Hi, Nextcloud Office and Collabora built in code server arm64, do not work.
Since version 25 (I think) of Nextcloud this plugin doesn’t work: I can’t open office files.
It seems really strange to me that this problem was not resolved with the Nextcloud and plugin updates. I think it’s a really important bug!! What can be done?? Thank you
The problem is often reported and often the root cause is the system misconfiguration. I would recommend working through many existing threads collabora-built-in
If you don’t find the problem you will learn which data you must attach here to receive help.
I’m seeing in the various requests for help that there hasn’t been a resolution to the problem. I should be in this case Nextcloud-Office: non stop circling `loading yxz.docx ...` but I don’t know what to do… how do you solve it??
I would be grateful if anyone could find a step by step solution to this!! Thank you
When you visit https://domain.tlf/apps/richdocumentscode_arm64/proxy.php?req=/hosting/discovery
what happens?
Thank you for answering
The browser tells me:
404 Not Found
The requested URL was not found on this server.
What do I have to do?
What installation method did you use? Do you have any custom apps folders configured?
I installed Nextcloud via Snap. I’ve been doing this for years and Office/Collabora has always worked. At some point since the 24/25 version of NC, Office/Collaborate no longer worked. I only customized the Notes app folders (but after that it didn’t work anymore).
You didn’t mention Snap before. Snap is a unique beast.
At least one possibility, is that there is some weirdness involving Snap / FUSE / underlying library versions[1]. I haven’t dug into the details too heavily since I no longer have any arm64 instances myself. There’s also a Wiki the Snap folks keep fairly up-to-date[2].
