Local storage Question
Thats funny, because your partition has no space left (100% being used):
I believe that this user (dtorres) has used most of your space.
Also appdata looks a little bit big. I bet you have previews enabled and if you check inside of appdata folder preview will be the biggest one. Example of command under appdata folder:
du -ah --max-depth=1 . | sort -hr
27G	./preview
27G	.
2.9M	./js
1.4M	./appstore
704K	./css
664K	./avatar
228K	./theming
204K	./dav-photocache
124K	./identityproof
20K	./external
8.0K	./richdocuments
As you can see my previews folder is huge, but this does not disturbs me → Previews / data size
OK here is the before:
ncadmin@cloud:~$ sudo du -ah --max-depth=1  /mnt/ncdata | sort -hr
[sudo] password for ncadmin:
2.8G    /mnt/ncdata
2.7G    /mnt/ncdata/dtorres
129M    /mnt/ncdata/appdata_ocm2710gjvgh
11M     /mnt/ncdata/ncadmin
11M     /mnt/ncdata/jtorres
11M     /mnt/ncdata/datorres
213K    /mnt/ncdata/files_external
65K     /mnt/ncdata/nextcloud.log
4.5K    /mnt/ncdata/updater.log
4.5K    /mnt/ncdata/.htaccess
512     /mnt/ncdata/updater-ocm2710gjvgh
512     /mnt/ncdata/.ocdata
512     /mnt/ncdata/index.html
I am very new to NextCloud and Linux in general. I edited the config.php file, added:
  'enable_previews' => true,
    'enabledPreviewProviders' =>
      0 => 'OC\\Preview\\PNG',
      1 => 'OC\\Preview\\JPEG',
      2 => 'OC\\Preview\\GIF',
      3 => 'OC\\Preview\\BMP',
      4 => 'OC\\Preview\\XBitmap',
      5 => 'OC\\Preview\\Movie',
      6 => 'OC\\Preview\\PDF',
      7 => 'OC\\Preview\\MP3',
      8 => 'OC\\Preview\\TXT',
      9 => 'OC\\Preview\\MarkDown',
    'preview_max_x' => 1080,
    'preview_max_y' => 1920,
Then ran :
sudo -u www-data /var/www/nextcloud/occ config:app:set --value=“32 64 1024” previewgenerator squareSizes
Responce was:
Config value squareSizes for app previewgenerator set to 32 64 1024
sudo -u www-data /var/www/nextcloud/occ config:app:set --value=“64 128 1024” previewgenerator widthSizes
Responce was
Config value widthSizes for app previewgenerator set to 64 128 1024
sudo -u www-data /var/www/nextcloud/occ config:app:set --value=“64 256 1024” previewgenerator heightSizes
Responce was
Config value heightSizes for app previewgenerator set to 64 256 1024
Here is after deleting all my data and emptying the trash bin:
160M    /mnt/ncdata
76K     /mnt/ncdata/dtorres
Another view is:
ncadmin@cloud:~$ df -Th
Filesystem                     Type      Size  Used Avail Use% Mounted on
udev                           devtmpfs  1.9G     0  1.9G   0% /dev
tmpfs                          tmpfs     393M  1.2M  391M   1% /run
/dev/mapper/nextcloud--vg-root ext4       39G  8.7G   28G  25% /
tmpfs                          tmpfs     2.0G  8.0K  2.0G   1% /dev/shm
tmpfs                          tmpfs     5.0M     0  5.0M   0% /run/lock
tmpfs                          tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
ncdata                         zfs       641M  161M  481M  25% /mnt/ncdata
tmpfs                          tmpfs     393M     0  393M   0% /run/user/1000
Space seems to no longer be an issue. I still problems with my Cert but i’ll open a new thread on that.
Thanks for all the help!!
@ gas85
Sorry, seems like I spoke to soon. My disk usage is now:
tmpfs                          tmpfs     393M  1.3M  391M   1% /run
/dev/mapper/nextcloud--vg-root ext4       39G  9.4G   27G  26% /
tmpfs                          tmpfs     2.0G   72K  2.0G   1% /dev/shm
ncdata                         zfs        33M   33M     0 100% /mnt/ncdata
33M     /mnt/ncdata
5.6M    /mnt/ncdata/appdata_ocm2710gjvgh
5.5M    /mnt/ncdata/jtorres
733K    /mnt/ncdata/nextcloud.log
177K    /mnt/ncdata/files_external
65K     /mnt/ncdata/dtorres
Compare the df -Th with one from a few weeks ago:
/dev/mapper/nextcloud--vg-root ext4       39G  8.9G   28G  25% /
ncdata                         zfs        24G   24G  497M  98% /mnt/ncdata
I can no longer login with out getting the, Internal Server Error, message. How is it possible the ncdata partition is shrinking?
Any guidance would be greatly appreciated. Thanks again!
Using the preview generator app will fill your disk if not setup properly. Hence there is a script for it in the VM that can be found here.
@enoch85 Thanks for the script. I ran it till successful but this did not address my issue. As seen below the appdata folder is a good size. I can no longer login with out getting the, Internal Server Error, message. How is it possible the ncdata partition is shrinking?
/dev/mapper/nextcloud–vg-root ext4 39G 9.4G 27G 26% /
33M /mnt/ncdata
/dev/mapper/nextcloud–vg-root ext4 39G 8.9G 28G 25% /
From 24 GB to 33 Mb? Do no know :face_with_raised_eyebrow:
Could be that you have Hardware issue? Did you lost all your data in NC?
Hi Georgiy, I have become so frustrated with storage issues I have moved all my data to a Windows server. I am now using NC external disks and sync data directly. NC is now solely as a pass thru but now that is not working either. I’m shocked that so much work would be needed just to keep it stable. Admittedly I am not strong a Linux person.
This is a Hyper-V Virtual Machine, so no hardware issues are possible. The underlining host is 100%. I am now focused on the " Internal Server Error". I have reviewed many postings of the same error but can’t find a solution. Any logs to look that might help?
Thanks again!
I have’t used Hyper-V, but NC is pretty simple - it is just an application with DB access and you can map DATA folder to whatever place via config or mount. Also you can added external storage as local folder if you need. Basically you need only to bother about DB access, local storage access and make server (with Apache2 or ngnix) that will serve your https connections, additionally added you Letsencrypt cert and it is done.
It seems that something wrong with you virtual machine, but as I did not used Hyper-V, I can’t help you ad-hoc :frowning:
Try to open a ticket in GitHub with logs and all relevant data.
or for Docker:
