Nextcloud 19.0.1 Problem with deleting files/folders
example
longer
example
here
Nextcloud version: 19.0.1 - 19.0.1.1
Operating system and version: Linux 5.4.51-v7l+ #1327 SMP Thu Jul 23 11:04:39 BST 2020 armv7l
Apache or nginx version : nginx/1.18.0 (fpm-fcgi)
PHP version: 7.4.8
Modules loaded: Core, date, libxml, openssl, pcre, zlib, filter, hash, Reflection, SPL, session, standard, sodium, cgi-fcgi, mysqlnd, PDO, xml, apcu, bcmath, bz2, calendar, ctype, curl, dom, mbstring, FFI, fileinfo, ftp, gd, gettext, gmp, iconv, igbinary, imagick, intl, json, ldap, exif, mysqli, pdo_mysql, Phar, posix, readline, redis, shmop, SimpleXML, sockets, sysvmsg, sysvsem, sysvshm, tokenizer, xmlreader, xmlwriter, xsl, zip, Zend OPcache
Problem with deleting files and folders
  1. delete file in groupfolder or in normal folder
  2. get status error deleting “file/folder”
{"reqId":"G4OZXksiR6VUA2mSqsCO","level":4,"time":"2020-08-05T13:50:46+02:00","remoteAddr":"1**.***.***.***","user":"***Username***","app":"webdav","method":"DELETE","url":"/remote.php/dav/files/***Username***/**folderstructure**/*filename*","message":{"Exception":"Exception","Message":"Failed to move groupfolder item to trash","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/files_trashbin/lib/Trash/TrashManager.php","line":103,"function":"moveToTrash","class":"OCA\\GroupFolders\\Trash\\TrashBackend","type":"->"},{"file":"/var/www/nextcloud/apps/files_trashbin/lib/Storage.php","line":192,"function":"moveToTrash","class":"OCA\\Files_Trashbin\\Trash\\TrashManager","type":"->"},{"file":"/var/www/nextcloud/apps/files_trashbin/lib/Storage.php","line":99,"function":"doDelete","class":"OCA\\Files_Trashbin\\Storage","type":"->"},{"file":"/var/www/nextcloud/apps/files_accesscontrol/lib/StorageWrapper.php","line":287,"function":"unlink","class":"OCA\\Files_Trashbin\\Storage","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1161,"function":"unlink","class":"OCA\\FilesAccessControl\\StorageWrapper","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":718,"function":"basicOperation","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":455,"function":"unlink","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php","line":183,"function":"delete","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":295,"function":"delete","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpDelete","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":474,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":319,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":320,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":167,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/groupfolders/lib/Trash/TrashBackend.php","Line":183,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Windows NT 10.0; rv:78.0) Gecko/20100101 Firefox/78.0","version":"19.0.1.1","id":"5f2a9d35d8e6c"}
        "***REMOVED SENSITIVE VALUE***",
        "localhost",
    "dbtype": "mysql",
    "version": "19.0.1.1",
    "overwritehost": "***REMOVED SENSITIVE VALUE***",
    "overwriteprotocol": "https",
    "overwritewebroot": "\/",
    "overwrite.cli.url": "***REMOVED SENSITIVE VALUE***",
    "dbport": "",
    "mysql.utf8mb4": true,
    "activity_expire_days": 14,
    "blacklisted_files": [
        ".htaccess",
        "Thumbs.db",
        "thumbs.db"
    "cron_log": true,
    "enable_previews": true,
    "enabledPreviewProviders": [
        "OC\\Preview\\PNG",
        "OC\\Preview\\JPEG",
        "OC\\Preview\\GIF",
        "OC\\Preview\\BMP",
        "OC\\Preview\\XBitmap",
        "OC\\Preview\\Movie",
        "OC\\Preview\\PDF",
        "OC\\Preview\\MP3",
        "OC\\Preview\\TXT",
        "OC\\Preview\\MarkDown"
    "filesystem_check_changes": 0,
    "filelocking.enabled": "true",
    "htaccess.RewriteBase": "\/",
    "integrity.check.disabled": false,
    "knowledgebaseenabled": false,
    "logfile": "***REMOVED SENSITIVE VALUE***",
    "loglevel": 2,
    "logtimezone": "***REMOVED SENSITIVE VALUE***",
    "log_rotate_size": 104857600,
    "preview_max_x": 1024,
    "preview_max_y": 768,
    "preview_max_scale_factor": 1,
    "redis": {
        "port": 0,
        "timeout": 0
    "quota_include_external_storage": false,
    "share_folder": "\/Shares",
    "skeletondirectory": "",
    "theme": "",
    "trashbin_retention_obligation": "auto, 7",
    "app_install_overwrite": [
        "joplin"
    "twofactor_enforced": "true",
    "twofactor_enforced_groups": [],
    "twofactor_enforced_excluded_groups": []
PASTE HERE
This is still a problem in 19.0.4
Anyone has a solution?
