/var/www/nextcloud”,“core/js/merged-template-prepend.json”]},{“file”:“/var/www/nextcloud/lib/private/Template/ResourceLocator.php”,“line”:78,“function”:“doFind”,“class”:“OC\Template\JSResourceLocator”,“type”:“->”,“args”:[“js/merged-template-prepend”]},{“file”:“/var/www/nextcloud/lib/private/TemplateLayout.php”,“line”:388,“function”:“find”,“class”:“OC\Template\ResourceLocator”,“type”:“->”,“args”:[[“core/js/dist/main”,“js/dist/files_fileinfo”,“js/dist/files_client”,“js/merged-template-prepend”,“core/l10n/de”]]},{“file”:“/var/www/nextcloud/lib/private/TemplateLayout.php”,“line”:216,“function”:“findJavascriptFiles”,“class”:“OC\TemplateLayout”,“type”:“::”,“args”:[[“core/js/dist/main”,“js/dist/files_fileinfo”,“js/dist/files_client”,“js/merged-template-prepend”,“core/l10n/de”]]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:182,“function”:“__construct”,“class”:“OC\TemplateLayout”,“type”:“->”,“args”:[“error”,“”]},{“file”:“/var/www/nextcloud/lib/private/Template/Base.php”,“line”:132,“function”:“fetchPage”,“class”:“OC_Template”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:331,“function”:“printPage”,“class”:“OC\Template\Base”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/index.php”,“line”:74,“function”:“printExceptionErrorPage”,“class”:“OC_Template”,“type”:“::”,“args”:[{“class”:“RedisException”},500]}],“File”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“Line”:120,“CustomMessage”:“Could not boot files_trashbin: Could not resolve trashManager! Class trashManager does not exist”}}
{“reqId”:“Yy7uq7fnf6K8z2xLY5uh3wAAAwI”,“level”:3,“time”:“2022-09-24T11:48:59+00:00”,“remoteAddr”:“192.168.178.159”,“user”:“–”,“app”:“no app in context”,“method”:“GET”,“url”:“/index.php/apps/files/”,“message”:“Could not boot files_versions: Could not resolve OCA\Files_Versions\Versions\IVersionManager! Class can not be instantiated”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36 Edg/105.0.1343.50”,“version”:“23.0.6.1”,“exception”:{“Exception”:“OCP\AppFramework\QueryException”,“Message”:“Could not resolve OCA\Files_Versions\Versions\IVersionManager! Class can not be instantiated”,“Code”:0,“Trace”:[{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:131,“function”:“resolve”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OCA\Files_Versions\Versions\IVersionManager”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:463,“function”:“query”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OCA\Files_Versions\Versions\IVersionManager”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:435,“function”:“queryNoFallback”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[“OCA\Files_Versions\Versions\IVersionManager”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:56,“function”:“query”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[“OCA\Files_Versions\Versions\IVersionManager”]},{“file”:“/var/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php”,“line”:128,“function”:“get”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OCA\Files_Versions\Versions\IVersionManager”]},{“file”:“/var/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php”,“line”:115,“function”:“loadBackend”,“class”:“OCA\Files_Versions\AppInfo\Application”,“type”:“->”,“args”:[[[“OCP\Files\Storage\IStorage”],“OCA\Files_Versions\Versions\LegacyVersionsBackend”],{“class”:“OC\AppFramework\DependencyInjection\DIContainer”},{“class”:“OC\AppFramework\ScopedPsrLogger”}]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php”,“line”:67,“function”:“registerVersionBackends”,“class”:“OCA\Files_Versions\AppInfo\Application”,“type”:“->”,“args”:[{“class”:“OC\AppFramework\DependencyInjection\DIContainer”},{“class”:“OC\App\AppManager”},{“class”:“OC\AppFramework\ScopedPsrLogger”}]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php”,“line”:51,“function”:“injectFn”,“class”:“OC\AppFramework\Bootstrap\FunctionInjector”,“type”:“->”,“args”:[{“class”:“Closure”}]},{“file”:“/var/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php”,“line”:100,“function”:“injectFn”,“class”:“OC\AppFramework\Bootstrap\BootContext”,“type”:“->”,