Hi.
I recently updated my Nextcloud-AIO instance to Nextcloud 35.
While SSO with Keycloak still works for login, I get the message that encryption keys could not be loaded and I should logout and login (when opening files)…
If I use the standard login or passkey, this doesn’t seem to happen.
If I login with password, logout, and login again with SSO, the message doesn’t show.
Do I have to setup some special fields for SSO to make encryption work?
I am using Keycloak with “OpenID Connect”…
- Nextcloud Hub 26 Spring (35.0.0) AIO
Debian 13
The one bundled with AIO
apache
- PHP version (e.g, 8.3):
nextcloud AIO
Started with 26 spring, but occurs often since then
AIO
No
