sudo docker inspect nextcloud-aio-mastercontainer
"Id": "a696f3bff86b2bc33f605d55e2ce44f3cf41277c93799b1c7331d9dbc223bf51",
"Created": "2023-02-24T14:41:51.198765574Z",
"Path": "start.sh",
"Args": [
"/usr/bin/supervisord",
"-c",
"/supervisord.conf"
"State": {
"Status": "running",
"Running": true,
"Paused": false,
"Restarting": false,
"OOMKilled": false,
"Dead": false,
"Pid": 3762,
"ExitCode": 0,
"Error": "",
"StartedAt": "2023-02-27T22:17:56.313382823Z",
"FinishedAt": "2023-02-27T22:16:56.203412834Z",
"Health": {
"Status": "healthy",
"FailingStreak": 0,
"Log": [
"Start": "2023-02-27T16:39:30.224760222-06:00",
"End": "2023-02-27T16:39:30.311348919-06:00",
"ExitCode": 0,
"Output": ""
"Start": "2023-02-27T16:40:00.322044039-06:00",
"End": "2023-02-27T16:40:00.387923324-06:00",
"ExitCode": 0,
"Output": ""
"Start": "2023-02-27T16:40:30.394690313-06:00",
"End": "2023-02-27T16:40:30.470406724-06:00",
"ExitCode": 0,
"Output": ""
"Start": "2023-02-27T16:41:00.475164946-06:00",
"End": "2023-02-27T16:41:00.58441318-06:00",
"ExitCode": 0,
"Output": ""
"Start": "2023-02-27T16:41:30.594636576-06:00",
"End": "2023-02-27T16:41:30.670251546-06:00",
"ExitCode": 0,
"Output": ""
"Image": "sha256:261f690c504288e68478671c168fc8943cd5fac90b4899d456d99a4062d5f2c5",
"ResolvConfPath": "/var/lib/docker/containers/a696f3bff86b2bc33f605d55e2ce44f3cf41277c93799b1c7331d9dbc223bf51/resolv.conf",
"HostnamePath": "/var/lib/docker/containers/a696f3bff86b2bc33f605d55e2ce44f3cf41277c93799b1c7331d9dbc223bf51/hostname",
"HostsPath": "/var/lib/docker/containers/a696f3bff86b2bc33f605d55e2ce44f3cf41277c93799b1c7331d9dbc223bf51/hosts",
"LogPath": "/var/lib/docker/containers/a696f3bff86b2bc33f605d55e2ce44f3cf41277c93799b1c7331d9dbc223bf51/a696f3bff86b2bc33f605d55e2ce44f3cf41277c93799b1c7331d9dbc223bf51-json.log",
"Name": "/nextcloud-aio-mastercontainer",
"RestartCount": 12,
"Driver": "overlay2",
"Platform": "linux",
"MountLabel": "",
"ProcessLabel": "",
"AppArmorProfile": "docker-default",
"ExecIDs": null,
"HostConfig": {
"Binds": [
"nextcloud_aio_mastercontainer:/mnt/docker-aio-config",
"/var/run/docker.sock:/var/run/docker.sock:ro"
"ContainerIDFile": "",
"LogConfig": {
"Type": "json-file",
"Config": {
"max-file": "10",
"max-size": "10m"
"NetworkMode": "default",
"PortBindings": {
"80/tcp": [
"HostIp": "",
"HostPort": "80"
"8080/tcp": [
"HostIp": "",
"HostPort": "8080"
"8443/tcp": [
"HostIp": "",
"HostPort": "8443"
"RestartPolicy": {
"Name": "always",
"MaximumRetryCount": 0
"AutoRemove": false,
"VolumeDriver": "",
"VolumesFrom": null,
"ConsoleSize": [
0,
0
"CapAdd": null,
"CapDrop": null,