“args”:[{“class”:“Closure”}]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php”,“line”:181,“function”:“boot”,“class”:“OCA\Files_Versions\AppInfo\Application”,“type”:“->”,“args”:[{“class”:“OC\AppFramework\Bootstrap\BootContext”}]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_App.php”,“line”:206,“function”:“bootApp”,“class”:“OC\AppFramework\Bootstrap\Coordinator”,“type”:“->”,“args”:[“files_versions”]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_App.php”,“line”:140,“function”:“loadApp”,“class”:“OC_App”,“type”:“::”,“args”:[“files_versions”]},{“file”:“/var/www/nextcloud/apps/dav/lib/AppInfo/Application.php”,“line”:172,“function”:“loadApps”,“class”:“OC_App”,“type”:“::”,“args”:[[“dav”]]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php”,“line”:181,“function”:“boot”,“class”:“OCA\DAV\AppInfo\Application”,“type”:“->”,“args”:[{“class”:“OC\AppFramework\Bootstrap\BootContext”}]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_App.php”,“line”:206,“function”:“bootApp”,“class”:“OC\AppFramework\Bootstrap\Coordinator”,“type”:“->”,“args”:[“dav”]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_App.php”,“line”:140,“function”:“loadApp”,“class”:“OC_App”,“type”:“::”,“args”:[“dav”]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Util.php”,“line”:199,“function”:“loadApps”,“class”:“OC_App”,“type”:“::”,“args”:[[“filesystem”]]},{“file”:“/var/www/nextcloud/lib/private/Files/Mount/Manager.php”,“line”:87,“function”:“setupRootFS”,“class”:“OC_Util”,“type”:“::”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/Files/Mount/Manager.php”,“line”:103,“function”:“setupForFind”,“class”:“OC\Files\Mount\Manager”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Files/View.php”,“line”:1385,“function”:“find”,“class”:“OC\Files\Mount\Manager”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/Root.php”,“line”:200,“function”:“getFileInfo”,“class”:“OC\Files\View”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“function”:“get”,“class”:“OC\Files\Node\Root”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php”,“line”:65,“function”:“call_user_func_array”,“args”:[[{“class”:“OC\Files\Node\Root”},“get”],[“appdata_ocle6jowghkx/js/core”]]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php”,“line”:142,“function”:“__call”,“class”:“OC\Files\Node\LazyFolder”,“type”:“->”,“args”:[“get”,[“appdata_ocle6jowghkx/js/core”]]},{“file”:“/var/www/nextcloud/lib/private/Files/AppData/AppData.php”,“line”:141,“function”:“get”,“class”:“OC\Files\Node\LazyFolder”,“type”:“->”,“args”:[“appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSCombiner.php”,“line”:96,“function”:“getFolder”,“class”:“OC\Files\AppData\AppData”,“type”:“->”,“args”:[“core”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSResourceLocator.php”,“line”:115,“function”:“process”,“class”:“OC\Template\JSCombiner”,“type”:“->”,“args”:[“/var/www/nextcloud”,“core/js/merged-template-prepend.json”,“core”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSResourceLocator.php”,“line”:71,“function”:“cacheAndAppendCombineJsonIfExist”,“class”:“OC\Template\JSResourceLocator”,“type”:“->”,“args”:[“/var/www/nextcloud”,“core/js/merged-template-prepend.json”]},{“file”:“/var/www/nextcloud/lib/private/Template/ResourceLocator.php”,“line”:78,“function”:“doFind”,“class”:“OC\Template\JSResourceLocator”,“type”:“->”,“args”:[“js/merged-template-prepend”]},{“file”:“/var/www/nextcloud/lib/private/TemplateLayout.php”,“line”:388,“function”:“find”,“class”:“OC\Template\ResourceLocator”,“type”:“->”,“args”:[[“core/js/dist/main”,“js/dist/files_fileinfo”,“js/dist/files_client”,“js/merged-template-prepend”,“core/l10n/de”]]},{“file”:“/var/www/nextcloud/lib/private/TemplateLayout.php”,“line”:216,“function”:“findJavascriptFiles”,“class”:“OC\TemplateLayout”,“type”:“::”,“args”:[[“core/js/dist/main”,“js/dist/files_fileinfo”,“js/dist/files_client”,“js/merged-template-prepend”,“core/l10n/de”]]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:182,“function”:“__construct”,“class”:“OC\TemplateLayout”,“type”:“->”,“args”:[“error”,“”]},{“file”:“/var/www/nextcloud/lib/private/Template/Base.php”,“line”:132,“function”:“fetchPage”,“class”:“OC_Template”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:331,“function”:“printPage”,“class”:“OC\Template\Base”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/index.php”,“line”:74,“function”:“printExceptionErrorPage”,“class”:“OC_Template”,“type”:“::”,“args”:[{“class”:“RedisException”},500]}],“File”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“Line”:116,“CustomMessage”:“Could not boot files_versions: Could not resolve OCA\Files_Versions\Versions\IVersionManager! Class can not be instantiated”}}
