Issue with CLAMAV
    • Ubuntu 22.04.5 LTS Linux 5.15.0-151-generic x86_64
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
Suddenly, NC cannot connect to ClamAV ; so users cannot upload files on the server
 RuntimeException Could not connect to ClamAV via 127.0.0.1:3310. Please check that ClamAV is running and reachable.
PASTE
PASTE HERE
PASTE HERE
Hey @EGU973002022 welcome back and thanks for supporting the snap :waving_hand:
can you please be clear what you mean when you say Nextcloud cannot connect to ClamAV?
  • since when is suddenly?
  • what changes took place since this issue has appeared?
  • is ClamAV a service hosted on a separate host?
we’ll definitely need logs to get to the bottom of this. so please run the debugging script or check out How to manage Nextcloud snap logs to find and get those logs.
I do not understand how, but ClamAV is not anymore listening on port 3310
$ netstat -lnp | grep -E “(clam|3310)”
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
unix 2 [ ACC ] STREAM LISTENING 22107 - /run/clamav/clamd.ctl
Although, it was well working in the past…
For this configuration, I added port in freshclam.conf
sudo vi /etc/clamav/freshclam.conf
TCPSocket 3310
I noticed my config was removed from freshclam.conf (maybe due to an update ?) and now even by added again TPCSocket 3310 in freshclam.conf, it does'nt work. ClamAV is not listening on port 3310.
I would like to add that my NC instance is a SNAP version under Ubuntu with activated updates.
But ClamAV is a systemd service installed on my local Ubuntu.
So I do not know how to restore communication between them.
May you Help me ?
Best Regards
Since this week end, when user reported the issue
I did not see change, or maybe an package update ?
ClamAV is a systemd Service on my local Ubuntu, but my NC is a Snap version installed on my local Ubuntu
@EGU973002022 this makes me wonder, has it ever worked?
If ClamAV is present on the same host and you’re trying to execute any binaries that are not contained in the snap, this will fail due to snap confinement.
then you’d be better off asking the ClamAV folks.
OK, I understand that. But now how can I desactivate ClamAV in NC, temporary in order to restore the file upload for users ?
I kwow that it is not secure, but the risk is our appreciation.
show your app list
sudo nextcloud.occ app:list
to disable an app without removing it:
sudo nextcloud.occ app:disable <appname>
see
Thank you so much :folded_hands:
That ClamAV stops working “suddenly”, is correct.
freshclam updates malware signatures frequently, but ClamAV itself also needs updates from time to time.
If ClamAV is outdated, it writes log entries into the logs of programs using ClamAV at every startup of the clamd service. After 1 or 2 months ClamAV stops working. Then you will get the error message that it refuses to connect to TPCSocket 3310.
ClamAV needs to be updated from the source you installed it resp. your Linux or download, compile, install and configure a tar-ball from clamav.net.
In the future I recommend a weekly check of the log-files, whether ClamAV is outdated. Starting then, you will have 1 month minimum to update the ClamAV-package.