"CgroupnsMode": "private",
"Dns": [],
"DnsOptions": [],
"DnsSearch": [],
"ExtraHosts": null,
"GroupAdd": null,
"IpcMode": "private",
"Cgroup": "",
"Links": null,
"OomScoreAdj": 0,
"PidMode": "",
"Privileged": false,
"PublishAllPorts": false,
"ReadonlyRootfs": false,
"SecurityOpt": null,
"UTSMode": "",
"UsernsMode": "",
"ShmSize": 67108864,
"Runtime": "runc",
"Isolation": "",
"CpuShares": 0,
"Memory": 0,
"NanoCpus": 0,
"CgroupParent": "",
"BlkioWeight": 0,
"BlkioWeightDevice": [],
"BlkioDeviceReadBps": null,
"BlkioDeviceWriteBps": null,
"BlkioDeviceReadIOps": null,
"BlkioDeviceWriteIOps": null,
"CpuPeriod": 0,
"CpuQuota": 0,
"CpuRealtimePeriod": 0,
"CpuRealtimeRuntime": 0,
"CpusetCpus": "",
"CpusetMems": "",
"Devices": [],
"DeviceCgroupRules": null,
"DeviceRequests": null,
"MemoryReservation": 0,
"MemorySwap": 0,
"MemorySwappiness": null,
"OomKillDisable": null,
"PidsLimit": null,
"Ulimits": null,
"CpuCount": 0,
"CpuPercent": 0,
"IOMaximumIOps": 0,
"IOMaximumBandwidth": 0,
"MaskedPaths": [
"/proc/asound",
"/proc/acpi",
"/proc/kcore",
"/proc/keys",
"/proc/latency_stats",
"/proc/timer_list",
"/proc/timer_stats",
"/proc/sched_debug",
"/proc/scsi",
"/sys/firmware"
"ReadonlyPaths": [
"/proc/bus",
"/proc/fs",
"/proc/irq",
"/proc/sys",
"/proc/sysrq-trigger"
"GraphDriver": {
"Data": {
"LowerDir": "/var/lib/docker/overlay2/82d6925597b99f7a841917640016bbf2520173a16c84401ed9e8651adaf19b77-init/diff:/var/lib/docker/overlay2/b68a599ad144a1fd2d43ae6e8521093d065c6e897116e5e7c8f6a9adecf0991a/diff:/var/lib/docker/overlay2/f9d4535beece57509d9c52a7af1836139b50dd70770048debcff84feaccd043f/diff:/var/lib/docker/overlay2/567bb4acd2f3729107bfa1352cbb37d41284a83f19c692b3c1a646229c4484f8/diff:/var/lib/docker/overlay2/6afa9de603d26171d73c38f6f525c43db22a839af70084235c152256ea1d6b40/diff:/var/lib/docker/overlay2/4901d53aaf7da8829938f0cea6e1bdd9495deb5096a8b5e164d75af65d21b684/diff:/var/lib/docker/overlay2/ac115c8012e57d6a0d93b877fea44e56fb61fc3a4a8eefa51124014a8016a526/diff:/var/lib/docker/overlay2/d6b74e3ca57a25eff38b602ff417a667b1a1b5e4f1022bc6608d2459bb76f301/diff:/var/lib/docker/overlay2/71aaa299b0d3cf12be5819088bd80c04f646771d234d33b1fb1dee30985ea213/diff:/var/lib/docker/overlay2/c2766f32d0c23e26052f5b208452450432d0779f980b9d63931f9ee8aba221f1/diff:/var/lib/docker/overlay2/13b1301cceffce928589e722d70d874487f841591a82015c80fe1d4144f5491e/diff:/var/lib/docker/overlay2/7916d917c4ed6d10e87d20528c0e0bf93bd14c3f126162583e21d6e8e79b3d87/diff:/var/lib/docker/overlay2/c390264beecde9fee42b7235b2511caf2faf09e562412f9db3b264615aa23a97/diff:/var/lib/docker/overlay2/99e7b48e2e2d8e843d89dfb665