Hello, I have a folder in the dataset shared with nextcloud, everything is entered correctly in next cloud and it still shows me folders from another dataset. I have Nextcloud on truenas. What’s the problem?
I do not really understand it. But i think you must use
/mnt/Polaczone/Domowy/Tobiasz
instead of
But that does not explain the entries with 2024.
I did as you wrote. Nothing has changed
Do you have any idea where those other folders are from? Did you have something else mounted there? Are they folders that you had there but deleted at some point? What’s the history of this setup?
Also please check things like External Storage: Adding Files.
It would also be helpful if you didn’t bypass the support template.
I created two datasets. One for files and one for photos. The one that is displayed in nextcloud is the dataset for photos, and I would like to display the dataset for files. Both datasets created folders with the same names, only the dataset for files only has folders named “Tobiasz”, “Slawek” and “Magda”. It is from the dataset for photos that these additional folders come
Sorry, next time I’ll use a template.
