Maintenance releases 24.0.6 and 23.0.10 are out, plus Hub 3 RC3!
Originally published at: Maintenance releases 24.0.6 and 23.0.10 are out, plus Hub 3 RC3! - Nextcloud
Nextcloud 24.0.6 and 23.0.10 are ready for update
As always, minor releases include stability and security improvements that are designed to be a safe and quick upgrade.
You can find the full changelog of fixes and improvements for these releases on our website.
Note: There will be no more releases of Nextcloud Hub 22. Upgrade to Nextcloud Enterprise to continue to get security and stability updates or move to Nextcloud Hub II 23 or 24. Don’t forget that running web-facing software without regular updates is risky. Please stay up to date with Nextcloud releases of both the server and its apps, for the safety of your data! Customers can always count on our upgrade support if needed.
RC3 of Hub 3
In other news, we’ve published the third RC of our upcoming release, Nextcloud Hub 3. Things are really coming together already, so if you want to make sure the upcoming release works well for your system – now’s the time to test and report problems you experience! As always, we’re very keen to hear about upgrade issues as there are always more ways Nextcloud is used in than what we realistically can test!
You can get involved on our forums.
To learn more about our release, check out the big release announcement we did last weekend!
Ready to move to Nextcloud Hub 24?
Nextcloud Hub 24 received its 6th maintenance release and we highly recommend that you upgrade to benefit from the latest features. Check out the release announcement here.
🙋 User migration
đź”’ Smart file locking
🚀 4x lower db load
❤️ Reactions & media tab in Talk
🤩 Reply to calls & messages in Desktop client
đź’Ś Undo send & schedule emails
End of public support for Nextcloud 22
Nextcloud Hub 22 is no longer maintained. We will continue to release security and bug fix updates only for Nextcloud Enterprise 22. If you are a home user, move to Hub 23 or 24 as soon as possible. If you use Nextcloud in a commercial setting, check out our Nextcloud Enterprise as that is likely more suited for you. As always we strongly recommend you update to ensure you have a secure and reliable content collaboration platform that respects your digital sovereignty!
This is, of course, also true for apps: Keeping them updated has security benefits, besides the new features and other bug fixes.
Stay safe: keep your server up-to-date!
Minor Nextcloud releases are security and functionality bug fixes, not rewrites of major systems that risk user data! We also do extensive testing, both in our code base and by upgrading a series of real-world systems to the test versions. This ensures that upgrades to minor releases are generally painless and reliable. As the updates not only fix feature issues but also security problems, it is a bad idea to not upgrade!
If you are maintaining a mission-critical Nextcloud system for your enterprise, it is highly recommended that you get yourself some insurance (and job security… who gets blamed if the file handling system isn’t working as expected?). A hotline to the core Nextcloud developers is the best guarantee for reliable service for your users, and the job safety of you as a system administrator.
Changes RC2→RC3?
Yeah, changelogs are commonly forgotten in these posts.
RC3 changelog based on pull request
Pending PRs:
Click here to see on GIthub
24.0.6 changelog
Version 24.0.6 October 6 2022
Download: nextcloud-24.0.6.tar.bz2 or nextcloud-24.0.6.zip
Check the file integrity with:
MD5: nextcloud-24.0.6.tar.bz2.md5 or nextcloud-24.0.6.zip.md5
SHA256: nextcloud-24.0.6.tar.bz2.sha256 or nextcloud-24.0.6.zip.sha256
SHA512: nextcloud-24.0.6.tar.bz2.sha512 or nextcloud-24.0.6.zip.sha512
PGP (Key): nextcloud-24.0.6.tar.bz2.asc or nextcloud-24.0.6.zip.asc
Changes
23.0.10 changelog
Version 23.0.10 October 6 2022
Download: nextcloud-23.0.10.tar.bz2 or nextcloud-23.0.10.zip
MD5: nextcloud-23.0.10.tar.bz2.md5 or nextcloud-23.0.10.zip.md5
SHA256: nextcloud-23.0.10.tar.bz2.sha256 or nextcloud-23.0.10.zip.sha256
SHA512: nextcloud-23.0.10.tar.bz2.sha512 or nextcloud-23.0.10.zip.sha512
PGP (Key): nextcloud-23.0.10.tar.bz2.asc or nextcloud-23.0.10.zip.asc
Changes