{“reqId”:“Yy7uq7fnf6K8z2xLY5uh3wAAAwI”,“level”:3,“time”:“2022-09-24T11:48:59+00:00”,“remoteAddr”:“192.168.178.159”,“user”:“–”,“app”:“no app in context”,“method”:“GET”,“url”:“/index.php/apps/files/”,“message”:“Could not boot files_sharing: Could not resolve externalMountProvider! Class externalMountProvider does not exist”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36 Edg/105.0.1343.50”,“version”:“23.0.6.1”,“exception”:{“Exception”:“OCP\AppFramework\QueryException”,“Message”:“Could not resolve externalMountProvider! Class externalMountProvider does not exist”,“Code”:0,“Trace”:[{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:131,“function”:“resolve”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“externalMountProvider”]},{“file”:“/var/www/nextcloud/lib/private/ServerContainer.php”,“line”:161,“function”:“query”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“externalMountProvider”,true]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:438,“function”:“query”,“class”:“OC\ServerContainer”,“type”:“->”,“args”:[“externalMountProvider”,true]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:56,“function”:“query”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[“externalMountProvider”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php”,“line”:57,“function”:“get”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“externalMountProvider”]},{“function”:“OC\AppFramework\Bootstrap\{closure}”,“class”:“OC\AppFramework\Bootstrap\FunctionInjector”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php",“line”:67,“function”:“array_map”,“args”:[{“class”:“Closure”},[{“class”:“ReflectionParameter”,“name”:“mountProviderCollection”},{“class”:“ReflectionParameter”,“name”:“mountProvider”}," sensitive parameters replaced “]]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php",“line”:51,“function”:“injectFn”,“class”:“OC\AppFramework\Bootstrap\FunctionInjector”,“type”:“->”,“args”:[[{“class”:“OCA\Files_Sharing\AppInfo\Application”},“registerMountProviders”]]},{“file”:“/var/www/nextcloud/apps/files_sharing/lib/AppInfo/Application.php”,“line”:104,“function”:“injectFn”,“class”:“OC\AppFramework\Bootstrap\BootContext”,“type”:“->”,“args”:[[{“class”:“OCA\Files_Sharing\AppInfo\Application”},“registerMountProviders”]]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php”,“line”:181,“function”:“boot”,“class”:“OCA\Files_Sharing\AppInfo\Application”,“type”:“->”,“args”:[{“class”:“OC\AppFramework\Bootstrap\BootContext”}]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_App.php”,“line”:206,“function”:“bootApp”,“class”:“OC\AppFramework\Bootstrap\Coordinator”,“type”:“->”,“args”:[“files_sharing”]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_App.php”,“line”:140,“function”:“loadApp”,“class”:“OC_App”,“type”:“::”,“args”:[“files_sharing”]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Util.php”,“line”:199,“function”:“loadApps”,“class”:“OC_App”,“type”:“::”,“args”:[[“filesystem”]]},{“file”:“/var/www/nextcloud/lib/private/Files/Mount/Manager.php”,“line”:87,“function”:“setupRootFS”,“class”:“OC_Util”,“type”:“::”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/Files/Mount/Manager.php”,“line”:103,“function”:“setupForFind”,“class”:“OC\Files\Mount\Manager”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Files/View.php”,“line”:1385,“function”:“find”,“class”:“OC\Files\Mount\Manager”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/Root.php”,“line”:200,“function”:“getFileInfo”,“class”:“OC\Files\View”