example
longer
example
here
Nextcloud version (eg, 20.0.5): ‘28.0.4’
Operating system and version (eg, Ubuntu 20.04): ‘docker container running the latest docker image’
Apache or nginx version (eg, Apache 2.4.25): ‘Nginx Proxy Manager 2.11.1’
PHP version (eg, 7.4): `idk where to find that’
I have been trying everything I can to get rid of the warning:
- You are accessing your instance over a secure connection, however your instance is generating insecure URLs. This most likely means that you are behind a reverse proxy and the overwrite config variables are not set correctly. Please read the documentation page about this .
But everytime I try something I does not get rid of it.
I can access the website through the domain and use nextcloud I just want to get rid of the warning.
- Open the security setup
don't need
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'XXXXXXXXXXXXXXX',
'passwordsalt' => 'XXXXXXXXXXXXXXXXXXXXX',
'secret' => 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX',
0 => 'nextcloud.XXXXXXXX.duckdns.org',
'trusted_proxies' => array(
0 => '192.168.20.50',
'overwritehost' => 'XXXXXXX.duckdns.org',
'overwritecondaddr' => '^192\.168\.20\.50$',
'forwarded-for-headers' =>
0 => 'X-Forwarded-For',
1 => 'HTTP_X_FORWARDED_FOR',
'overwrite.cli.url' => 'https://nextcloud.XXXXXXX.duckdns.org/nextcloud',
'version' => '28.0.4.1',
'dbname' => 'XXXXXXXXXX',
'dbhost' => 'nextcloud-db',
'dbuser' => 'XXXXXXXXXX',
'dbpassword' => 'XXXXXXXXXXXXXXXXXX',
'app_install_overwrite' =>
0 => 'memories',
'memories.exiftool' => '/var/www/html/custom_apps/memories/bin-ext/exiftool-amd64-glibc',
'memories.vod.path' => '/var/www/html/custom_apps/memories/bin-ext/go-vod-amd64',
'loglevel' => 2,
'memories.db.triggers.fcu' => true,
'default_phone_region' => 'ISO 3166-2:US',
PASTE HERE
PASTE HERE
You are accessing your instance over a secure connection, however your instance is generating insecure URLs. This most likely means that you are behind a reverse proxy and the overwrite config variables are not set correctly. Please read the documentation page about this ↗.
