Nextcloud Hub 7 (28.0.1) problems with mobile nextcloud app
Hi All,
I did a upgrade to [Nextcloud Hub 7 (28.0.1) and now i can not open excel files of pdf files with my mobile nextcloud app. With the pc browser all is working normal.
I cant seem to find any errors in the logs. The files just keep on loading but nerver loads on the phone nextcloud app.
I all redeay restored a previous collabora version. However i keep getting the same issue. It must have something to do with the latest version of nextcloud. When i create a new excel file with the mobile nextcloud app it opens the file one time. Now i can edit the file and save it, However i want to reopen the file ican not open the file anymore. (Keeps loading). Seems like a bug in nextcloud.
Anyone having the same issues?
Kind regards,
Chris
Hi Chris,
sorry for only sending a Link… :sweat_smile:
Hope this helps
sambilanet
No problem. Thank you for your reply. So for pdf it is normal to not work with nextcloud mobile app anymore.
Does the same go for excel files?
Kind regards,
Chris
I don’t realy use it
Sorry again… :sweat_smile: :sweat_smile:
It is a very old discussion, you might ckeck newer ones…
Hope you can find a solution
kind regards
sambilanet
Download the Nextcloud Dev client from the FDroid store. The Dev client loads office docs just fine.
