Nextcloud Office Build-in Code Server does not Work
Nextcloud version: 28.0.6
Operating system and version: Linux nextbox 5.10.103-v8+ aarch64**
I’m very new to nextcloud and am trying to install nextcloud office with the built-in code server. After installing both packages and checking unse build-in code server, I get the following error messages:
Could not establish connection to the Collabora Online server.
Failed to connect to the remote server: Could not find urlsrc for application/vnd.openxmlformats-officedocument.wordprocessingml.document in WOPI discovery response
and:
You have not configured the allow-list for WOPI requests. Without this setting users may download restricted files via WOPI requests to the Nextcloud server. Click here for more info
Unfortunately I really don’t know what to do with it. Any suggestions?
Thanks, kind regards kr1979
The error sounds like something is wrong with CODE hosting/discovery… please consult Collabora integration guide for troubleshooting steps and report details if this doesn’t help.
I did try to follow the checklist but it did not get me any further, bassically because I don’t understand some bits of it.
curl https://mydomain/status.php
{"installed":true,"maintenance":false,"needsDbUpgrade":false,"version":"28.0.6.1","versionstring":"28.0.6","edition":"","productname":"Nextcloud","extendedSupport":false}
For from client and nextcloud:
curl -k https://mydomain/apps/richdocumentscode/proxy.php?req=/hosting/capabilities
and:
curl https://mydomain/apps/richdocumentscode/proxy.php?req=/hosting/discovery
I get huge html files. So what is next? Am I missing something?
You need to install the ARM64 edition of Built-in CODE from the app store.
I did install the wrong one at first, but now the ARM64 edition is running.