bf7f3a9159fd6aab12145e3f1b7b15f7bb1a04/diff:/var/lib/docker/overlay2/9645164a0c74ba86accc01d1f396eeabca0d35d90d3e6f6cd147f267db10bff9/diff:/var/lib/docker/overlay2/0a009dfeb315f99a2fbd6e191c5a0bf953e30d0af9c420c7ca1a7e5fd8d41f9a/diff:/var/lib/docker/overlay2/270160fa7068f7617ccf47c0bae10c822f7a35b3a869cebcc027eeac0059b8d9/diff:/var/lib/docker/overlay2/e80a2377d43c1e233c27d4506187631f4031303e4dbc1d814b8686d5d2ccaef4/diff:/var/lib/docker/overlay2/6e80a3f9a7b79237d868a6059be8e0f0232c18db36c10fadfcd99d52fae4200e/diff:/var/lib/docker/overlay2/c642ab69192238901de91589e1952ef7e90f5f76d5da72f8b1b2a7776228f2ae/diff:/var/lib/docker/overlay2/b0118d555acb8427e2e5501551cd8b79ffcc7fcf708c53b82cecc8c9599ba154/diff:/var/lib/docker/overlay2/48d91fbf0e21d7c39a07840f9c575ade846ee99d87918c09fba8d5b9083c051e/diff:/var/lib/docker/overlay2/1108fdc8bac2ff1408fb067944262a79c30824723ce460b143a1cd3e3b26dac0/diff:/var/lib/docker/overlay2/08a4bb71b47958b37d55dfe4f7e9be8dce4d1d8125584f7a6c648d86a45a088a/diff:/var/lib/docker/overlay2/d7986493541c9f8cd5af92f8d98e0ae2ddd2e8f0469c34ef5492161cdd59f882/diff:/var/lib/docker/overlay2/2e07d85a18756c91cc39e321d8119735ed3900d7de6c37e4768f123931d3cedb/diff:/var/lib/docker/overlay2/78566f63905557ab17961e38a47c8a5190adae158de34f3876486e530d64b7df/diff:/var/lib/docker/overlay2/544c47e6f1e811440d060fa6efd7ff44ff9d811db4ab3521b60ee4eec8d3a09a/diff:/var/lib/docker/overlay2/7c6f95a1a82102d9f7d6084921b29eefb77010856e26d2cf9fb608e3aa35d84e/diff:/var/lib/docker/overlay2/04440857bb84fd213795273f517d06706159fb13c3c6ca4208f9075c5c60fd30/diff:/var/lib/docker/overlay2/4727a15dcde38e282748c9525840a35c21706fbb28b0aa1360fcf45a9c03df68/diff:/var/lib/docker/overlay2/ba7dbd0ee51d22d9a2e21fb1ac12d000b2a6b32ee4ee56af05bd6ef949c584a8/diff:/var/lib/docker/overlay2/0ec5c6c5a066a588711c1fe480756c0c0c0b25f6f4085c773dd079b9b36d42c0/diff:/var/lib/docker/overlay2/c8b8b17c6bafeeaf18c37776f0ba1c0324ed08554310899914ad0a9c935ad3b3/diff:/var/lib/docker/overlay2/b4843db4cb3a7e41c8fd983375b7e8c85191ddcce78344b713df41ad5351c492/diff:/var/lib/docker/overlay2/93ce791f5ddcd67dbdd4ab52c7e6bea179ad942468a4ddb50962376f26a2b4d9/diff",
"MergedDir": "/var/lib/docker/overlay2/82d6925597b99f7a841917640016bbf2520173a16c84401ed9e8651adaf19b77/merged",
"UpperDir": "/var/lib/docker/overlay2/82d6925597b99f7a841917640016bbf2520173a16c84401ed9e8651adaf19b77/diff",
"WorkDir": "/var/lib/docker/overlay2/82d6925597b99f7a841917640016bbf2520173a16c84401ed9e8651adaf19b77/work"
"Name": "overlay2"
"Mounts": [
"Type": "volume",
"Name": "nextcloud_aio_mastercontainer",
"Source": "/var/lib/docker/volumes/nextcloud_aio_mastercontainer/_data",