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“function”:“get”,“class”:“OC\Files\Node\Root”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php”,“line”:65,“function”:“call_user_func_array”,“args”:[[{“class”:“OC\Files\Node\Root”},“get”],[“appdata_ocle6jowghkx/js/core”]]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php”,“line”:142,“function”:“__call”,“class”:“OC\Files\Node\LazyFolder”,“type”:“->”,“args”:[“get”,[“appdata_ocle6jowghkx/js/core”]]},{“file”:“/var/www/nextcloud/lib/private/Files/AppData/AppData.php”,“line”:141,“function”:“get”,“class”:“OC\Files\Node\LazyFolder”,“type”:“->”,“args”:[“appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSCombiner.php”,“line”:96,“function”:“getFolder”,“class”:“OC\Files\AppData\AppData”,“type”:“->”,“args”:[“core”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSResourceLocator.php”,“line”:115,“function”:“process”,“class”:“OC\Template\JSCombiner”,“type”:“->”,“args”:[“/var/www/nextcloud”,“core/js/merged-template-prepend.json”,“core”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSResourceLocator.php”,“line”:71,“function”:“cacheAndAppendCombineJsonIfExist”,“class”:“OC\Template\JSResourceLocator”,“type”:“->”,“args”:[“/var/www/nextcloud”,“core/js/merged-template-prepend.json”]},{“file”:“/var/www/nextcloud/lib/private/Template/ResourceLocator.php”,“line”:78,“function”:“doFind”,“class”:“OC\Template\JSResourceLocator”,“type”:“->”,“args”:[“js/merged-template-prepend”]},{“file”:“/var/www/nextcloud/lib/private/TemplateLayout.php”,“line”:388,“function”:“find”,“class”:“OC\Template\ResourceLocator”,“type”:“->”,“args”:[[“core/js/dist/main”,“js/dist/files_fileinfo”,“js/dist/files_client”,“js/merged-template-prepend”,“core/l10n/de”]]},{“file”:“/var/www/nextcloud/lib/private/TemplateLayout.php”,“line”:216,“function”:“findJavascriptFiles”,“class”:“OC\TemplateLayout”,“type”:“::”,“args”:[[“core/js/dist/main”,“js/dist/files_fileinfo”,“js/dist/files_client”,“js/merged-template-prepend”,“core/l10n/de”]]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:182,“function”:“__construct”,“class”:“OC\TemplateLayout”,“type”:“->”,“args”:[“error”,“”]},{“file”:“/var/www/nextcloud/lib/private/Template/Base.php”,“line”:132,“function”:“fetchPage”,“class”:“OC_Template”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:331,“function”:“printPage”,“class”:“OC\Template\Base”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/index.php”,“line”:74,“function”:“printExceptionErrorPage”,“class”:“OC_Template”,“type”:“::”,“args”:[{“class”:“RedisException”},500]}],“File”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“Line”:120,“CustomMessage”:“Could not boot files_sharing: Could not resolve externalMountProvider! Class externalMountProvider does not exist”}}
{“reqId”:“Yy7uq7fnf6K8z2xLY5uh3wAAAwI”,“level”:3,“time”:“2022-09-24T11:48:59+00:00”,“remoteAddr”:“192.168.178.159”,“user”:“–”,“app”:“no app in context”,“method”:“GET”,“url”:“/index.php/apps/files/”,“message”:“Could not boot notify_push: Could not resolve listener! Class listener does not exist”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36 Edg/105.0.1343.50”,“version”:“23.0.6.1”,“exception”:{“Exception”:“OCP\AppFramework\QueryException”,“Message”:“Could not resolve listener! Class listener does not exist”,“Code”:0,“Trace”:[{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:131,“function”:“resolve”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“listener”]},{“file”:“/var/www/nextcloud/lib/private/ServerContainer.php”,“line”:161,“function”:“query”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“listener”,true]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php”,“line”:438,“function”:“query”,“class”:“OC\ServerContainer”,“type”:“->”,“args”:[“listener”,true]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:56,“function”:“query”,“class”:“OC\AppFramework\DependencyInjection\DIContainer”,“type”:“->”,“args”:[“listener”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php”,“line”:57,“function”:“get”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“listener”]},{“function”:“OC\AppFramework\Bootstrap\{closure}”,“class”:“OC\AppFramework\Bootstrap\FunctionInjector”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php",“line”:67,“function”:“array_map”,“args”:[{“class”:“Closure”},[{“class”:“ReflectionParameter”,“name”:“eventDispatcher”}," sensitive