vascocb
September 22, 2021, 9:30am
1
I have a new installation, Debian 10 x86_64 + curl installation.
Let’s encrypt request the certificates and they are downloded.
The apache server conrinues to use the self-signed certificates.
Everything is configured but the Apache server not.
ncp-report
https://pastebin.com/WnHF1kV6
Hello @vascocb ,
maybe you could check the following topic and solution
Support intro Sorry to hear you’re facing problems
<a href="http://help.nextcloud.com">help.nextcloud.com</a> is for home/non-enterprise users. If you’re running a business, paid support can be accessed via <a href="http://portal.nextcloud.com">portal.nextcloud.com</a> where we can ensure your business keeps running smoothly.
In order to help you as quickly as possible, before clicking Create Topic please provide as much of t…
vascocb
September 22, 2021, 10:34am
3
Thanks
Did not worked
After the update and run letsencrypt the path is good but the apache server does not work
what is the output from sudo systemctl status apache2
for you?
Ihave the same issue but from within a docker container.
root@nextcloudpi:/var/log/apache2# service apache2 status
[ ok ] apache2 is running.
yes that should be fixed by now