"Destination": "/mnt/docker-aio-config",
"Driver": "local",
"Mode": "z",
"RW": true,
"Propagation": ""
"Type": "bind",
"Source": "/var/run/docker.sock",
"Destination": "/var/run/docker.sock",
"Mode": "ro",
"RW": false,
"Propagation": "rprivate"
"Config": {
"Hostname": "f9cf3edd2d5f",
"Domainname": "",
"User": "root",
"AttachStdin": false,
"AttachStdout": true,
"AttachStderr": true,
"ExposedPorts": {
"80/tcp": {},
"8080/tcp": {},
"8443/tcp": {},
"9000/tcp": {}
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": [
"PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"PHPIZE_DEPS=autoconf \t\tdpkg-dev dpkg \t\tfile \t\tg++ \t\tgcc \t\tlibc-dev \t\tmake \t\tpkgconf \t\tre2c",
"PHP_INI_DIR=/usr/local/etc/php",
"PHP_CFLAGS=-fstack-protector-strong -fpic -fpie -O2 -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64",
"PHP_CPPFLAGS=-fstack-protector-strong -fpic -fpie -O2 -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64",
"PHP_LDFLAGS=-Wl,-O1 -pie",
"GPG_KEYS=528995BFEDFBA7191D46839EF9BA0ADA31CBD89E 39B641343D8C104B2B146DC3F9C39DC0B9698544 F1F692238FBC1666E5A5CCD4199F9DFEF6FFBAFD",
"PHP_VERSION=8.1.16",
"PHP_URL=https://www.php.net/distributions/php-8.1.16.tar.xz",
"PHP_ASC_URL=https://www.php.net/distributions/php-8.1.16.tar.xz.asc",
"PHP_SHA256=d61f13d96a58b93c39672b58f25e1ee4ce88500f4acb1430cb01a514875c1258"
"Cmd": [
"-c",
"/supervisord.conf"
"Healthcheck": {
"Test": [
"CMD-SHELL",
"/healthcheck.sh"
"Image": "nextcloud/all-in-one:latest",
"Volumes": {
"/mnt/docker-aio-config/": {}
"WorkingDir": "/var/www/docker-aio",
"Entrypoint": [
"start.sh"
"OnBuild": null,
"Labels": {},
"StopSignal": "SIGWINCH"
"NetworkSettings": {
"Bridge": "",
"SandboxID": "f065c723cb36d96b2826329a57de5df125381c4a920148b0bdcc03f09f36aa10",
"HairpinMode": false,
"LinkLocalIPv6Address": "",
"LinkLocalIPv6PrefixLen": 0,
"Ports": {
"80/tcp": [
"HostIp": "0.0.0.0",
"HostPort": "80"
"8080/tcp": [
"HostPort": "8080"
"8443/tcp": [
"HostPort": "8443"
"9000/tcp": null
"SandboxKey": "/var/run/docker/netns/f065c723cb36",
"SecondaryIPAddresses": null,
"SecondaryIPv6Addresses": null,
"EndpointID": "5880dae0475a764ae1994f314d662f7066d28969497a8011b7cf20270ba66539",
"Gateway": "172.17.0.1",
"GlobalIPv6Address": "",
"GlobalIPv6PrefixLen": 0,
"IPAddress": "172.17.0.2",
"IPPrefixLen": 16,
"IPv6Gateway": "",
"MacAddress": "02:42:ac:11:00:02",
"Networks": {
"bridge": {
"IPAMConfig": {},
"Links": null,
"Aliases": [],
"NetworkID": "9a06a4b98bf0a0f9fc9557eda9c0e350dd906298fa2c4294f1a1c99631dd44f4",
"IPPrefixLen": 16,
"IPv6Gateway": "",
"DriverOpts": {}