parameters replaced “,{“class”:“ReflectionParameter”,“name”:“activityManager”},{“class”:“ReflectionParameter”,“name”:“notificationManager”}]]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php",“line”:51,“function”:“injectFn”,“class”:“OC\AppFramework\Bootstrap\FunctionInjector”,“type”:“->”,“args”:[[{“class”:“OCA\NotifyPush\AppInfo\Application”},“attachHooks”]]},{“file”:“/var/www/nextcloud/apps/notify_push/lib/AppInfo/Application.php”,“line”:70,“function”:“injectFn”,“class”:“OC\AppFramework\Bootstrap\BootContext”,“type”:“->”,“args”:[[{“class”:“OCA\NotifyPush\AppInfo\Application”},“attachHooks”]]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php”,“line”:181,“function”:“boot”,“class”:“OCA\NotifyPush\AppInfo\Application”,“type”:“->”,“args”:[{“class”:“OC\AppFramework\Bootstrap\BootContext”}]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_App.php”,“line”:206,“function”:“bootApp”,“class”:“OC\AppFramework\Bootstrap\Coordinator”,“type”:“->”,“args”:[“notify_push”]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_App.php”,“line”:140,“function”:“loadApp”,“class”:“OC_App”,“type”:“::”,“args”:[“notify_push”]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Util.php”,“line”:199,“function”:“loadApps”,“class”:“OC_App”,“type”:“::”,“args”:[[“filesystem”]]},{“file”:“/var/www/nextcloud/lib/private/Files/Mount/Manager.php”,“line”:87,“function”:“setupRootFS”,“class”:“OC_Util”,“type”:“::”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/Files/Mount/Manager.php”,“line”:103,“function”:“setupForFind”,“class”:“OC\Files\Mount\Manager”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Files/View.php”,“line”:1385,“function”:“find”,“class”:“OC\Files\Mount\Manager”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/Root.php”,“line”:200,“function”:“getFileInfo”,“class”:“OC\Files\View”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“function”:“get”,“class”:“OC\Files\Node\Root”,“type”:“->”,“args”:[“/appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php”,“line”:65,“function”:“call_user_func_array”,“args”:[[{“class”:“OC\Files\Node\Root”},“get”],[“appdata_ocle6jowghkx/js/core”]]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php”,“line”:142,“function”:“__call”,“class”:“OC\Files\Node\LazyFolder”,“type”:“->”,“args”:[“get”,[“appdata_ocle6jowghkx/js/core”]]},{“file”:“/var/www/nextcloud/lib/private/Files/AppData/AppData.php”,“line”:141,“function”:“get”,“class”:“OC\Files\Node\LazyFolder”,“type”:“->”,“args”:[“appdata_ocle6jowghkx/js/core”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSCombiner.php”,“line”:96,“function”:“getFolder”,“class”:“OC\Files\AppData\AppData”,“type”:“->”,“args”:[“core”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSResourceLocator.php”,“line”:115,“function”:“process”,“class”:“OC\Template\JSCombiner”,“type”:“->”,“args”:[“/var/www/nextcloud”,“core/js/merged-template-prepend.json”,“core”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSResourceLocator.php”,“line”:71,“function”:“cacheAndAppendCombineJsonIfExist”,“class”:“OC\Template\JSResourceLocator”,“type”:“->”,“args”:[“/var/www/nextcloud”,“core/js/merged-template-prepend.json”]},{“file”:“/var/www/nextcloud/lib/private/Template/ResourceLocator.php”,“line”:78,“function”:“doFind”,“class”:“OC\Template\JSResourceLocator”,“type”:“->”,“args”:[“js/merged-template-prepend”]},{“file”:“/var/www/nextcloud/lib/private/TemplateLayout.php”,“line”:388,“function”:“find”,“class”:“OC\Template\ResourceLocator”,“type”:“->”,“args”:[[“core/js/dist/main”,“js/dist/files_fileinfo”,“js/dist/files_client”,“js/merged-template-prepend”,“core/l10n/de”]]},{“file”:“/var/www/nextcloud/lib/private/TemplateLayout.php”,“line”:216,“function”:“findJavascriptFiles”,“class”:“OC\TemplateLayout”,“type”:“::”,“args”:[[“core/js/dist/main”,“js/dist/files_fileinfo”,“js/dist/files_client”,“js/merged-template