After trying to update my nextcloud instance with beta version i’m stuck with an error.
It looks like a permission error on data folder but I don’t find it.
Any help would be appreciated
Nextcloud version : 18.0.0 RC1
Operating system and version : Archlinux
Apache or nginx version : 1.17.7
PHP version : 7.4.1
Votre répertoire n’est pas valide Assurez-vous que le répertoire de données contient un fichier “.ocdata” à sa racine. Impossible de créer le dossier “data” Ce problème est généralement résolu en donnant au serveur web un accès en écriture au répertoire racine. Voir https://docs.nextcloud.com/server/18/go.php?to=admin-dir_permissions
Is this the first time you’ve seen this error? : Y
No idea
{"reqId":"XXX","level":1,"time":"2020-01-04T22:03:50+00:00","remoteAddr":"XXX","user":"--","app":"no app in context","method":"GET","url":"/","message":"Deprecated event type for \\OCP\\Files::preWrite: Symfony\\Component\\EventDispatcher\\GenericEvent","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0","version":"18.0.0.8"}
{"reqId":"XXX","level":1,"time":"2020-01-04T22:03:50+00:00","remoteAddr":"XXX","user":"--","app":"no app in context","method":"GET","url":"/","message":"Deprecated event type for \\OCP\\Files::preCreate: Symfony\\Component\\EventDispatcher\\GenericEvent","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0","version":"18.0.0.8"}
{"reqId":"XXX","level":1,"time":"2020-01-04T22:03:51+00:00","remoteAddr":"XXX","user":"--","app":"no app in context","method":"GET","url":"/favicon.ico","message":"Deprecated event type for \\OCP\\Files::preWrite: Symfony\\Component\\EventDispatcher\\GenericEvent","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0","version":"18.0.0.8"}
{"reqId":"XXX","level":1,"time":"2020-01-04T22:03:51+00:00","remoteAddr":"XXX","user":"--","app":"no app in context","method":"GET","url":"/favicon.ico","message":"Deprecated event type for \\OCP\\Files::preCreate: Symfony\\Component\\EventDispatcher\\GenericEvent","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0","version":"18.0.0.8"}
The output of your config.php file in /var/www/nextcloud
'instanceid' => 'xxxxx',
'passwordsalt' => 'xxxxx',
'secret' => 'xxxxx',
0 => 'xxxxx,
'datadirectory' => '/home/nextcloud',
'overwrite.cli.url' => 'xxxxx',
'version' => '18.0.0.8',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'XXX',
'dbpassword' => 'XXX',
'mail_smtpmode' => 'smtp',
'mail_smtpauthtype' => 'PLAIN',
'mail_smtpsecure' => 'tls',
'mail_from_address' => 'do-not-reply',
'mail_domain' => 'xxxxx,
'mail_smtpauth' => 1,
'mail_smtphost' => 'xxxxx,
'mail_smtpport' => '587',
'mail_smtpname' => 'xxxxx',
'mail_smtppassword' => 'xxxxx,
'updater.release.channel' => 'beta',
'theme' => '',
'loglevel' => '1',
'app_install_overwrite' =>
0 => 'forms',
1 => 'apporder',
2 => 'bookmarks_fulltextsearch',
'updater.secret' => 'xxxxx',
The output of your log in syslog:
Jan 04 23:36:46 XXX nginx[818]: 2020/01/04 23:36:46 [error] 818#818: *83 FastCGI sent in stderr: "PHP message: PHP Warning: fileperms(): stat failed for /home/nextcloud/nextcloud.log in /var/www/nextcloud/lib/private/Log/File.php on line 83PHP message: {"reqId":"xxx","level":3,"time":"2020-01-04T22:36:46+00:00","remoteAddr":"XXX","user":"--","app":"PHP","method":"GET","url":"/","message":"fileperms(): stat failed for /home/nextcloud/nextcloud.log at /var/www/nextcloud/lib/private/Log/File.php#83","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0","version":"18.0.0.8"}PHP message: {"reqId":"XXX","level":3,"time":"2020-01-04T22:36:46+00:00","remoteAddr":"XXX","user":"--","app":"PHP","method":"GET","url":"/","message":"chmod(): Permission denied at /var/www/nextcloud/lib/private/Log/File.php#84","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0","version":"18.0.0.8"}" while reading upstream, client: XXX, server: XXX request: "GET / HTTP/2.0", upstream: "fastcgi://unix:/var/run/php-fpm/php-fpm.sock:", host: "XXX"
