Nextcloud-aio-collabora Container Accesses the AIO Master Container via Reverse Proxy
    • 32.0.0
    • Debian GNU/Linux 12
    • Docker AIO
The nextcloud-aio-collabora container accesses the master container via reverse proxy rather than internally within the Docker Network.
Steps to replicate:
  1. Packet capture going towards reverse proxy: sudo tcpdump -i any host {Proxy IP}
  2. Correlate logs with actually container:sudo docker network inspect {Docker Network} | grep -B5 {Container IP Identified}
Packet Capture excerpt:
*14:36:00.098526 br-**cfa8884114e4** In  IP **172.20.0.3**.57776 > **{Proxy IP}**.https: Flags \[R\], seq 2027403687, win 0, length 0*
Correlation:
*sudo docker network inspect cfa8884114e4  | grep -B5 172.20.0.3
“{REDACTED_UNRELATED}”: {
“Name”: “nextcloud-aio-collabora”,
“IPv4Address”: “172.20.0.3/16”,*
        "one-click-instance": true,
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "overwritehost": "nextcloud.REDACTED.com",
        "overwriteprotocol": "https",
            "localhost",
        "dbtype": "pgsql",
        "version": "32.0.0.13",
        "overwrite.cli.url": "https:\/\/nextcloud.REDACTED.com\/",
        "dbport": "",
        "updatechecker": true,
        "loglevel": 2,
        "app_install_overwrite": [
            "nextcloud-aio"
        "log_type": "file",
        "log_rotate_size": 10485760,
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 60,
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie",
            "7": "OC\\Preview\\Krita",
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "activity_expire_days": 30,
        "share_folder": "\/Shared",
        "htaccess.RewriteBase": "\/",
        "dbpersistent": false,
        "twofactor_enforced": "true",
            "Admins",
            "admin"
        "memories.exiftool": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/exiftool-amd64-musl",
        "memories.vod.path": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/go-vod-amd64",
        "DOMAIN": "nextcloud.REDACTED.com"
  - admin_audit: 1.22.0
  - calendar: 6.0.2
  - circles: 32.0.0
  - comments: 1.22.0
  - contacts: 8.0.5
  - contactsinteraction: 1.13.1
  - cookbook: 0.11.4
  - dashboard: 7.12.0
  - dav: 1.34.2
  - federation: 1.22.0
  - files: 2.4.0
  - files_reminders: 1.5.0
  - files_sharing: 1.24.0
  - files_trashbin: 1.22.0
  - files_versions: 1.25.0
  - firstrunwizard: 5.0.0-dev.0
  - google_synchronization: 4.0.1
  - logreader: 5.0.0-dev.0
  - memories: 7.7.0
  - nextcloud-aio: 0.8.0
  - notes: 4.12.3
  - notifications: 5.0.0-dev.0
  - notify_push: 1.2.1
  - oauth2: 1.20.0
  - privacy: 4.0.0-dev.0
  - profile: 1.1.0
  - provisioning_api: 1.22.0
  - qownnotesapi: 25.8.0
  - richdocuments: 9.0.1
  - serverinfo: 4.0.0-dev.0
  - settings: 1.15.1
  - sharebymail: 1.22.0
  - spreed: 22.0.4
  - support: 4.0.0-dev.0
  - survey_client: 4.0.0-dev.0
  - systemtags: 1.22.0
  - tasks: 0.17.0
  - text: 6.0.0-dev.0
  - theming: 2.7.0
  - twofactor_totp: 14.0.0
  - updatenotification: 1.22.0
  - user_status: 1.12.0
  - viewer: 5.0.0-dev.0
  - weather_status: 1.12.0
  - webhook_listeners: 1.3.0
  - whiteboard: 1.4.1
  - workflowengine: 2.14.0
  - activity: 5.0.0-dev.0 (installed 5.0.0-dev.0)
  - app_api: 32.0.0 (installed 32.0.0)
  - deck: 1.16.0 (installed 1.16.0)
  - encryption: 2.20.0
  - files_external: 1.24.0
  - photos: 5.0.0-dev.1 (installed 5.0.0-dev.1)
  - user_ldap: 1.23.0
I guess it may be the remote font config retrieval:
Currently it uses NC_DOMAIN, but perhaps it could be adjusted to use the APACHE_HOST / nextcloud-aio-apache or similar.
Can you create an Issue in the AIO dev repository for this to get looked at closer? GitHub · Where software is built
using public DNS for connections between systems is the way how WOPI protocol is designed see collabora integration guide for details.. but for weird reasons people keep asking for local connections and unfortunately kind of internal connection was added shortly Local access for Collabora
