Nextcloud instance randomly switches to maintenance mode
    • 30.0.17
    • Ubuntu 22.0.4 LTS
    • Apache 2.4
    • none
    • 8.1.2
    • no, it is the second time
    • two weeks ago
    • bre metal
    • no
Nexcloud instance goes into maintenance mode witout any admin interaction.
I have to ssh into the server and deactivate maintenance mode via the occ command line.
I could not find anything regarding this here in the forum… is this a known bug? :face_with_raised_eyebrow:
none, it just happens randomly
there are no relevant log entries
We can’t help you unless you fill out the support template. We don’t even have your config or app list.
nope… that’s probably why you didn’t find anything in the forum :laughing:
EOL = 2025-10
not supported any longer…
calling for geriatric ward…
→ we’ll need your logs though, post your config and an app list, have you checked the system logs? otherwise its a guessing game.
recommend upgrading Nextcloud and upgrading os or we’ll be chasing windmills
Thanks for the feedback - unfortunately, upgrading is currently not an option.
Most likely I will be able to do this sometimes in January 26…
Are you sure? Is there really no entry about “maintenance mode” in nextcloud.log?
What about a nightly backup? Maybe this turns Nextcloud into maintenance mode before backing up the database.
Is the Nextcloud updater running nightly?
try a
grep maintenance -F /var/log/nextcloud/nextcloud.log
On my Hansson-IT Nextcloud instance for example I get
{“reqId”:“tHeSrzd7GKmPkHP2a80F”,“level”:1,“time”:“2025-11-18T14:37:04+01:00”,“remoteAddr”:“”,“user”:“–”,“app”:“updater”,“method”:“”,“url”:“–”,“message”:“\OC\Updater::maintenanceEnabled: Turned on maintenance mode”,“userAgent”:“–”,“version”:“30.0.17.2”,“data”:{“app”:“updater”}}
as well as a “Turned off maintenance mode”, if I run the updater.
Maybe a cron job does similar with your system.
Hi… the maintenance log entries are fine, there is always an ON-OFF-pair as expected.. but :grimacing:
The backup seems to be the culprit here.
There is a log entry in the backup script log… enabling maintenance mode goes just fine, but switching it off fails:
02:05:48: Switching off maintenance mode...
In Config.php line 280:
  /var/www/html/config/ does not have enough space for writing the config file! Not writing it back!
maintenance:mode [--on] [--off]
Apparently, the backup is so large that the disk runs out of space after the backup and causes this to fail.
Ok, the rason seems to be found now.
You will need to remove old files to get more free space, like old huge log files, replaced kernel and more or enlarge the partition mounted on “/”
Do you store the backups on your root-partition? - An external disk (frequently replaced by annother one) might be a better solution.
Other Suggestions:
  • “apt autoremove” removes old unused kernels and boot files.
  • If nextcloud log is set to debug (see “Administration settings” - “Logging” in the web interface), set the log-level to a higher one.
  • Check old backups in the nextcloud backup-folder f.ex. in /var/backups and remove the oldest ones.
  • Check and remove old snapshots, if enabled (see Ubuntu docs).
The backup location is only temporary. The backup files are moved off the machine immediately to a separate, larger disk anyways.
I will have do some reorganizing to avoid this situation in the future.
I used to keep two backups “just in case”, but I can change that to “only keep the latest” for now.
My last attempt to update the server os and switch to a more recent PHP version effed up the installation :grimacing:
So I already planned to set up a totally new server, probably using the AIO docker image this time. But since I never used Docker before, there is still some learning ahead of me :grin:
Yes, but in many cases the backup archive additional will be stored in /tmp folder while compressing.
An alternative may be, to create two smaller backups instead of one large one or write onto the external drive directly.
I found a script, which can send you an alert email, if disk runs out of space:
#!/bin/bash
# found on
# https://unix.stackexchange.com/questions/84334/shell-script-to-send-an-alert-mail-if-disk-usage-exceeds-90
# but structure modified and added a "quiet" alert to prevent from flooding mailbox
# receiver of the alert email:
ADMIN=recipient@mydomain.tld
# change value to your needs - here alert, if disk usage 95% or higher
ALERT=95
silent=0 # temporary variable
# getting drives/partitions
a=`df -Hl | grep -vE 'overlay |tmpfs|cdrom|Used' | awk '{ print $1 }'`
for i in $a;do
    # get free space of partition in $i
    usep=`df -Hl|grep $i|awk '{ print $5 }' | cut -d'%' -f1`
    partition=$i
    # if too less free space and /tmp/diskspace.txt does NOT exist send alert mail
    if [ $usep -ge $ALERT ] && ! [ -a /tmp/diskspace.txt ]; then
      echo  "Alert: Almost out of disk space $usep"
      df -Hl | mail -s "Alert: out of disk space $partition $usep%"  $ADMIN
      # set a flag in /tmp/ as alert-flag-file until used disk space is lower than $ALERT
      echo alert > /tmp/diskspace.txt
      silent=1 # still alert present
    fi
  # if disk-usage greater than alert-level and alert-flag-file exists set silent mode
  if [ $usep -ge $ALERT ] &&  [ -a /tmp/diskspace.txt ]; then silent=1;fi
done
# if not "silent" anymore, remove alert-flag-file
if [ $silent -eq 0 ];then
  rm /tmp/diskspace.txt
fi
The flag-file /tmp/diskspace.txt prevents from flooding your mailbox by alert emails and will be removed automatically, if disk-usage shrinks below the $ALERT - level.
The alert-mail must be sent, before disk-usage is 100%. Otherwise the mail program cannot create temporary mail file(s) and maillog-entries.
You may run it f.ex. every 3 minutes as a cron job. I use a similar script since 20 years on a linux server in a company, where i was the administrator until last year.
If you plan to handle your backup procedure after new installation in the same way as now, I recommend to attach an additional disk into your system as temporary storage for backup.