-prepend”,“core/l10n/de”]]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:182,“function”:“__construct”,“class”:“OC\TemplateLayout”,“type”:“->”,“args”:[“error”,“”]},{“file”:“/var/www/nextcloud/lib/private/Template/Base.php”,“line”:132,“function”:“fetchPage”,“class”:“OC_Template”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:331,“function”:“printPage”,“class”:“OC\Template\Base”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/index.php”,“line”:74,“function”:“printExceptionErrorPage”,“class”:“OC_Template”,“type”:“::”,“args”:[{“class”:“RedisException”},500]}],“File”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“Line”:120,“CustomMessage”:“Could not boot notify_push: Could not resolve listener! Class listener does not exist”}}
{“reqId”:“Yy7uq7fnf6K8z2xLY5uh3wAAAwI”,“level”:3,“time”:“2022-09-24T11:48:59+00:00”,“remoteAddr”:“192.168.178.159”,“user”:“–”,“app”:“core”,“method”:“GET”,“url”:“/index.php/apps/files/”,“message”:“read error on connection”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36 Edg/105.0.1343.50”,“version”:“23.0.6.1”,“exception”:{“Exception”:“RedisException”,“Message”:“read error on connection”,“Code”:0,“Trace”:[{“file”:“/var/www/nextcloud/lib/private/RedisFactory.php”,“line”:138,“function”:“auth”,“class”:“Redis”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/RedisFactory.php",“line”:172,“function”:“create”,“class”:“OC\RedisFactory”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/Memcache/Redis.php”,“line”:46,“function”:“getInstance”,“class”:“OC\RedisFactory”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/Memcache/Factory.php”,“line”:120,“function”:“__construct”,“class”:“OC\Memcache\Redis”,“type”:“->”,“args”:[“fecfed0b35d57bfb055f310cd78e05f5/lock”,“”]},{“file”:“/var/www/nextcloud/lib/private/Server.php”,“line”:1080,“function”:“createLocking”,“class”:“OC\Memcache\Factory”,“type”:“->”,“args”:[“lock”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:160,“function”:“OC\{closure}”,“class”:“OC\Server”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php",“line”:118,“function”:“OC\AppFramework\Utility\{closure}”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php",“line”:127,“function”:“offsetGet”,“class”:“Pimple\Container”,“type”:“->”,“args”:[“OCP\Lock\ILockingProvider”]},{“file”:“/var/www/nextcloud/lib/private/ServerContainer.php”,“line”:136,“function”:“query”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OCP\Lock\ILockingProvider”,false]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:56,“function”:“query”,“class”:“OC\ServerContainer”,“type”:“->”,“args”:[“OCP\Lock\ILockingProvider”]},{“file”:“/var/www/nextcloud/lib/private/Server.php”,“line”:2040,“function”:“get”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OCP\Lock\ILockingProvider”]},{“file”:“/var/www/nextcloud/lib/private/Files/View.php”,“line”:118,“function”:“getLockingProvider”,“class”:“OC\Server”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/Server.php”,“line”:439,“function”:“__construct”,“class”:“OC\Files\View”,“type”:“->”,“args”:[]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:160,“function”:“OC\{closure}”,“class”:“OC\Server”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php",“line”:118,“function”:“OC\AppFramework\Utility\{closure}”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[" sensitive parameters replaced ***”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:127,“function”:“offsetGet”,“class”:“Pimple\Container”,“type”:“->”,“args”:[“OC\Files\Node\HookConnector”]},{“file”:“/var/www/nextcloud/lib/private/ServerContainer.php”,“line”:136,“function”:“query”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OC\Files\Node\HookConnector”,false]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:56,“function”:“query”,“class”:“OC\ServerContainer”,“type”:“->”,“args”:[“OC\Files\Node\HookConnector”]},{“file”:“/var/www/nextcloud/lib/private/Server.php”,“line”:1403,“function”:“get”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[“OC\Files\Node\HookConnector”]},{“file”:“/var/www/nextcloud/lib/base.php”,“line”:594,“function”:“boot”,“class”:“OC\Server”,“type”:“->”,“args”:},{“file”:“/var/www/nextcloud/lib/base.php”,“line”:1089,“function”:“init”,“class”:“OC”,“type”:“::”,“args”:},{“file”:“/var/www/nextcloud/index.php”,“line”:34,“args”:[“/var/www/nextcloud/lib/base.php”],“function”:“require_once”}],“File”:“/var/www/nextcloud/lib/private/RedisFactory.php”,“Line”:138,“CustomMessage”:“–”}}