Please consider moving your question to these existing topics to keep the forum organized:
File stuck - can’t move or delete it
Issues with deleting, moving, and renaming files - External storage
apart from what @rhua just said…
have you checked the links? if one of it is fitting pls let us know and we would do the move for you (if you cant’t do it yourself)
I first tried following the next instruction:
Which at step one resulted in mayor errors and the process being killed:
Starting scan for user 1 out of 3 (Some_user_without_groupfolder_access)
Starting scan for user 2 out of 3 (Some_user_with_Groupfolder_access)
    Exception during scan: An exception occurred while executing 'SELECT `fileid` FROM `oc_filecache` WHERE (`storage` = ?) AND (`path_hash` = ?)' with params [1, "1e6013faa7e8570d55f5164261dc1b4d"]:
SQLSTATE[HY000]: General error: 2006 MySQL server has gone away
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php(169): Doctrine\DBAL\Driver\AbstractMySQLDriver->convertException()
#1 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php(145): Doctrine\DBAL\DBALException::wrapException()
#2 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(911): Doctrine\DBAL\DBALException::driverExceptionDuringQuery()
#3 /var/www/nextcloud/lib/private/DB/Connection.php(194): Doctrine\DBAL\Connection->executeQuery()
#4 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php(200): OC\DB\Connection->executeQuery()
#5 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(216): Doctrine\DBAL\Query\QueryBuilder->execute()
#6 /var/www/nextcloud/lib/private/Files/Cache/Cache.php(472): OC\DB\QueryBuilder\QueryBuilder->execute()
#7 /var/www/nextcloud/lib/private/Files/Cache/Wrapper/CacheJail.php(144): OC\Files\Cache\Cache->getId()
#8 /var/www/nextcloud/lib/private/Files/Cache/Wrapper/CacheWrapper.php(151): OC\Files\Cache\Wrapper\CacheJail->getId()
#9 /var/www/nextcloud/apps/groupfolders/lib/Mount/RootEntryCache.php(47): OC\Files\Cache\Wrapper\CacheWrapper->getId()
#10 /var/www/nextcloud/lib/private/Files/Cache/Wrapper/CacheWrapper.php(151): OCA\GroupFolders\Mount\RootEntryCache->getId()
#11 /var/www/nextcloud/lib/private/Files/Cache/Scanner.php(386): OC\Files\Cache\Wrapper\CacheWrapper->getId()
#12 /var/www/nextcloud/lib/private/Files/Cache/Scanner.php(391): OC\Files\Cache\Scanner->scanChildren()
#13 /var/www/nextcloud/lib/private/Files/Cache/Scanner.php(391): OC\Files\Cache\Scanner->scanChildren()
#14 /var/www/nextcloud/lib/private/Files/Cache/Scanner.php(391): OC\Files\Cache\Scanner->scanChildren()
#15 /var/www/nextcloud/lib/private/Files/Cache/Scanner.php(340): OC\Files\Cache\Scanner->scanChildren()
#16 /var/www/nextcloud/lib/private/Files/Utils/Scanner.php(260): OC\Files\Cache\Scanner->scan()
#17 /var/www/nextcloud/apps/files/lib/Command/Scan.php(151): OC\Files\Utils\Scanner->scan()
#18 /var/www/nextcloud/apps/files/lib/Command/Scan.php(207): OCA\Files\Command\Scan->scanFiles()
#19 /var/www/nextcloud/3rdparty/symfony/console/Command/Command.php(255): OCA\Files\Command\Scan->execute()
#20 /var/www/nextcloud/core/Command/Base.php(169): Symfony\Component\Console\Command\Command->run()
#21 /var/www/nextcloud/3rdparty/symfony/console/Application.php(1012): OC\Core\Command\Base->run()
#22 /var/www/nextcloud/3rdparty/symfony/console/Application.php(272): Symfony\Component\Console\Application->doRunCommand()
#23 /var/www/nextcloud/3rdparty/symfony/console/Application.php(148): Symfony\Component\Console\Application->doRun()
#24 /var/www/nextcloud/lib/private/Console/Application.php(215): Symfony\Component\Console\Application->run()
#25 /var/www/nextcloud/console.php(100): OC\Console\Application->run()
#26 /var/www/nextcloud/occ(11): require_once('/var/www/nextcl...')
#27 {main}
Starting scan for user 3 out of 3 (Some_other_user)
Killed
After this i tried the next proposed solution which actually solved some problems (but not all).
Then I went back to the first procedure, which this time didn’t cause any errors.
But still didn’t solve the problem.
So to be clear:
The newer problem in my log file named (and occured after my initial post):
OCP\Files\NotPermittedException: Could not create path
Is SOLVED with the instructions.
But the one in my log file that is named:
Exception: Failed to move groupfolder item to trash
Still occurs…
I do not wish to move this question to another topic, as i’m quite sure it is a problem on it’s own that has not been solved yet… (or that i’m aware of after frantically searching for a solution on the forum.)
Is there any more information that can help search for a solution?
Thanks a lot.
Hi @triver , i also noticed the mentioned problem in NC22. I did some research and i found that decreasing the serverside loglevel to 2 or less gave me some more informational log messages like this one:
unable to rename, destination directory is not writable : __groupfolders/trash/2
So then i inspected my NC data directory (usually something like /var/www/nextcloud/data) and i found the the data/__groupfolders/trash directory was missing completely. So what i did was basically:
cd /var/www/nextcloud/data/__groupfolders
mkdir trash
cd trash
mkdir 1  10  2  3  4  5  6  7  8  9
cd ..
chown -R www-data:www-data trash
Creating the trash folder with all subfolders fixed the error for me but to be honest i don’t know how it happened that the trash folder was removed. Also i don’t know if it’s enough to create the subfolders numbered from 1 to 10 or if this is something which depends on your installation.
Hope this helps!
