Dear Users,
I have a problem with the renewal of a Letsencrypt certificate. The setup of the certificate once worked without any problems. However, yesterday I got a mail that the certificate expires.
I then tried to renew the certificate via NCP Panel. However, this failed. I received the following error:
The following errors were reported by the server:
Domain: XXX.myfritz.net
Type: unauthorized
Detail: Invalid response from
http://XXX.myfritz.net/.well-known/acme-challenge/GNXI75iLy_hSGHXLmXkgPlg525WMKIEUqFMBhdLKDHo
[79.193.9.115]: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML
2.0//EN\">\n<html><head>\n<title>404 Not
Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p"
After trying various troubleshooting instructions without success, I then made the mistake of disabling Letsencryt in the NCP panel. This made the problem even worse. After some back and forth, I deleted the certificate using “certbot delete”.
But I still can’t install a new certificate. I still get this error:
[ letsencrypt ] (Mon Nov 29 12:28:44 CET 2021)
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator webroot, Installer None
Obtaining a new certificate
Performing the following challenges:
http-01 challenge for 0eyyqqyufqpypran.myfritz.net
Using the webroot path /var/www/nextcloud for all unmatched domains.
Waiting for verification...
Cleaning up challenges
Failed authorization procedure. XXX.myfritz.net (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://XXX.myfritz.net/.well-known/acme-challenge/FT89kuKf8y8s56DbzIK80HMtGSHz4AobzhBFlkDrpBg [79.193.9.115]: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\">\n<html><head>\n<title>404 Not Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p"
IMPORTANT NOTES:
- The following errors were reported by the server:
Domain: 0eyyqqyufqpypran.myfritz.net
Type: unauthorized
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address.
When I call the URl in the browser I am redirected directly to the login page of Nextcloud (https). CURL brings the following output:
curl http://XXX.myfritz.net/.well-known/acme-challenge/GNXI75iLy_hSGHXLmXkgPlg525WMKIEUqFMBhdLKDHo
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
</head><body>
<h1>Not Found</h1>
<p>The requested URL was not found on this server.</p>
So I suspect something is wrong with the redirect for “.well-known/acme-challenge/”. Have no idea what though.
Thanks a lot for your hints.