Jan 04 23:36:46 XXX nginx[818]: 2020/01/04 23:36:46 [error] 818#818: *83 FastCGI sent in stderr: "PHP message: PHP Warning: fileperms(): stat failed for /home/nextcloud/nextcloud.log in /var/www/nextcloud/lib/private/Log/File.php on line 83PHP message: {"reqId":"XXX","level":3,"time":"2020-01-04T22:36:46+00:00","remoteAddr":"XXX","user":"--","app":"PHP","method":"GET","url":"/favicon.ico","message":"fileperms(): stat failed for /home/nextcloud/nextcloud.log at /var/www/nextcloud/lib/private/Log/File.php#83","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0","version":"18.0.0.8"}PHP message: {"reqId":"XXX","level":1,"time":"2020-01-04T22:36:46+00:00","remoteAddr":"XXX","user":"--","app":"no app in context","method":"GET","url":"/favicon.ico","message":"Deprecated event type for \\OCP\\Files::preWrite: Symfony\\Component\\EventDispatcher\\GenericEvent","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0","version":"18.0.0.8"}PHP message: PHP Warning: fileperms(): stat failed for /home/nextcloud/nextcloud.log in /var/www/nextcloud/lib/private/Log/File.php on line 83PHP message: {"reqId":"XXX","level":3,"time":"2020-01-04T22:36:46+00:00","remoteAddr":"XXX","user":"--","app":"PHP","method":"GET","url":"/favicon.ico","message":"fileperms(): stat failed for /home/nextcloud/nextcloud.log at /var/www/nextcloud/lib/private/Log/File.php#83","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0","version":"18.0.0.8"}PHP message: {"reqId":"XXX","level":1,"time":"2020-01-04T22:36:46+00:00","remoteAddr":"XXX","user":"--","app":"no app in context","method":"GET","url":"/favicon.ico","message":"Deprecated event type for \\OCP\\Files::preCreate: Symfony\\Component\\EventDispatcher\\GenericEvent","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0","version":"18.0.0.8"}" while reading response header from upstream, client: XXX
Jan 04 23:36:46 XXX nginx[818]: 2020/01/04 23:36:46 [error] 818#818: *83 FastCGI sent in stderr: "PHP message: PHP Warning: fileperms(): stat failed for /home/nextcloud/nextcloud.log in /var/www/nextcloud/lib/private/Log/File.php on line 83PHP message: {"reqId":"XXX","level":3,"time":"2020-01-04T22:36:46+00:00","remoteAddr":"XXX","user":"--","app":"PHP","method":"GET","url":"/favicon.ico","message":"fileperms(): stat failed for /home/nextcloud/nextcloud.log at /var/www/nextcloud/lib/private/Log/File.php#83","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0","version":"18.0.0.8"}PHP message: {"reqId":"Xxx","level":3,"time":"2020-01-04T22:36:46+00:00","remoteAddr":"XXX","user":"--","app":"PHP","method":"GET","url":"/favicon.ico","message":"chmod(): Permission denied at /var/www/nextcloud/lib/private/Log/File.php#84","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0","version":"18.0.0.8"}" while reading upstream, client: XXX, server: XXX, request: "GET /favicon.ico HTTP/2.0", upstream: "fastcgi://unix:/var/run/php-fpm/php-fpm.sock:", host: "XXX"
Permissions:
drwxr-x--- 14 http http 4096 Jan 4 23:08 nextcloud
ls -l /home
drwxrwx---+ 8 http http 4096 Jan 4 22:20 nextcloud
Php-fpm conf:
cat /etc/php/php-fpm.conf | egrep -v "(^;.*|^$)"
[global]
error_log = syslog
include=/etc/php/php-fpm.d/*.conf
cat /etc/php/php-fpm.d/www.conf
[www]
user = http
group = http
listen = /run/php-fpm/php-fpm.sock
listen.owner = http
listen.group = http
pm = dynamic
pm.max_children = 5
pm.start_servers = 2
pm.min_spare_servers = 1
pm.max_spare_servers = 3
request_terminate_timeout = 300
env[PATH] = /usr/local/bin:/usr/bin:/bin
php_admin_value[error_log] = /var/log/fpm-php.www.log
php_admin_flag[log_errors] = on
sudo systemctl status php-fpm
● php-fpm.service - The PHP FastCGI Process Manager
Loaded: loaded (/usr/lib/systemd/system/php-fpm.service; enabled; vendor preset: disabled)
Active: active (running) since Sat 2020-01-04 23:52:56 CET; 55s ago
Main PID: 3321 (php-fpm)
Status: "Processes active: 0, idle: 2, Requests: 2, slow: 0, Traffic: 0req/sec"
Tasks: 3 (limit: 9442)
Memory: 24.2M
CGroup: /system.slice/php-fpm.service
├─3321 php-fpm: master process (/etc/php/php-fpm.conf)
├─3331 php-fpm: pool www
└─3332 php-fpm: pool www
Jan 04 23:52:56 XXX systemd[1]: Starting The PHP FastCGI Process Manager...
