I use a hosting provider and Nextcloud has been running fine for the past couple of years. I received a notification from the hosting provider that I’m exceeding my allocated resources. I only use Nextcloud and its an installation for a family of 4 where I am pretty much the primary user. We use it to share files, calendar, and Instant upload to upload pictures taken on our mobile phones. On an average day maybe we add/update 10 files a day so a very small installation.
The cron job seems to be running constantly. Earlier today in the Nextcloud Admin/Overview page thre was an error that said that cron had been running for 2 hours ! Its set to run every hour. I maybe added a calendar entry and maybe added a new file to today. I also run a cron for preview generator which I’ve always suspected to be a resource hog. I’ve change the cron to run every 6 hours and preview generator to every 24 hrs in an effort to reduce the resource usage.
CPU usage is into the stratosphere and MySQL minutes even more so (4000 minutes/day how is that possible?)
I was running 21.1.1 (I think) until last week and this was happening. In an effort to fix it I’ve upgraded thru 22/x/x with no change. I even went to the beta channel (against my best judgement) and am now on Nextcloud Hub II (23.0.1 RC3) hoping whatever huge bug that is causing this has been fixed. Also ran the occ index updates which completed fine. I see no discussion in the community forums that seems to address this.
My hosting provider is threatening to kick me off their service unless this can be fixed. They suggested I updated to the latest version.
I’m moderately technically literate, enough to install/update and move around but not a dev so any help/diagnostics needs to be fairly step by step.
Any ideas/suggestions?