{“reqId”:“Yy7uq7fnf6K8z2xLY5uh3wAAAwI”,“level”:3,“time”:“2022-09-24T11:48:59+00:00”,“remoteAddr”:“192.168.178.159”,“user”:“–”,“app”:“core”,“method”:“GET”,“url”:“/index.php/apps/files/”,“message”:“NOAUTH Authentication required.”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36 Edg/105.0.1343.50”,“version”:“23.0.6.1”,“exception”:{“Exception”:“RedisException”,“Message”:“NOAUTH Authentication required.”,“Code”:0,“Trace”:[{“file”:“/var/www/nextcloud/lib/private/Memcache/Redis.php”,“line”:66,“function”:“get”,“class”:“Redis”,“type”:“->”,“args”:[“fecfed0b35d57bfb055f310cd78e05f5/JS-bc619556b0787b511e2dcf8c7e0a24fccore-merged-template-prepend.js.deps”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSCombiner.php”,“line”:122,“function”:“get”,“class”:“OC\Memcache\Redis”,“type”:“->”,“args”:[“core-merged-template-prepend.js.deps”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSCombiner.php”,“line”:102,“function”:“isCached”,“class”:“OC\Template\JSCombiner”,“type”:“->”,“args”:[“merged-template-prepend.js.deps”,{“class”:“OC\Files\SimpleFS\SimpleFolder”}]},{“file”:“/var/www/nextcloud/lib/private/Template/JSResourceLocator.php”,“line”:115,“function”:“process”,“class”:“OC\Template\JSCombiner”,“type”:“->”,“args”:[“/var/www/nextcloud”,“core/js/merged-template-prepend.json”,“core”]},{“file”:“/var/www/nextcloud/lib/private/Template/JSResourceLocator.php”,“line”:71,“function”:“cacheAndAppendCombineJsonIfExist”,“class”:“OC\Template\JSResourceLocator”,“type”:“->”,“args”:[“/var/www/nextcloud”,“core/js/merged-template-prepend.json”]},{“file”:“/var/www/nextcloud/lib/private/Template/ResourceLocator.php”,“line”:78,“function”:“doFind”,“class”:“OC\Template\JSResourceLocator”,“type”:“->”,“args”:[“js/merged-template-prepend”]},{“file”:“/var/www/nextcloud/lib/private/TemplateLayout.php”,“line”:388,“function”:“find”,“class”:“OC\Template\ResourceLocator”,“type”:“->”,“args”:[[“core/js/dist/main”,“js/dist/files_fileinfo”,“js/dist/files_client”,“js/merged-template-prepend”,“core/l10n/de”]]},{“file”:“/var/www/nextcloud/lib/private/TemplateLayout.php”,“line”:216,“function”:“findJavascriptFiles”,“class”:“OC\TemplateLayout”,“type”:“::”,“args”:[[“core/js/dist/main”,“js/dist/files_fileinfo”,“js/dist/files_client”,“js/merged-template-prepend”,“core/l10n/de”]]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:182,“function”:“__construct”,“class”:“OC\TemplateLayout”,“type”:“->”,“args”:[“error”,“”]},{“file”:“/var/www/nextcloud/lib/private/Template/Base.php”,“line”:132,“function”:“fetchPage”,“class”:“OC_Template”,“type”:“->”,“args”:},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:331,“function”:“printPage”,“class”:“OC\Template\Base”,“type”:“->”,“args”:},{“file”:“/var/www/nextcloud/index.php”,“line”:74,“function”:“printExceptionErrorPage”,“class”:“OC_Template”,“type”:“::”,“args”:[{“class”:“RedisException”},500]}],“File”:“/var/www/nextcloud/lib/private/Memcache/Redis.php”,“Line”:66,“CustomMessage”:“–”}}
{“reqId”:“Yy8AlLfnf6K8z2xLY5uncgAABh0”,“level”:2,“time”:“2022-09-24T13:05:24+00:00”,“remoteAddr”:“192.168.178.159”,“user”:“”,“app”:“core”,“method”:“POST”,“url”:“/index.php/login/challenge/totp”,“message”:“Two-factor challenge failed: (Remote IP: 192.168.178.159)”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36 Edg/105.0.1343.50”,“version”:“23.0.6.1”}
{“reqId”:“VEcuiq8cMr8pcJIRLji7”,“level”:2,“time”:“2022-09-25T04:26:07+00:00”,“remoteAddr”:“”,“user”:“–”,“app”:“appstoreFetcher”,“method”:“”,“url”:“–”,“message”:“Could not connect to appstore: cURL error 28: Operation timed out after 60001 milliseconds with 0 out of 0 bytes received (see libcurl - Error Codes) for https://apps.nextcloud.com/api/v1/apps.json",“userAgent”:“--”,“version”:"23.0.6.1”}
</details>