Jan 04 23:52:56 XXX php-fpm[3321]: [NOTICE] fpm is running, pid 3321
Jan 04 23:52:56 XXX php-fpm[3321]: [NOTICE] ready to handle connections
Jan 04 23:52:56 XXX systemd[1]: Started The PHP FastCGI Process Manager.
Jan 04 23:52:56 XXX php-fpm[3321]: [NOTICE] systemd monitor interval set to 10000ms
sudo systemctl status nginx
● nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/usr/lib/systemd/system/nginx.service; enabled; vendor preset: disabled)
Active: active (running) since Sat 2020-01-04 23:52:56 CET; 1min 40s ago
Process: 3327 ExecStart=/usr/bin/nginx -g pid /run/nginx.pid; error_log stderr; (code=exited, status=0/SUCCESS)
Main PID: 3328 (nginx)
Tasks: 2 (limit: 9442)
Memory: 3.0M
CGroup: /system.slice/nginx.service
├─3328 nginx: master process /usr/bin/nginx -g pid /run/nginx.pid; error_log stderr;
└─3330 nginx: worker process
Jan 04 23:54:10 XXX nginx[3330]: 2020/01/04 23:54:10 [error] 3330#3330: *4 FastCGI sent in stderr: "PHP message: PHP Warning: fileperms(): stat failed for /home/nextcloud/nextcloud.log in /var/www/nextcloud/lib/private/Log/File.>
Jan 04 23:54:10 XXX nginx[3330]: 2020/01/04 23:54:10 [error] 3330#3330: *5 FastCGI sent in stderr: "PHP message: PHP Warning: fileperms(): stat failed for /home/nextcloud/nextcloud.log in /var/www/nextcloud/lib/private/Log/File.>
Jan 04 23:54:33 XXX nginx[3330]: 2020/01/04 23:54:33 [error] 3330#3330: *9 FastCGI sent in stderr: "PHP message: PHP Warning: fileperms(): stat failed for /home/nextcloud/nextcloud.log in /var/www/nextcloud/lib/private/Log/File.>
Jan 04 23:54:33 XXX nginx[3330]: 2020/01/04 23:54:33 [error] 3330#3330: *9 FastCGI sent in stderr: "/3.9.2","version":"18.0.0.8"}" while reading upstream, client: 82.64.193.149, server: XXX, request: "GET /index.php>
Jan 04 23:54:33 XXX nginx[3330]: 2020/01/04 23:54:33 [error] 3330#3330: *8 FastCGI sent in stderr: "PHP message: PHP Warning: fileperms(): stat failed for /home/nextcloud/nextcloud.log in /var/www/nextcloud/lib/private/Log/File.>
Jan 04 23:54:33 XXX nginx[3330]: 2020/01/04 23:54:33 [error] 3330#3330: *8 FastCGI sent in stderr: "/3.9.2","version":"18.0.0.8"}" while reading upstream, client: 82.64.193.149, server: XXX request: "GET /index.php>
