_1uke
December 6, 2018, 1:34pm
1
Background information
I have used NextCloud in the past but never got very far with it.
I now have more experience of Linux and feel like it’s time I give NextCloud another try, but once again I am a little lost.
What I have done so far
I have downloaded NextCloudPi from this link https://ownyourbits.com/downloads/NextCloudPi_RPi_11-22-18/NextCloudPi_RPi_11-22-18.tar.bz2
I have extracted the .img file and burnt it to an SD card with etcher.
After the system has booted up I am shown the login prompt on the terminal.
I am then shown $pi@nextcloudpi at the terminal prompt.
I enabled shh using $ sudo raspi-config
Once I have done this I am back at the $pi@nextcloudpi command prompt.
My issue
At this point I think I am meant to type in USER but this gives me -bash: user: command not found
Adding sudo also gives me the same output.
I am also unable to access the web interface using https://“raspberryPiAddress”:4443
Can anyone suggest what to do next or guide me with this setup please?
If you need more details about anything please ask and I will reply.
You should first visit https://“raspberryPiAddress”
and
take note of the generated passwords
activate your instance by hitting the activation button
this first run of init may take a while…(check the /var/log/ncp.log for …init done)
You will then be forwarded to the :4443 to further setup your instance, or you do this in the terminal by running sudo ncp-config .
The $pi@nextcloudpi is the Linux command line prompt
You log in with user pi an password raspberry initially
You can change the password with the passwd command
_1uke
December 6, 2018, 2:10pm
3
Hi @OliverV - thanks for the reply
If I navigate to - https://192.168.x.x I get a message saying … Can’t connect to server / unable to connect
Can you suggest what the issue is and what I might try to fix it.
Thank you
If it is a fresh install and no risk of data loss
in terminal run
sudo ncp-config
use arrow keys to navigate to nc-init , use enter to select and run it.
then return to command line and run
sudo tail -f /var/log/ncp.log
and wait for … init done
q to quit
then reload activation page at https://nextcloudpi.local/
If this fails, you might try same thing again, but also run nc-nextcloud before nc-init , to make sure 14.0.4 gets installed properly. What model Pi are you using?
_1uke
December 6, 2018, 2:30pm
5
Thanks again @OliverV
I ran both commands and they both seemed to run correctly
sudo tail -f /var/log/ncp.log - This showed various things as ‘enabled’
Navigating to - https://192.168.x.x I am still gettting a message … Can’t connect to server / unable to connect
Is there something else we can try next to fix this?
_1uke
December 6, 2018, 2:38pm
7
I think it said,
init done
Should I run it again?
I am using a Raspberry Pi 2B+
Thank you for helping me with this.
OliverV:
So first nc-nextcloud then nc-init
Sure, give it another go and copy/paste output of
sudo cat /var/log/ncp.log
here or on pastbin.com or the likes.
Also output of sudo dmesg might contain clues to what’s going wrong. Any i/o errors are signals towards bad or corrupt sd-cards or bad powersource(cable).
Also copy/paste output of nc-info
_1uke
December 6, 2018, 3:25pm
9
@OliverV So I ran nc-nextcloud and then nc-init.
It says,
NC init done
at the very end,
Here is a link to the paste bin - https://pastebin.com/uTcn3GE2
Let me know if this is helpful and what you find.
Thank you
OliverV
December 6, 2018, 3:33pm
10
Thanks for reporting, its a bug, it will be fixed shortly…
Will let you know here when its patched.
You can then run
sudo ncp-update
which will load the fixed nc-init, so you can run it again.
BTW you can run nc-nextcloud and tell it install 14.0.4 (latest stable) instead of 14.0.3
_1uke
December 6, 2018, 3:49pm
11
@OliverV
So just to check I run the following
$ncp-config
nc-nextcloud
Then set the install to 14.0.5
nc-init
Then run $ncp-update
_1uke
December 6, 2018, 4:13pm
13
@OliverV
Yes 14.0.4 my mistake.
I have done all that but I am still getting,
Can’t connect to server / unable to connect.
Is there anything else we can do to troubleshoot this?
OliverV
December 6, 2018, 4:18pm
14
The patch has been created, Might take 10 to 12 hrs before Nacho has a moment to commit the patch.
In meantime, if you dont want to wait, you can patch the script yourself by adding PHPVER=7.2 to nc-init
sudo nano /usr/local/etc/ncp-config.d/nc-init.sh
add PHPVER=7.2 somewhere at the top of the file
save, exit and run nc-init again.
_1uke
December 6, 2018, 4:32pm
15
@OliverV
Thanks for letting me know about the patch.
I am going to try to do it manually.
Can you look at the image below and suggest the best place to ad in PHPVER=7.2?
(Right clicking ‘view image’ should let you see a slightly bigger version of the image).
Thank you
OliverV
December 6, 2018, 4:38pm
16
Was not 100% sure about that myself.
In the proposed patch I added an extra line just below the comment line
#tmp upload dir
Just above the part where variable $PHPVER gets called
It should work anywhere above there too.
_1uke
December 6, 2018, 4:52pm
17
@OliverV
Thanks for your help.
I have added in the extra line (see image below)
How do I test this is working?
OliverV
December 6, 2018, 5:02pm
18
Just run nc-init again from ncp-config.
And visit activation page to activate
_1uke
December 6, 2018, 5:40pm
19
@OliverV
I ran ncp-config, then in my web browser I visited https://192.168.x.x
I am still getting a message … Can’t connect to server / unable to connect
Have I missed out a step?
Is there anything else I can try to make it work?
OliverV
December 6, 2018, 6:13pm
20
Thanks @_1uke for hanging in there !
Could you please post (pastbin) output of
and
sudo /usr/local/bin/ncp-report
So Nacho can have look later, when he has a moment to spare.
